Question about Sport & Outdoor - Others
I would like to know approximately how long to run the pump before I can expect it to start looking cleaner please.
  • 2,100 Answers
What are you pumping? I am guessing you have silt or mud coming out of the faucets in the house. When the pump guys drill or drive a well, they have a monster pump on the truck, 3 or 4 times as powerful as the one you have, they pump a big hole and blow it back down and pump it out again creating a void or a cavity that will stay that way for as while. You can run your pump all day to try and get it to clear up, But it might not do anything. It won't hurt it though. You can get a sand filter on the line to get some of the heavy stuff out, then get a fine filter under the sink for the smaller stuff that sneaks through. Check it out.
Posted on Jun 02, 2010
  • singer_y Jun 02, 2010
    I don't think you understood my problem. I am using a Bestway Flowclear Pool pump and I am trying to filter/pump the dirt in my pool. Since I no longer have the instruction manual, I just want to know how long to expect it to take to pump my pool out.
    Thank you.
  • Ned  White
    Ned White Jun 02, 2010
    No, I had no idea what you were pumping, I was just guessing. Your pool filter huh? It could take days, weeks to get that thing clear, that is why they run them so much. How dirty is it? Does it need to be shocked? Did you have the chlorine tested? Is the water green or just dirty? You can get the big stuff with a scoop if you have to, but as long as the pump is going and the filter is on there and clean, it should be cleaning the water. But it will take a few days. Hope this helps.
I cant get my a985 F250 to stay running, bought a new Carb, bought a new ignition control module, new coil
Check the wiring from the ignition switch . When you got fuel as the engine was cranking then the power for the pump is on the start side of the ignition switch and not in conjunction with the run side of the switch.. IT could be a fuse in the run circuit or a faulty pump relay.
Feb 17, 2014 | Cars & Trucks
Shuts off driving
fuel pump or crank camshaft sensor ,if no codes most likely fuel pump in the tank ,if check engine light on check the codes and expect crank cam sensor usualy crank sensor will cause it to cease running ,when that happens check the spark by removing one wire and watching for spark close to the ground or spray some fuel like carb cleaner or starting fluid into the air filter and see if it starts
Oct 21, 2013 | Dodge Durango Cars & Trucks
2007 Nissan Sentra 2.0 that has a starting problem.
Running lean , not enough fuel . Have fuel pump pressure an flow tesing done . Have a scan tool hooked up to look at engine sensor data . Any number of thing's can cause this type problem . an looking for a magical fix on here is going to fix it . Newer vehicles have complex electronic's , PCM/ECM engine computer an sensors ! Diagnostic equipment an someone who knows what to look for is what fixes the modern automobile . Training as well !!!! Coolant temp sensor could cause this .
001 Introduction to Fuel Control
Fuel Pump Current Ramp Test Diagnostic Quick Tips Snap on Training...
May 24, 2017 | Cars & Trucks
Would like to know what code 506 means on my 04 f150all i did was change my battery and check engine light came on truck started to stall and run ruff is there a reset sequence i need to go through? please...
P0506--idle air control system rpm lower than expected--check around where battery was replaced may have damaged or knocked loose a vacuum line- possible dirty throttle body clean throttle body check for restriction in intake air tube also clean" iac"---possible faulty pcv valve fix or replace if necessary--good luck
Jan 27, 2010 | 2004 Ford F150
I have Lenovo G530. I have it for only 3-4 months. The problem is, it takes the computer (laptop) approximately 60 sec. to open a directory, such as My computer, My documents, any other directory on the...
Check the system status (Start, Control Panel, System) to make sure that the system senses the full amount of memore on your system.
Check the Task Manager (Ctrl-Alt-Delete) Performance to check the Physical Memory being utilized.
If these are as expected, you may have a virus.
Run a virus scan such as McAfee, Norton Anti-Virus, or Kaspersky to clean any viruses. You may also want to run a registry cleaner such as System Mechanic or RegCure.
These will clear the majority of the problems in your described situation.
Let me know if these work. Thanks
Nov 16, 2009 | Lenovo IdeaPad G530-3331Ue PC Notebook
My 91 cammry suddenly wont start I have spark for sure! I suspect a fuel problem where do I start. & whats the procedure Chuck
Easiest thing to do is make sure you right. On the air cleaner hose theres a smaller hose connected to it coming from the valve cover remove it and spray a little carb cleaner or gas into the big hose with the engine cranking. If it fires up running on the carb cleaner you know its a fuel problem if not the timing belt could have broke. To check that, on some models you can remove the oil filler cap and see the cam or rocker arm. Crank the engine and if the parts don't move the belt is brocken. Thats where to start
Aug 13, 2009 | 1991 Toyota Camry
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Pump problems?
Their can be a number of things.. Is the pump priming. Hopefully it did prime. what usually happens after running for awhile, with no cool water coming in. The water inside the pump basket starts to heat up, then the tubing turns to brownish on the input side of pump and exhaust side. (you could have air leaking in throught the input side, which could result in the pump never priming) Or if it is priming and no pressure (can mean your empellar is clogged up)
Mar 07, 2009 | Pentair Mastertemp Heater
My 1996 Chevy Cavalier started running hot and had a srong burning smell to it today. I have been looking into it and it seems that the water pump needs to be replaced (another hint was that I have been...
I am a mechanic in a shop in my area and replacing a water pump on your car would not cost that much money. I checked the prices of a water pump and thermostat and I would not charge more than $250 for the job. I pays 1.5 hours labor to replace the pump. I hope this is helpful.
Jan 10, 2009 | 2001 Chevrolet Cavalier
Frost, ice on coils DeLonghi DDE50E Dehumidifier
expected? of course! this is not ur solution try draining all the water to the sewerage if u cant try to pump it out with a vacuum cleaner (that can pump water) or a pump then turn on the Dehumidifier every time it frosts turn it off untill it defrosts or u can heat up the basement with a bellower and the Dehumidifier wont frost
Feb 05, 2006 | DeLonghi DDE50E Dehumidifier
Sport & Outdoor - Others Logo
14 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
