Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The wall button is blinking like crazy.None of the remotes are working either. I tried to reprogram all of the remotes, but nothing is working. This was all after we lost power for a short period of time
    President:
  • 3,197 Answers
Press and hold the lock button for 3 seconds on the wall control.
Posted on Jun 02, 2010
I have a craftsman 315mhz 1/2 hp opener and both remotes stopped working. The light on the base unit is solid. I tried reprogramming the remotes both from the wall unit and from the opener. The overhead...
Sounds like your receiver has quit working. To program the remotes do this: Press and hold the button on the remote while you press and immediately release the smart/learn button. Do this for each remote. If this doesn't work your logic board is bad.
Jun 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Liftmaster HBW077. The opener operates from the wall mounted button. There are two remotes and neither will open the door. The green light on the WALL button is blinking. There is nothing that...
Check to see if the wall control has 3 buttons. If it does one of them is the lock button and you need to press and hold this for 3 seconds. The lock button has an icon of a padlock. If you do not have a 3 button wall control programming the remotes should cure it.
Dec 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
(Chamberlain 1/2 hp Whisper Drive garage door opener) the garage mounted opener will open the door, but none of the remotes now work. batteries have been changed already. Is there a way to reprogram the...
If the wall button will operate the door up but none of the devices do then look at the wall button. Find the lock button and push it for 2 seconds and then try the remotes again. This is your vacation lock. You can get a manual at chamberlain.com. Now if the door does not open or close with the remotes you can reprogram them. Press the colored learn button on the motor head and then press the button on the remote. Repeat for each remote. If they fail to program you will need a new logic board. Thanks BB
Aug 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
I came home today and my liftmaster garage door opener does not work. I checked 3 other remotes and none of them work. The button on the wall inside the garage works fine. I tried to reprogram one of...
CHECK TO SEE OF THE LED IN THE WALL CONTROL IS FLASHING. IF IT IS PRESS THE LOCK BUTTON FOR ABOUT 2 SECONDS & RELEASE. THIS BUTTON IS USED AS A VACATION LOCK OUT FOR ALL THE REMOTES AND MAY HAVE BEEN PRESSED BY ACCIDENT.
Aug 11, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door will not reprogram its remotes
Did you actually go to the power head and push the program button, then the remote button?
Is there a small wire hanging down from the power head? It's the antenna wire.
Jan 28, 2009 | Chamberlain 950CB Remote Control
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Neither remote control will open door but wall mounted button wil
Make sure the code set inside the remote is the same as in the main reciving unit code.
Dec 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener stopped working, I hit the reset button and it started working again, the wired remote on the wall works, but my 2 wireless remotes do not work, I have followed directions to...
IS THE LED FLASHING ON THE WALL BUTTON??
IF THE LED IS FLASHING THE LOCK FEATURE HAS BEEN ACTIVATED. PRESS THE LOCK BUTTON ON THE WALL CONTROL AND THE LED SHOULD STOP FLASHING.
NOW YOU CAN REPROGRAM REMOTES AND YOU ARE ALL SET.
Sep 09, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
318 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
