Question about Sebo Automatic X1 Bagged Upright Vacuum
Hi, My Sebo X1 has a problem... The brush has stopped rotating (just after a noise like a jet engine!). Is this a belt problem? What's the best way for me to check. Thanks, MP
    President:
  • 389 Answers
It's possible you have a broken belt, although Sebo belts usually last at least 10 years and often much longer. The first (and easiest) thing to do is remove the brush roll and check that it's not damaged where it mounts on the metal drive spindle. If that's OK, place the machine in a position where you can see the drive spindle then, keeping fingers and clothing well clear, switch on and check if the drive spindle rotates. If a belt is broken, the spindle will (of course) not rotate. The ultimate check is to take the cover off and have a look. To do that, first separate the bag compartment from the base, then turn the base upside down and undo the four deeply-recessed screws. Turn the base over, move the suction tubes out of vertical and just lift the cover off. The belts will be exposed and all will become clear (or possibly not!).
If you need guidance on changing belts, you can search on this site, as it's a question I've answered many times here. If you still have a problem, post a reply here and I'll see what more I can do to help. Good luck!
Posted on Jun 04, 2010
The brush on sebo x4 will not go up or down. Red check brush light briefly flashes
You should try to replace your SEBO roller brush with the softer one. The part number is SEBO 5010GE Genuine Sebo product
Jan 11, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Height adjustment not working.
It's likely the circuit board that controls the height adjustment motor, or the motor itself. Your local sebo service center will be better able to test to see just what is wrong. Though it wouldn't hurt to take a look at the boards sometimes they're visibly burnt, or connections can be loose. Good Luck!
Feb 16, 2013 | Sebo Automatic X1 Bagged Upright Vacuum
Faithful Sebo X1 upright, about 12 years old, stopped working today. I replaced old with new dust bag, checked all dust paths were clear, checked main brush was clear/clean, and drive spindle rotated OK...
At 12 years, this vacuum has had a good long life. I suspect the motor is shot, but it could be due to faulty wiring and connections. A bad switch, break in the power cord, and worn brushes in the motor are other causes.
I recommend taking it to a shop for diagnosis and repair. You may be better off buying a new vacuum if the cost of repair and parts seems excessive.
Mar 01, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
The brush roller will not rotate. I have removed it, cleaned it and vacuumed the interior of the machine and checked for blockages.
The motor that runs the brush must have gone bad...
Check and see if you have a vacuum repair shop near by that can replace that motor..
heatman101
Aug 29, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
New Filters have been fitted on the Sebo automatic XI
OK - I'm a Sebo expert, and we will get to the bottom of this! I need you to do one thing for me: lie the machine on one side, then switch it on and look to see if the brush roller is revolving - KEEP FINGERS and all loose items WELL CLEAR. Does the brush revolve? Then, with the machine switched off and unplugged, see if you can rotate the brush roll by hand. Does it revolve easily, or is there a lot of resistance? Then post a reply here saying what you observe. I'll get back to you when I've got your reply.
Feb 24, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo automatic X1. After switching on the motor
As sure as possible without actually seeing your machine, the carbon brushes on the motor are worn out. They are quite easy to replace (and not expensive). If you need help with doing the job, just post a reply here and I'll guide you as best I can. If you choose to have a professional do it for you, it should take no more than half an hour's labour.
I hope this has been helpful - please remember to score me! Good luck!
Feb 10, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Replacing a belt on a Sebo Automatic X1 vacuum cleaner
The roller brush has stopped turning, I think it could be the belt, how do I seperate the top from the bottom?
I will await your reply.
Thankyou Val
May 18, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo Automatic X1 Bagged Upright Vacuum Logo
321 people viewed this question
Top Sebo Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
