Question about Sewing Machines
Sewing Machine Ideal Automatic Quelle 785
My beloved Sewing Machine Ideal Automatic Quelle International from the 80ties brakes down. The motor suddenly got slower finally stops transporting alltogether.Now belts don't run at all. I looked at the smaller belt but do not have a manual to fix it. What could it be aand where can I start?
SewExpress
  • 41 Answers
SOURCE: pfaff 1222 belt
Hi - a few suggestions:
  1. May just need a good thorough service - generally a good idea to have it completely gone over - by an experienced Pfaff tech - every year or 2. Internal parts can dry out and simply get jammed.
  2. The timing could be off - again an experienced tech can take care of.
  3. The cam-stack (the part that actually makes your stitch formations) may have cracked. At the age of your machine, this isn't uncommon.
At the age of your machine, many other owners actually have it "rebuilt" by an authorized Pfaff service person. This model is one of those that's worth the investment compared to buying a new machine of the same caliber/quality.
If you are comfortable removing the top cover, you may be able to look at the internal parts to see if anything is broken. This will at least give you an idea of what may be happening.
Many authorized techs will not charge you to look at the machine and give you a quote. We'd suggest calling a few sewing machine stores in your area. Don't hesitate to ask friends for their recommendation of a good service person.
Hope this helps - please don't hesitate to respond if you need further info or clarification.
Happy sewing,
Kim & Linnette
Posted on Jun 13, 2008
SOURCE: changing Pfaff 1222 sewing machine belt
Have a look at this: remove the top cover and have a look (don't put your fingers in !) at the plastic gear in the middle of the mechanism (left side of he selection keys). It often cracks and then the motor is able to turn the whole mechanism for part of the circumference of this gear and when it passes on the crack, it locks or slows down until the crack is passed. You need to have it changed if this is the case.
Posted on Aug 27, 2008
SOURCE: Sewing machine, motor runs but does not sew
I HAVE THE SAME PROBLEM. I HEAR THE MOTOR AND BELT IS MOVING BUT NEEDLE IS NOT MOVING
Posted on Feb 23, 2009
  • 5 Answers
SOURCE: replace a motor belt for sewing machine
The top tension is dependent not just on the tension dial, but also on the little disks that you go through to thread the machine. If it is not threaded correctly, you will get bunching underneath. Sometimes I just have to rethread the machine-- when you get to the disks- hold the thread taut and push it through the disks before going up to the arm part. Here is a threading picture I found- but it doesn't point out the disks too much. Once the machine is stitching nicely, then the tension dial can be used to flatten out the stitches.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_900_futura_threading.htm
Posted on Mar 14, 2009
  • 14 Answers
SOURCE: motor works needle does not go up and down
You can call the company toll-free at 1-800-361-4639 and they can tell you what to do. All the phone reps I've talked ot have been wonderful.
Posted on Mar 26, 2009
Where can you buy a motor for a bernina 830 record machine circ 1977
check with Pfaff motors as some parts are interchangeable between the 2
earlier singers also had a similar motor
on the motor will be specifications so really all you are looking for is a motor that has the same specs that will fit
check the range on e-bay ---sewing machine motors
Feb 12, 2018 | Bernina Sewing Machines
What would cause a Bernina 830 Record to be sluggish and labored at low speed but run beautifully at high speed? Thank you.
Your beloved Bernina 830 Record needs a good cleaning and oiling. The old oil has solidified and is beginning to seize the machine. Continued use may burn out the motor. Also, other parts will begin to falter, ie the stitch selectors, the feed dogs, the needlebar... These old machines are great but they do require TLC to keep them happily purring.
Wheel on right side that controls the needle up and down is very tight...
Sep 07, 2017 | Bernina Sewing Machines
974 singer sewing new -sows down and the stopped why ?
Brand new? Run, do Not walk, back to the store where it was purchased. Ask for a replacement.
Mar 06, 2016 | Singer Sewing Machines
How to get the back off if it. My machine stitches slower and slower. Need to find out what is wrong
Sounds like your motor is going out. Engage your bobbin winder, and make sure the needle isn't moving. Push the foot pedal all the way down and listen to the motor. It should be a steady sound. If it sounds like it's struggling, your motor is going bad. Your foot pedal can also be an issue.
Mar 05, 2015 | Singer 2950 Mechanical Sewing Machine
I have a singer 247 it was sewing really good but started going slower and slower til it stopped could it be the motor
It is more likely that a bushing internally warms up then seizes partially. A good cleaning and lubrication could solve this. To test the motor remove the drive belt and run the motor with no load, see if it slows down if not see idea above.
May 13, 2014 | Singer 7462 Mechanical Sewing Machine
Automatic thread cutter.bobbin thread does not feed to the top.
when you stop sewing where is the arm located ,up or down ..that will make a world of difference
Jan 06, 2014 | Elna 7200 Computerized Sewing Machine
I lost the plug for my beloved husqvarna sewing machine. can i buy another one
what is the model number of the sewing machine?
are you wanting a power cord for the machine?
Jan 07, 2013 | Husqvarna Sewing Machines
Sewing Machines Logo
264 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
