Question about Sony MDS-JE440 Mini Disc Player
The disk will not eject without fiddling it out i:e a scewdriver
Can we still buy spares for this machine i:e a new disk drive??
Http://www.ebay.co.uk/itm/400466051703
These decks suffer from this fault. Both the 440 and the 480 are the same deck with the 480 having more input and output choices.
I have various models of Sony MD and only these exhibit this fault. A friend has four 440/480 decks and all have this problem. The loading belt needs to be changed, This is responsible for pulling in and pushing out the loading & ejecting mechanism. You can get them from this link on Ebay as of Jan 2015.
http://www.ebay.co.uk/itm/400466051703
(I am not related to or have any connection to the vendor).
Posted on Jan 06, 2015
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 236 Answers
What John said. Or simply buy another deck on eBay and toss the old one.
Does this problem happen consistently?
Did you force a disc into the mechanism? If so, perhaps you bent it.
The other possibility is that the paper label is coming off and getting in the way.
Posted on Jan 17, 2012
  • Sony Expert
  • 509 Answers
Yes, but if you look on eBay, the optical drives are very expensive relative to buying an old machine and using it for parts.
Posted on Aug 10, 2010
What is the biggest hard disk that i can put in my notebook???
Rather than put a new drive inside your machine, which will mean opening it up and fiddling around in a very limited space, have you considered getting an external hard drive? You can now get 1Tb for a very reasonable price. As long as your hard disk has enough juice to boot you up, you could then switch everything over to your external drive. Consider getting one with its own power source, so it does not put too much pressure on the laptop to power it via the USB.
Sep 21, 2012 | Acer Aspire 5630 Notebook
I have a dell laptop that has 2 CDs stuck in the drive and I can not get them to eject
unscrew your disk drive and step by step try to open your computer until you get to your cd drive and manually take those 2 cds out
Aug 24, 2012 | Dell Inspiron 1318 Laptop Computer PC...
Problems hl-dt-st dvdram gsa-t40n ata device
Dvd needs replacing sometimes they just fail, like you can have hard ware and not software the reverse also applies
dvd are cheap enough now
Apr 26, 2017 | Dell Vostro A860 Notebook
I can't open my disc drive on my Acer Aspire 5820T without using a pin. How do I get the eject button to work?
I suggest that you can use the other method to eject: press start and go to my computer, select the disk drive and you should see an eject option in the menu bar.Remember that disk drives are subject to computer admin and do not respond quickly to a button press, especially if a disk process in taking place...
Mar 03, 2012 | Acer Aspire TimelineX 5820T-5951 Notebook
How can I fix bad sectors in my hard drive
You cannot. The disk-drive has some "spare" sectors, and it should automatically reassign them, i.e., like using a spare tire on your car when one of the 4 tires goes flat, you just "swap-in" the "spare".
Unfortunately, unlike fixing a flat tire, there is no way to "repair" a bad sector on a disk.
Having "bad" sectors is a sign that your disk-drive is _SOON_ to _COMPLETELY_ fail. So, it's time for you to buy a new disk-drive, and copy all your files from your "old" disk to your "new" disk. Compare it to buying insurance for your automobile, in case of a "crash" while using your automobile (or your computer).
May 28, 2010 | Seagate (ST3160827AS) 160 GB Hard Drive
Disc tray will not open e-machine T5224
This is not uncommon with older CD/DVD drives.
There should be a very small hole on the front of the drive that can be used to manually eject the disk.
Straighten out a paper clip and insert it in the hole. It may take a little fiddling but you should be able to get your disk out.
Unfortunately, this indicates that you drive is failing so you should replace it soon.
I hope this helps.
Feb 21, 2010 | E-Machines emachines (emachinees) CD-ROM...
I need to remove a disk from a Sony NEC Optiarc AD-7640S
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Dec 23, 2009 | Computers & Internet
Hitachi 0A59577 320 gb disk drives reporting high pending and reallocated sectors causes system to crash.Vibration 10-200mz
The electronics inside the disk-drive is encountering "bad" spots on the surface of the disk-drive, and is attempting to allocate some of the "spare" parts of the disk-drive as substitutes for the "bad" parts.
But, it is running-out of "spare" areas to deploy.
What this means is that YOUR DISK-DRIVE IS ABOUT TO FAIL.
Buy an external disk-drive, or buy a bunch of CD-writable or DVD-writable disks, and make a BACKUP copy of your files (E-mail, music),
while you still can access your current disk-drive.
Then, buy a new "internal" hard-drive, and reinstall Windows (you *DO* have the "System Restore" disks, correct?) onto the new disk-drive, and restore your files from your backup.
If your current disk-drive is still under manufacturer's warranty, then exercise the warranty, to get a free replacement. But, make sure that you have copied all your data from the disk-drive *BEFORE* you send it to the manufacturer, because they will take *NO* responsibility for trying to "recover" any of your files.
Nov 09, 2009 | Hitachi Computers & Internet
Zip drive does not eject the disk and will not power up.
To the left of the Eject Button/Activity Light is a Disk Eject Hole. It will be a very small hole big enough for you to straighten out a paperclip and push in to hit the eject the disk
Jul 20, 2009 | IBM Iomega ZIP 750 (22P7099) External ZIP...
DVD reader
Hi I'm sorry you are having trouble,
OK, when was the last time your CD/DVD trey opened properly when instructed by pressing the eject button on your keyboard ?
This (and all other apple computers now) machine does not have a button other than the keyboard eject button to eject or open the trey. The eject button is usually the last key at the top right hand of the keyboard. If you are not using an Apple Keyboard, it does not always work. And, sometimes, that key no longer sends it's request to the Mac... SO,
Have you tried another keyboard ?
Is there a Disk in the reader? Sometimes the disk itself confuses the reader and paralyses it and restarting won't help it even freezes the system....
That is why there is another way to get the CD drive to open or eject a disk that won't come out:
Restart your mac or from an off position, turn on the Mac and VERY QUICKLY press the mouse button ( If you have a mighty mouse, be sure to click the left side of the mouse ) and hold that mouse button down until the disk ejects, depending on how much ram you have, it could take 10 seconds to 70 seconds, be patient...
If the Mac boots without ejecting the disk, then either your mouse or keyboard are not connected directly to the mac, this does not work well through a USB Hub, or the mouse or Keyboard are defective.
Keep trying it with other keyboards or mice until you get that drawer opened.
Mar 28, 2009 | Apple Power Mac G5 Desktop
Sony MDS-JE440 Mini Disc Player Logo
563 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
