Question about Sharp Televison & Video
I am servicing a Sharp 13J-M100 color TV. I am getting the sound excellent on all channels but no video. What can cause this problem?
  • kazakman7 Jun 03, 2010
    I am working on a Sharp color TV 13J-M100. I am getting good sound from all the channels but i am not getting any video.
    President:
  • 1,961 Answers
Is your tv monitor is lit up?is it a crt tv or a lcd tv?if this model is a crt tv the problem is on the cathode and heater.it is located at the neck of the picturetube..you can see a crt board.it is a small pcboard that is connected to the picture tube by a CRT socket...you can see a label on the on the pins of the connector KR,KB KG.means cathode red cathode blue and green..you can see a pin named h1 and h2 means heater ground and heater positive check wether the heater supply is present.it is supplied by a 3-6v ac...check for open resistors on supply of the heater...if it is a LCD TV,,check the power inverter of the screen backlight,. a backlight is a cold cathode lamp which is supplied with a high voltage coming from the inverter board.inverter board is supply by a 12-24 volts dc...replace the inverter board if there is no high voltage output....tnx
Posted on Jun 03, 2010
  • Sharp Master
  • 5,138 Answers
There could be several reasons as to why you have sound and no video
Check the Hori output see if it is shorted,or Bad capacitor,Video IC on crt board,Bad FBT flyback Transfomer depending on which pin feeding high voltage that maybe bad or Low ohm resistor could be open that feeds to the high voltage circuit.
Posted on Jun 02, 2010
How do I reset to factory setting a Sharp TV model 13J-M100?
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Dec 08, 2014 | Sharp Televison & Video
Sharp 13J-M100 owner manual
you need to get the tv to an auxillary channel...this is accomplished by the remote...try getting a replacement thru eBAY or possibly buy a universal remote.
Aug 28, 2014 | Sharp 13J-M100 TV
Can I override the max volume on Sharp 13J-M100
You have to get into its service mode option to adjust the Max Volume. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 25, 2012 | Sharp 13J-M150 13" TV
My sharp 25n-m100 only gets a couple of the cable channels how do i make it get all basic cable channels
In the menu look for an ANT INPUT option, choose cable and look for an AUTO TUNE option. Hit the AUTO TUNE and wait til it scans all the available channels.
Dec 24, 2010 | Sharp 25N-M100 25" TV
How to hook up a dvd player to a SHARP r19-m100
Ur tv have colors R,Y,W Video,Audio IN holes from the back or the front wright?The DVD player have R,Y,W Video,Audio out holes from the back wright?Used the AV component cable R,Y,W hook it up to the tv R,Y,W Video,Audio IN holes,the other side of the AV component cable to the back of the DVD player R,Y,W holes.Now u are all hook up and ready to play movies.
Oct 20, 2010 | Sharp 19R-M100 19" TV
I don't know how to set the tv to receive all of the channels
Enter the "menu" and select auto program. This will allow the set to search for all available channels. There is also a possibility that when you hooked it up the little wire center conductor in the cable might have been bent over when you hooked it up. Check that first.
Apr 16, 2010 | Sharp 19R-M100 19" TV
Need codes for sharp tv
hi! i have a couple of codes for your tv! just try them, 1023, 1045, 1062, 1095, 1380, hope this helps! goodluck!!!
Nov 18, 2009 | Sharp 13J-M100 TV
No audio on select channels
Go into the TV's menu and see what type of audio mode its set on. If it says sap turn on to stereo or mono. If it says stereo, set to mono. Also try to unplug set for 12 to 24 hours.
Sep 03, 2006 | Sharp 25R-M100 25" TV
Televison & Video Logo
51 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
