Question about Car Audio & Video
Hi I have locked out my citreon radio since having my starter motor replaced '4 error code' is stuck there and has been for 4 days since i tried to put in a code several times I found code in my paperwork but obviously not correct one. Basically i dont even know what model my radio is as i cant see it written anywhere on there? its a citreon saxo 51 plate so 2001. Anyone know A) how I can get rid of error code 4 and B) what the correct code should be? Any ideas much appreciated as I am rubbish with these things!!
  • 4,848 Answers
Ask here
ukbookshelf.co.uk
Posted on Jun 02, 2010
I have got hotpoint -ultima super silent wf 865 is getting sign f-12 pl let me know the solution.
These are the error codes : I hope it helps!
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
So in this instance with the second light flashing the error code would be f04 light 2. pressure switch stuck on empty
Nov 11, 2014 | Washing Machines
1982 Pontiac Firebird Trans Am, starter solenoid only engages sometimes (starter motor always spins), occasionally starter gets stuck ON, and sometimes no spark (fuel is fine but car won't start u
ANY FAULT CODES? HAVE YOU CHECKED THE STARTE DEPTH FOR PROPER CLEARANCE? HAVE YOU RITIATED THE FLYWHEEL TO LOOK FOR MISSING TEETH? I HAD AN 82 T/A AND THAT WAS WHAT CAUSED MY STARTER PROBLEMS. AS FAR AS NO SPARK DO YOU HAVE ANY FAULT CODES INTHE ELECTRONICS? TO TEST WITHOUT A SCNNER GO TO THIS LINK
Feb 11, 2012 | Cars & Trucks
I need a radio code for a F reg citreon xsara RDS audio system serial number PHACCFW9065006
Hi
The code for this radio is 6 2 1 4
I have limited capability to provide free codes so for anyone else requiring a code for their radio I recommend this site which does them for a small fee.
Please do leave a comment to show this free code is correct.
Thanks for using FixYa.
Oct 09, 2011 | Car Audio & Video
Le code (LE) ?
Display Condition LE = Motor Error.
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Thanks and have a nice day.
Jul 03, 2011 | Dishwashers
The starter motor on my Breva 1100 has stuck! I've given the motor a knock with a piece of wood and it started! I turned it off and tried to start again but it is again stuck! Any ideas before I get it...
Hi.
The starter motor will probably need to be replaced. Check if when you ignite there is voltage at the starter motor contacts. If there is voltage at the motor and motor does not start, the motor may need replacement. Sometimes it is possible to fix the motor replacing brushes and commutator (see Starter Kit, includes x 4 carbon brushes, + x 1 each commutator).
If there is no power to the starter motor, check ignition (start button wiring and grounding), starter relay and ECU connector.
The problem is usually the starter motor.
Jun 04, 2011 | 2008 Moto Guzzi Breva 1100
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
E03 error code
Error Codes
f16 N/A
Aug 09, 2010 | Siemens WTXD8300 Electric Dryer
I'm after some error codes please guys, It's flashing 2(Reduces Creases) & 4(Time Saver) I've been told that these 'do' mean something, but can I find out what it is....no Any help would be really...
List of the Error Codes I found on another site. I'm getting f04 light 2 (the "wash" light). Looks like you've got the opposite problem with your pressure switch stuck on full (f05).
f16 N/A
Sep 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Car Audio & Video Logo
130 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
