Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Double image - colors out of sync, concave image
Colors do not synchronize. Image is concave on the top and bottom. It drifts from green and red out of sync to in sync.
    Scholar:
  • 170 Answers
Bad converage ic's, check reisters around them and fuses for -&+VCC
Posted on Apr 09, 2008
Concave image and multiple images on the edges along with multiple colors of green, red, and blue.
It is a convergence problem.
Tell me brand and model number and I will tell you what is needed or if it is reasonable to repair.
SD TECH
May 22, 2010 | Sony Televison & Video
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Getting double image in colors
this is a lost of convegence power. first check to see if you have the convergence option in setup menu. if you do not then i suggest you read the fl231 problem in the tips and trick section. otherwise there a good chance u would have to replace convergence power supply board
Mar 18, 2009 | RCA R52WM24 52" HDTV Projection Television
Double Image Red and Green
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
How do i center the colors, red, blue and green?
Replace Both of your convergence ICs STKs, big black ICs.
STK392-560, also CK pico fuses around ics you may have 1or2 bad .
HAPPY NEW YEAR!
Jan 01, 2009 | Sony KP-61HS10 61" Rear Projection...
51mp392H/17...bowing and color alignment off
Take the TV to a repair shop. It sounds like the convergence chips are bad. Be sure they change them as a pair or you'll wind up with the same problem again.
Dec 09, 2008 | Philips Magnavox 51MP392H Rear Projection...
Seeing double image in three colors
Its a convergence problem for sure ,,,if you cant move the red or blue (green is stationary) then your problem lies on the convervence module.. requiring ....mostly new output ICs like STKs your going to need a tech, for convergence is a common problem with rear projectors and requires patience and a expert to get it back just right. good luck
Sep 01, 2007 | Akai PT4298HD Rear Projection Television
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
151 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
