Question about HP LaserJet 3390 All-in-One Multifunction Printer
How do I set automatic fax receipt?
On the HP Laserjet all-in-one 3390 How do I set up the automatic fax receipt? I want a receipt to be printed each time I send a fax, that tells me the details about this particular fax I sent, whether it was received or not, etc.
If you got a satisfactory solution to the fax receipt issue, I would surely appreciate your sharing it with me. I don't think that any HP all-in-ones will give you a receipt from the recipient. I need this too.
Maybe I will reinstall Win Fax
Posted on Jul 31, 2010
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
We can't receive faxes and when we send them they all say no answer HP Laserjet 3390, I have installed a new catridge and still will not work
Program it to try to send a FAX to your cell-phone, to see if sending a "test" FAX will cause your cell-phone to ring. If not, then investigate why.
Mar 02, 2011 | HP LaserJet 3390 All-In-One Printer
Hp 3390 work with w7 64x in scan mode ???
Your 3390 will only scan by using the Windows scanning software, the HP solutions do not work on Windows 7.
This is how you can scan from your 3390, assuming you have been able to get it working for printing on your system.
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scan .
  4. Click New Scan , and then click Scan .
Feb 26, 2011 | HP LaserJet M2727 MFP Series PS
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
Trying to set up fax to print when sending fax
Setting print times for the fax call report
You can set the all-in-one to print a fax call report after any of the following events:
● Every fax error (the factory-set default)
● Send fax error
● Receive fax error
● Every fax
● Send fax only
● Never
NOTE If you select Never, you will have no indication that a fax failed to be transmitted
unless you print a fax activity log.
To set the print times for the fax call report
Use the following steps to set when the fax call report is printed:
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Reports, and then press .
3. Use the < or the > button to select Fax Call report, and then press .
4. Press the > button once to select Print report, and then press .
5. Use the < or the > button to select the option for when you want the fax call reports to be printed.
6. Press to save your selection.
Sep 24, 2009 | HP LaserJet 3390 All-In-One Printer
HP laserjet 3900, when receiving a fax, displays
You can set as Fax only mode in fax configuration and set the ringing count to one. ring then it l give fax tone automatically.after that u check from any other number and verify it.
Aug 25, 2009 | Office Equipment & Supplies
The fax will not receive automatically even though it show's as being set to automatic
This issue can occur when the receive-to-PC setting was previously enabled for the PC connected to the printer, and the user is trying to enable this feature once again without disabling the previously enabled setting. This is because the receive-to-PC setting can be activated only from one computer.
Perform the following steps in the correct order to re-activate the receive-to-PC setting:
1. Turn the receive-to-PC setting off from the all-in-one printer control panel.
Here are the steps to be performed from the printer:
a. On the all-in-one control panel, press Menu .
b. Use the < or the > (left or right arrow) button to select Fax functions , and then press Enter .
c. After you selected the Stop Recv to PC setting (any faxes that remain in the all-in-one memory are printed).
2. Next, to turn the receive-to-PC setting on from the printer software, perform the following steps from the printer:
a. Open HP ToolboxFX .
b. Select the HP LaserJet 3050 / 3055 / 3390 / 3392 all-in-one.
c. Click Fax .
d. Click Fax Tasks .
e. Under Fax Receive Mode , select Receive faxes to this computer .
Performing the preceding steps should ensure that the user is able to select/activate the receive-to-PC setting.
Aug 07, 2009 | HP LaserJet 3050 All-In-One Printer
HP 3392 is not picking up the paper -
start - settings - printer and faxes right click on your printer
properties -
device settings
choose A4 instead letter
and the same at printing defaults
Jul 10, 2009 | HP LaserJet 3390 Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3390 All-in-One Multifunction Printer Logo
184 people viewed this question
Seeker5211
Seeker5211
