Question about JBL GTO 301.1 Car Audio Amplifier
I got the live and earth leads the wrong way round but now there the right way and the amp wont come on at all. theres no protection light and the fuse is ok???
  • 140 Answers
You will need to disassemble the entire amp, check all components and replace burned ones.
some components burn when wrong polarized.
Posted on Jun 02, 2010
On my Autotrail Tracker Motorhome , when i plug the mains in the reverse polarity light comes on ( i have checked the wires both ends ok ) but when i plug it in on a camping site its ok , the only...
it is a strange one. you do need an earth wire lead but the problem i'm seeing is that your mains maybe the wrong way round.. try another socket to plug into but im thinking the socket you are using is wired the wrong way round. camp sites are tested on a regular basis as they have a lot of use on there plugs so there sockets will be the right voltage and the right way round for the volts.
Mar 12, 2014 | Cars & Trucks
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Break lights on all times????????????????????
Hi
I know you said the switch is all the way out but they can stick internally and will appear that the switch is still out but the small conatct inside will still be down. check that before going any further.
No your right the abs would not cause the brake lights to stop working in any way as it is not connected at all. Check the earth/ground leads from the rear light clusters to the car body, ensure they have a good conatct, shiny metal to metal. check the wiring from the rear lights also.
sometimes people use the wrong bulb in the brake lights and the light connections connect the cluster board as one, basically the wrong bulb can make the lights stay on through contact to an incorrect part of the assembly board for the rear lights.
Alos check the main battery lead black one earth/ground from the car battery to the car body ensure again this has a good contact from the battery to the car body. there will be another earth lead going to the gearbox, check all your earths, as a poor earth can again cause this fault.
Thats quite a bit of information, sorry it's just there are so many things that can cause this fault.
Hope this helps
regards
dan
Feb 26, 2010 | 2000 GMC New Sierra 1500
I've got 2 blaupunkt amps pushing 2 10" kicker cvr. the only problem im having is that when i start my truck the "protect" lights comes on for about 2 min then it switchs to the "power" light, it that just...
The wiring could be wrong, it sounds like you have taken the live feed from ignition, the main feed should be direct from the battery with an inline fuse as close to the + terminal as you can, the earth lead should be as short as you can from the amp to the chassis, and the remote lead comes from the head unit.
Feb 06, 2010 | Kicker Solo-Baric L7 10'' Car Speaker
I have wired a new light fitting into our downstairs toilet however when I came to test it the light worked but half the other downstairs lights are now switched off when the toilet light is swithced off....
Hi
Probably put your family at risk of electricution . By connecting the live cables to earth you have effectivly made all the metal light fittings live. It is amazing that the fuse has not blown, This in itself is dangerous and you should have an electrician look at the wiring.
The correct wiring should be as follows.
Identify cables there should be 2 twin and earth (red black & copper earth) cables and 1 twin red and copper earth. (or 2 single red wires)
connect all copper earth wires suitably sheathed in green/yellow sleeving to earth lug.
Connect 2 black cables to neutral block.
Connect either single red (0r 1 of 2 reds) into live block.
connect remaining 3 reds into loop block.
HTH
Nov 11, 2009 | Kitchen Appliances - Others
My amp is not working! i have a live from battery and a good earth,but still nothing,does it need to be earthed to back of head unit?
Do you have the remote turn-on lead hooked up?
There should be 3 wires on the power side of the amplifier.
Ground - to the car chassis
Power - to the car battery
Remote - to the remote turn on lead from the head unit. (this emits a 12V signal to a relay inside the amplifier for it to turn on when the radio does)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2009 | Car Audio & Video
I'm just about to have a towbar fitted on a new car for a caravan. I am unsure whether to have a 13-pin socket fitted, as up till now our old caravan and car had just the 7-pin sort for the tailboard and...
Saves having to use a supplementary socket
01 Yellow Left Indicator
02 Blue Fog light
03 White Earth (35amp)
04 Green Right Indicator
05 Brown Right Side Light
06 Red Brake Lights
07 Black Left Side Light
08 Yellow Reversing Light
09 Green Permanent live
10 Blue Ignition live
11 Red Earth (35amp)
12 Black Coupled Trailers
13 White Earth (35 amp)
Aug 31, 2009 | 2007 Volkswagen Golf
Protection light coming on when car is off but when the car is on it works fine, protection light is killing battery while car is off.
The amplifier appears to be permanently live thus running and drawing current (often significant) all the time. This will drain batteries relatively quickly (particularly a smaller older battery as expected).
As for the protection circuit. This could be a number of things. Firstly it could be undervoltage that is causing this, whereby a low voltage when the alternator is not charging is triggering the protection circuit. Alternatively it could be a wiring issue. If the Earth is switched instead of the main live, but somehow the device has a poor earth elsewhere (ie through the remote live which is NOT live when switched off) this could also trigger the protection circuit.
All amps are different of course, but most have a permenant 12v feed, an earth and a remote live which is generally triggered either by the ignition or by the headunit when this switches on. If it has these 3 power connections but they are not wired up this way then modifying this to follow these rules will help you.
Mar 27, 2009 | Car Audio & Video
Pioneer GM-D7400M power light keeps flashing?
ur rcas could b round the wrong way you might have a weak earth aswll
Mar 24, 2009 | Pioneer GM-D7400M Car Audio Amplifier
Hello, I get a mild electric shock from the strings on my bass guitar after i have turned my amp on. Nothing seems to be wrong with the bass itself and i have checked the plug for loose wires or split...
Hi FR101621
This is not good, you should not get electric shocks of any part of your gear. I strongly suggest that you take it to a qualified electronics guy that can perform an electrical safety check on it for you. It may be that the earth potential of your mains is different to the earth potential of the floor you are standing on. This may cause a small shock(would depend what country you are in and the mains system supply you are using). In any case, I would (for your safety) get it checked and tagged as safe. This is the only way to be sure you wont eventually GET KILLED!! Does not cost alot, usually about $30. Then you know it is good
regards
robotek
Oct 12, 2008 | Audio Players & Recorders
JBL GTO 301.1 Car Audio Amplifier Logo
51 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
isaac johny
isaac johny
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
