Question about Samsung SF-340 Plain Paper Inkjet Fax
Paper jumped problem
Hi-I have a samsung SF-340P machine.Last night one paper jumped.I remove that papaer.But still now its showing"Remove jumped paper then press stop/clear."
    Genius:
  • 2,120 Answers
Do you mean jammed?
Usually they don't lie. A piece of paper is somewhere.
Posted on Sep 01, 2008
Display is showing broadcast how do i remove it
take the power out hold the red stop button in and put the power back.
if that do not work the main board is foulty.
Nov 09, 2011 | Samsung SF-5100 Plain Paper Laser Fax
CRU fuse error in my Samsung SF 5100 P
did you replace the fuse in the cartridge.remove it.
Aug 01, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Sir my printer samsung sf-565pr show error [jam 1] or [no cartridse] plz give me solution for this problem
Sounds like a paper jam check out the paper path going through machine. somewhere in there is some paper jamming a switch the cartridge is the printer head that holds the ink uinstall cartridge then reinstall . Then trace back what made it do this what happened the last time it worked. If nothing else go through the reinstallation process like you are hooking it up for the first time and that way you check all your cords make sure the paper tray is right and reload the driver and see , It is something simple one or all those things I mentioned.
Apr 01, 2011 | Samsung SF-565PR/XST Printer
Paper jam
It jams due to the rollers. Please change the rollers and it should be good. also pay attention to the way the paper is being seated in the drawer.
Jun 29, 2009 | Samsung CLX 3160fn All-In-One Printer
SF-341P
Remove all papers from the machine, unplug it from the mains suply and try all over again,
If the problem persist most probably there is a broken or an unplug actuator sensor inside the machine or in the scaner area.
GOOD LUCK.
Oct 31, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Samsung fax machine SF-365TP
Before diagnose the problem please turn off the Machine.
Check all sensor if they have dust then clean it.
Close properly the cover.
Sep 15, 2008 | Samsung Office Equipment & Supplies
Samsung sf- 360 - removing jammed paper
There may be a small piece of torn paper holding the sensor.
1. Try loading a piece of paper and selecting 'paper feed'
It may take a couple of goes.
2. Try the same with thin card.
3. with the machine switched on remove the power cord.
4 Discover the 'Reset' routine for this particular machine.- It may be
in the manual if not look up www.fixyourownprinter.com
then in the field type the make/model
Jun 13, 2008 | Office Equipment & Supplies
Samsung sf-5100 Fax machine - no paper
Check inside the paper tray area to see if the paper sensor flag is dislodged. Otherwise it will be a board problem. Vacuum clean out any toner spill. Try a can of compressed air to blow any paper dust from any sensor. They will be the little black U shaped devices. Make sure the flafs move freely in and out of the sensors.
Jul 24, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF-340 Plain Paper Inkjet Fax Logo
67 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
