Question about Acer X221WSD Monitor
Acer 17 in. monitor
Blanks out after only a few seconds icons come up then it blanks out not even a year old yet
  • 3 Answers
Boot to safe-mode. (f8 pressed prior to windows starts) choose "safe mode" in this advanced boot menu. If the screen displays in this mode, it's a driver issue. If it fails, it's the screen or the vid card. Swap screens (CRT preferred) if it works vid card is good, screen is bad. If it fails you must use a known good vid card to isolate the point of failure
Posted on Apr 09, 2008
SOURCE:
My acer monitor is under a year old,and now when u turn it on it flashes for a few seconds then it goes blank..
Hello. It is possible that one of the lamps that illuminate the screen is damaged, or may be .. something else. must be brought into service.
Feb 03, 2011 | Acer AL1912 19" LCD Monitor
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
Shuts down after a few seconds
hi there, check your power supply on cpu if theres a tripping off , so if theres then replace power supply. then switch it on again. then let me know what happen nexr..
reagards rated me... thanks
Mar 31, 2009 | Acer AL1715 17" LCD Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
SCREEN GOES BLANK
Hi.
I have have repaird a few monitors, the acer one was the back light, but it was I think 7 capacitors, they were old, aged, and stopping the light from working.
So, get it apart, and replace ALL the caps, they are not expensive, do not touch the parts when powered up, it is high voltage, and will probably hurt you whilst killing you, so, DONT TOUCH!
Check out web for any other help, lots of videos to show you how to proceed.
Ray.
Jan 01, 2018 | TDV Vison F153 Monitor
Acer X221WSD Monitor Logo
107 people viewed this question
Ekse
Alun Cox
