Question about Rosewill R900J 19" Flat Panel LCD Monitor
LCD VGA Display goes on and off.
I have one LCD. When i watch movies using dvd player connected by RCA cables it works fine.Display is proper.
When I connect my laptop with this lcd through VGA its loosing signal.The display goes on and off. I checked the same laptop connected to a projector using the same vga cable and the projector display is fine. So I think the LCD's VGA has some issue. How can I fix it.
    Problem Solver:
  • 15 Answers
Check refresh rate and setting for external display output. It won't work with unsuitable screen resolution, color depth or refresh rate. Check all three points and I believe you can troubleshoot the problem this way.
Posted on Jun 02, 2010
I connected my 32" Funai LCD TV to PC CPU with VGA cable. I could watch the movie once. However, not able to get the connection again. TV gives message "Not Support". Do i have to change the settings
Make sure your VGA chord is connected to both TV and Computer. Right click on your desktop and go to screen resolutions. Click on Connect to a Projector and click the Duplicate icon.
Jan 29, 2013 | Televison & Video
I have a 32 inch RCA LCD TV. when I play a movie, every 2=3 minutes to goes back to the blue screen, and blinks a few times then goes back to the movie. Its with every movie and I dont think it is my dvd...
Probably the Controller unit for the TV. Try hooking it up through a different connection type e.g. HDMI, component. See if that fixes the issue for the time being. If it dies then those ports you used previously are malfunctioning.
Mar 19, 2011 | Televison & Video
Can i connect a dvd player to a dell e173fpf monitor with a scart to vga adaptor/cable?
You can with an RCA to VGA converter device (Amazon has it for $45 S&H), the AV cables of your DVD player and a pair of amplified speakers. Connect the yellow RCA video cable to this device then your monitor's VGA cable to the device. Also plug in the red & white RCA audio cable to both the device and to your DVD player. Finally connect your speakers to the DVD player ad your'e all set!
Jul 04, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
"Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
May 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Jan 03, 2009 | Sony DVP-NS300 DVD Player
Screen goes from color to black and white
replace the cable with a new one it should be fine after that
Oct 26, 2017 | RCA Televison & Video
Input video to nec 1740cx-bk lcd monitor
If you are trying to use a computer monitor to watch a DVD, you probably won't have much success unless your monitor accepts the RCA plug. I have found the VGA adapters to RCA plugs will not work in this manner.
Nov 29, 2017 | NEC AccuSync LCD71VM 17" LCD Monitor
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Sep 05, 2006 | RCA F20TF10 20" TV
Rosewill R900J 19" Flat Panel LCD Monitor Logo
80 people viewed this question
Top Rosewill Computers & Internet Experts
Ian Ballard
Level 1 Expert
Jim Thurston
Alun Cox
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
