Question about Kenmore Dryers
Dryer will not turn on there is a faint clicking noise when I hold the start button in
I would start with making sure You have the correct voltage. then I would check your thermal overload. This many be differant on differant models. most kenmores have one that looks white with two with two wires on it. More times than not this will fix your problem
Posted on Jun 02, 2010
My gas dryer is a whirlpool LGR4634eq0. Timer starts but when I press the power button i hear a load noise( like a stuck hinge) and the dryer wont start. Help
The power button is usually called a "start" button. For as long as you hold it down, it provides power to the motor. When the motor gets up to speed, centrifugal force holds the switch closed for you. This is why a quick (short) opening of the door will not stop the dryer and a quick press of the start button will not start the dryer.
This, however, does not explain the noise...
The motor turns a belt which wraps (sort of) around a pulley which is on a spring (and also around the drum). The spring should hold tension on the belt, but the belt should not be so resistive (drum refuse to turn) to cause the tensioner to strike anything.
Can you turn the drum by hand?
The drum rides on two wheels. They should roll smoothly.
:o).
Jun 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Won't start just clicks when i push the start button. When I push the start button I do hear a faint click in the selection ( color, white.etc.) button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Mar 05, 2011 | Kenmore Dryers
My dryer will not start. when i press the start button i hear a faint buzzing sound and nothing happens, the inside of my dryer warms up a little. other then the buzzing sound i hear no noise.
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 31, 2011 | Dryers
Dryer wont turn on. light is on when door is open. When you push on button you can hear a faint buzzing noise where timer is.
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 01, 2011 | Kenmore 600 7962 Dryer
My kenmore ultra fabric care dryer won't start when I hold the start button down. It only makes a clicking noise.
heatman101
Nov 21, 2010 | Kenmore 62602 Electric Dryer
Dryer heats, but drum will not rotate.
try looking for a thermo fuse or check vent on roof ??
May 02, 2010 | Kenmore Elite HE4 Electric Dryer
My dryer, bought in June '09 just started making same scraping noise. does not make noise when you hold dryer door open and hold in the door-closed button.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dsaf
Feb 25, 2010 | GE Profile Harmony DPGT750EC Electric...
Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
Mar 18, 2009 | Amana NDG5800 Gas Dryer
Kenmore dryer start button not working
when I push the start button on my kenmore dryer it will not start and the drum will not turn.
Nov 09, 2008 | Dryers
Dryers Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
