Question about Sharp EL-738 Scientific Calculator
How to add decimal on SHARP EL735S
How to get program more decimals after the dot on numbers. I ve got only 2decimals and I want at least 4
How do i increase decimal places on a sharp el735?
Posted on Aug 18, 2010
How can I round 0.4678476 to the nearest dollar?
When rounding, we always look at the number in the position directly to the right of the position we are interested in. In this case, the whole dollar is the number immediately to the left of the decimal, so we look at the number immediately to the right of the decimal. If this number is 5 or more, we add 1 to the number to the left of the decimal. If the number to the right of the decimal is 4 or less, we do not add 1 to the number to the left of the decimal.
In this case, the number is 4, so it rounds down to 0.
Good luck,
Paul
Feb 16, 2016 | Office Equipment & Supplies
How to change decimal point
If you want all entries and answers to have two numbers after the decimal, you should have a lever or slide that shows F,6,3,2,1,0. Some also show Add. Set the lever on the 2 or add. F means floating decimal. the others indicate how many numbers after the decimal.
Oct 30, 2014 | Sharp EL-1701C Calculator
What is the default setting for the f cut 5/4 and the 4320 add 2 I don't know what to have these options set at thanks EW Seattle
The selector you are asking about is the "decimal selector". The result displayed/printed, will be in a format according to the position that you have selected as follows:
f = floating (the result will be in the number of decimal places that were entered on the keyboard
4= fixed 4 decimal places (x.0000)
3= fixed 3 decimal places (x.000)
2= fixed 2 decimal places (x.00)
0= fixed 0 decimal places (x)
add 2= (add mode*,fixed 2 places) ($.00)
Note* "ad mode" automatically enters the decimal place when entering the number on the keyboard. If you enter "123", the displayed ammount will be "1.23". If you enter "1", the display will read ".01". This is a useful setting when adding a list of numbers in a dollars/cents format, however, be careful, if entering a whole dollar ammount "three dollars" be sure to enter the decimal point, or enter the number as "300". If you don't, the result will be ".03", instead of the 3 dollars you intended.
May 20, 2011 | Royal 29307U Calculator
It is showing fractions instead of Decimals when i do equations like (4 divided by 9) it gives 4/9 instead of the decimal.
Calculation results will be displayed using
fractions, r, and ?. When you press CHANGE, the display will cycle
through the following display styles:
• Mixed fractions (with or without ?) ? improper fractions (with
or without ?) ? decimal numbers
• Proper fractions (with or without ?) ? decimal numbers.
Feb 03, 2011 | Sharp ELW535 Calculator
How to turn printing on and off?
PRINT KEY: To save paper you can only print what is displayed, even in non-print mode. Pressing after the entry of a number will print the entry with the symbol “#” even in non-print mode. Pressing will insert a separator into a number entry such as a code, date, etc. Separators are displayed as a period and dashes but printed as periods. MEMORY + KEY / PRINT ON / OFF KEY: Pressing selects print mode or non-print mode. Cause the calculator to operate in a display / print or display only mode, depending upon the calculator’s present state. “P” on the display: Print mode. “NP” on the display: Non-print mode. MEMORY – KEY / DECIMAL SELECTION KEY: Pressing sets the number of decimal places in the result. “F” on the display: The answer is displayed in the floating decimal system. “3, 2, 1, 0” on the display: Presets the number of decimal places in the answer. “A” on the display (Add mode): The decimal point in addition and subtraction entries is automatically positioned to the 2nd digit from the lowest digit of entry number. Use of the add mode permits addition and subtraction of numbers without entry of the decimal point. Use of , and will automatically override the add mode and decimally correct answers will be printed.
Aug 18, 2010 | Sharp EL-1611P Calculator
Only shows 1 decimal place!!
Press 2ndF TAB and then a digit specifying the number of digits you want after the decimal point.
May 23, 2010 | Sharp EL-501WBBL Calculator
I have done something so the calculator is only displaying whole numbers and will not show anything after the decimal point. Thanks!
Hello
The floating point number display (FIX) is set to zero decimal digits. All your. numbers with decimal parts are rounded.
Look for a key that says [FIX]. Press it and enter a number say3 If I guessed right (Sharp makes numerous calculators) your numbers will show 3 decimal digits.
If there is no such key look for a [MODE] Button. Press the button. If you have a new screen with differents choices look for Format, Float,
On some older calculators there is a table below the display. At the left of the table one finds MODE--> or -->MODE
If it says there Mode DEG:4 that means to have angles in degrees you enter [MODE][4].
I think I exhausted all possibilities. Without you model number, I cannot do more.
Hope it helps.
Sep 04, 2009 | Sharp Office Equipment & Supplies
SETTINGS
Check the Decimal / Add Selector. It shoul be set to "A" (Add mode), to permit addition and subtraction of numbers without entry of the decimal point.
You may also want to download the SHARP
EL-1801P Operation Manual
Jun 22, 2009 | Sharp EL-1801P Calculator
I have a Sharp EL-1801P III. I want to make it so that when I type numbers in and his add it automatically puts the decimal in for me. For example if I typed in 3596 it would make it 35.96. Is this...
Your calculator has a decimal counter (top center of calculator starting with the letter F654321A) for lack of a better name for it. Anyway mine is set at A. It puts the decimal in for me. I hope this helps you. if you haven't figured it out by now.
Jan 15, 2009 | Sharp EL-1801P Calculator
I lost my decimal point
You need to be in add mode, and have 2 decimal places selected for the result.
To change to add mode, make sure the 'K . A' switch is in the 'A' position. To get 2 decimal places in the answer, move the selector in the 'F 6 3 2 1 0' switch to the '2' position.
You can see the above described at
this Sharp.com page which shows the users manual. The manual shows examples.
Mar 19, 2008 | Sharp EL-1197P Calculator
Sharp EL-738 Scientific Calculator Logo
1,339 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
