Question about Zebra 105SL Thermal Label Printer
Power on Zebra 105SL printer the LCD panel is blank
When I power on a Zebra 105SL printer the LCD display panel is blank and after about 10 seconds ALL of the lights on the front of the printer come on and stay on. Has anyone come across this problem and got a solution?
Thanks
Tony.
SOURCE: ZEBRA 105SL : PRINTING PROBLEM
Thanks your the solution. This helped me a lot.
Greetings
Thomas
Posted on May 05, 2008
SOURCE: Poor Quality Print on Zebra 105SL direct thermal
How many labels has the printer printed? Because it sounds to me like you just need to replace the print head.
They are around $400 from whomever your supplier is, and very easy to replace.
Posted on Nov 21, 2008
Wiired
  • 122 Answers
SOURCE: How to check the MAC address of Zebra 105SL Printer
go to the configuration on the printer. Scroll through until you reach the network settings. You can display or print the results, which will show the MAC address. Also, if you have a PC on the same network, and you know the IP of the printer, you can look at your ARP tables and find the MAC associated with the IP. ARP -a at the dos prompt
Posted on Jun 23, 2009
  • 254 Answers
SOURCE: ZebraDesigner Pro is changing my settings
use a different driver for each printer.
Posted on Sep 03, 2009
  • 31 Answers
SOURCE: Zebra 105SL print only half of label
This can happen if your page size in your driver is not set to the actual label size. It can happen if you have old .dll driver files mixed with your mew driver installation.
This is what I would do:
Uninstall the driver completely - delete the icon in Printers and Faxes. Drop down the file menu there and choose server properties and remove the driver for all Zebra printers from the Drivers tab. Go into the LCD menu of the printer and load defaults. Go back into the LCD meny and look at the page width setting. Your printer has 300 dots per inch, so a 4 inch label would be 1200 dots wide.
Another thing to consider is that you may be trying to printer to a 300 dpi printer from a 203 dpi driver. Make sure that you choose 300dpi when you reinstall. This should work.... If not, repost with more details about your application and driver. I can assure you that this is not a printer problem unless half of your printhead has failed.... unlikely, but possible....
Posted on Jan 31, 2010
We have a Zebra 105SL thermal printer. When I print to it with any application, the data light comes on, but it doesn't print. It has ribbon, media, calibrated, no error lights
The data light indicates that the printer is receiving data. Hold the cancel key for 10 seconds while powering on. This will print printer configuration. Use to troubleshoot. If the data or format is wrong it will not print as you send data. Make sure you are using the 105SL printer driver. To test the printer functionality you can go to www.teklynx.com and download a demo copy of labelveiw, select the 105SL printer and try to print a simple label. If you can print with labelveiw then it is not a printer problem. Double check your driver and label format.
Nov 12, 2010 | Zebra 105SL Thermal Label Printer
Zebra 105sl laebls always come out blank
Power on while holding the pause button for 5 seconds. This should print black bar across the width of the label. If this prints, then check the darkness parameter in your label format or driver. Also check to make sure your ribbon is feeding coated side out. There is a shiny side and a dull side to a ribbon. The dull side should be against the media. If it is leaving an image on the ribbon and nothing on the label the ribbon is either loaded incorrectly or not a zebra ribbon.
Oct 03, 2010 | Zebra 105SL Thermal Label Printer
Zebra printer feeds out to omuch of the lable to start so printing too low
Press the cancel button 5 seconds while power on. This will give you a config. printout. Check the top position, and tear off position for settings of 0. If it is anything else change it and save .
Jun 16, 2010 | Zebra 105SL Thermal Label Printer
Zebra 105SL thermal Label Printer prints blank with new supplies
Some possible reasons:
1. The darkness is not set high enough for the paper/ribbon combination
2. The ribbon is on backwards. Zebra uses coated-side out ribbons so the ribbon should be coming off the right side of the roll if you're looking at it from the side.
Hope that helps !
Apr 16, 2010 | Zebra 105SL Thermal Label Printer
Jun 23, 2009 | Zebra 105SL Thermal Label Printer
Blank labels keep feeding out
Disable start up calibration maybe?
May 09, 2009 | Zebra 105SL Thermal Label Printer
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
227 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
