Adapter was sparking as there was a split in the adaptor wire and
Adapter was sparking as there was a split in the wire and now laptop dont power up.
    Sergeant:
  • 253 Answers
Please cut and resoldering of your output cable where sparking
Posted on Jun 02, 2010
Crackling noise coming from travel power adapter
Only one reason for the noise on a power adaptor and you already guessed it - spark jump. Do not use until repaired or replace.
Jan 28, 2014 | Computers & Internet
When the power adaptor is connected to toshiba tecra T9000 notebook there is little little spark from the power jack
There is probably a small crack on the cord that goes from the adapter to the computer. I had a similar problem with old laptop my cat had bitten the cord, and bit through part of the wire. I replaced the connection and got rid of the spark.
Aug 25, 2013 | Toshiba Tecra T9000 Notebook
My hp pavilion dv6-2117ax laptop won't power up (no power light on where adaptor meets laptop). Replaced power adaptor / charger and laptop powered up and operated for a day and then next day woul
The laptop probably isn't charging. Could be a bad d/c connector on the laptop or the battery is bad. Remove the battery and plug in the a/c adapter and see if it powers on. Wiggle the a/c plug in gently while pressing the power button on the laptop. It powers on and off briefly then I'd say it's the d/c jack on the laptop, bad sodder joint.
Dec 04, 2012 | Computers & Internet
I have a F7D2101 Surf & Share Wireless USB Adapter and I have a wired internet connection. Can i use the surf and share USB adaprtor to share the internet (Creating a hotspot) between my desktop and...
You need wireless router for your usb adapter if you want to share your internet connection. Just an example if you have 2 laptop which dont have wireless adapters then you need 2 usb wireless adapters.
Sep 06, 2011 | Computers & Internet
The black outer part on my power adaptor on the connector part that goes into the laptop has started to split- exposing the wire underneath. Is it worth getting this fixed or am I better off just buying a...
Hi Nicole. It's better to just have the cable repaired. Take the adapter to the nearest TV repair shop or computer repair shop and ask them to replace the jack. This shouldn't be expensive, about $10, depending on where you live. Adapters go from $30 to 50, so it's not worth the investment especially if your adapter is working just fine.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Feb 02, 2011 | Compaq Presario B1200 Laptop AC Adapter...
My laptop battery is drained to battery low after being fully charged.
two possible couses.
first one the adapter is not charging well the battery and therefore the adapter contains a problem.
the second one the battery is damaged.
Aug 12, 2010 | Computers & Internet
I CONNECT THE CHARGER AND THE CHARGER DON'T CHARGE THE LAPTOP. NOW I I REMOVE THE LAPTOPS BATTERY AND PLUG IN THE CHARGER AND THE SAME THING HAPPENS THERE'S NO LIGHTS, NO POWER AND THE BATTERY IS DEAD....
There are 2 possible problems with your notebook.
1) Adaptor/Charger problem. (common)
2) Notebook power problem. (slight)
To check if there is a problem with your charger.
a) Plug in charger to any wall socket.
b) Get a small solid wire (prefferably insulated).
c) insert one end of the wire to the positive point of the adapter or the inner side of adapter.
d) scratch the outer side of the adapter using the other end of the wire to check for sparks. a spark is highly visible on a 12v power.
e) if no spark is created, then there could have been a problem with your charger.
Hope this helps.
Mar 23, 2010 | ASUS Eee 4G Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
AC Adapter is beeping
the best would be ebay. type in your model number and you should find a compatible version. i dont recommend the universals, they dont show up on certain computers correctly such as dells. most charges retail on ebay for about 16 bucks. if you want it fast. get it overnighted. still will be cheaper than anything you buy in the store..
heres a link
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=acer+aspire+charger&_sacat=See-All-Categories
good luck!
ruben
Mar 29, 2009 | Acer Aspire 5630-6288 Notebook
How to fix Power Adapter
Does your adaptor geting warmer when plugged to power outlet for some time (minutes)?
If not, than there are two possible solutions:
First (the easiest) thing is to check if both wires are not cut or short (one that you connect to power outlet, and the other one you connect to your laptop). You'll need some multimer to do this.
Most possible is that you'll need to open the power adaptor to do these checks.
Second thing is to locate and check the Fuse. Most of the adaptors have a Fuse inside.
If the fuse is OK, the wires are also OK, and the adaptor is getting warmer (or not), than you should buy a new power adaptor.
My experiance sais, not to belive much to repaired laptop adaptors (you don;t say what laptop you have).
Also, do not ask for substitute (cheap) adaptor!
Find an original one!
Most important is the following:
Please note that you should't try to do these checks, if you don't feel you are enough qualified. You should ask some friend of your's or some service. It should't cost you much !
Also, if you try to do this by yourself, be EXTREMELY carefull when adaptor is open. DO NOT PLUG it to power outled !!!
You might be killed !!!
Regards.
Mar 26, 2009 | Toshiba Satellite 2210CDT Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
