Question about UIS Abler USA ABLER Venus 500 (VS500) UPS System
My ups fuse blows
My ups blows. i turn it on and turn it off 3 times when iturn on again the fuse blows i change the fuse but it wont work. how to fix it? ablerex 500
    Sergeant:
  • 253 Answers
If there is short circuit in your ups. circuit than it come that type of problem,
please check properly of the primery side of your ups circuit
Posted on Jun 02, 2010
My turn signal fuse blowed got new one now they dont work why
canada or USA, (diffr. laws, different wiring, even DRL up there)
station wagon or NOT?
THE TURNS FUSE BLEW OUT. 2nd time, 3rd,,,?????
that means the circuit is overloaded or shorted.! (prevents fire)
but did it blow a 2nd time, why not say so???
all 4 lamps dead. or stuck on, or flash odd. or what? dim?
does the cluster lamp flash, , in blink or emerg. mode?
wont work , means what, (dead or stuck on or dim)?????
do emergency flashers work? ,dead, stuck on what?
does car drive perfect day or night?
are any other things on car dead, of odd acting?
we see all this , 1st 5 min in a shop, zero here.
ive answered Forenza blinks here, many times.
ever search?
ill now answer by guessing USA non stationwagon and no DRL.
dash box fuse 4 kills blinkers
EF1 (engine fuse) 1 good?
dash fuse 14 and EF1 can kills emerg. flasher
so of Emergancy flash lamps blows fuse 14,(smaller of 2)
then the blinkers are in fact shorted.
does it?
if yes, then find out which side blows the fuse 3.
turns left blow or turns right blows.
so if say turns right blows, F4 fuse.
if true ?remove all bulbs front rear right bulbs.
does the fuse hold now,(means not blown)
then buy new lamps there. problem solved
bulbs can in fact short.
not just blow open.
Tell the full story and all this gets easy.
For sure emergency flash,
Mar 09, 2016 | 2007 Suzuki Forenza Sedan
No heat and blower doesnt blow
If one of the two thermal fuses are blown you will not get heat. Thermal fuses blow (and are not resetable, they must be replaced) when the machine gets too hot. Often this is caused by not enough air flow through the machine. Check and make sure your exhaust vent is not clogged. Clean it the best you can to get all the lint, dead mice, bird nests, etc. out. Also make sure air is blowing out of the machine when it is turned on. If not you have a blower problem.
Turn the power off to do this. The thermal fuses are located on the element casing. They each have two wires coming out of them. They are about 3/4 inch round with screw ears on the sides so they are about 1 1/2 inch long and about an inch across. Goodluck, Dont forget to rate me as fixya..
Jan 30, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Why does fuse 15 keep blowing on citroen picasso 2007
change the fuse from 15 amp to 20 amp will cure your problem
Jun 06, 2014 | 2007 Citroen Xsara Kombi
Short need help 96 toyota camry
Test the relais condenser and replace , and test again if the fuse is blown.
Otherwise you must go to the repair shop.
The short is the most difficult are to isolate.
You will need a VOM.
May 10, 2012 | 1996 Toyota Camry
Maytag performa dryer suddenly stopped working, as if no power. i replaced both fuses and it worked. ran for about 15 mins and stopped again. any suggestions?
did it blow the fuses a second time.try this .put your dryer on a cycle that wont call for heat and turn it on.if the heat strips are not on and it still blows a fuse it is the motor.if the heat strips are on and it blows a fuse the heat strips are the trouble.
Nov 05, 2009 | Maytag Performa PAV2200
My sony receiver tuner wont turn on. It was working fine yesterday now it wont power up. The fuse near the plug wire inside is good. Any suggestions
Fuses almost never go bad something causes them to blow. Even when a blown fuse is found in electronics just t replacing it can cause more damage if something caused it to blow, a repair person looks for bad parts before replacing a fuse. Only microwaves are known to blow fuses and replacing the fuse fixes it. About the only thing that people can do is unplug a short time and try it again. And need i say is the power outlet ok.
Nov 03, 2009 | Audio Players & Recorders
Fuel pump wont run
Power from the relay comes from the ignition switch. If you don't have power at the relay then its likely the switch.
Jul 09, 2009 | 1994 Geo Metro
When trying to go up my window fuse keep blowing out
IF ITS ONLY THAT ONE DOOR THAT BLOWS THE FUSE TAKE OFF THE DOOR PANEL AND LIKE YOU SAID CK TO MAKE SURE NOTHING IS RESTRICTING MOVEMENT IF EVERYTHING A-OK REPLACE THE MOTOR SOUNDS LIKE ITS HAD ENOUGH AND IS PULLING TO MANY AMPS THATS WHY YOU KEEP BLOWING FUSES GOOD LUCK HOPE THIS HELPS
Jun 25, 2009 | 2004 Chevrolet Aveo
Neon wont start
Replace the damaged wiring harness
Jun 27, 2008 | 1998 Dodge Neon
UIS Abler USA ABLER Venus 500 (VS500) UPS System Logo
245 people viewed this question
Top UIS Abler USA Computers & Internet Experts
David Payne
David Payne
Are you an UIS Abler USA Computer and Internet Expert? Answer questions, earn points and help others
