Question about Dunlop 535qc Chrome Crybaby Wah Pedal
No effect. i plug in my instrument and only get volume and no effects.
    Champion:
  • 211 Answers
Please check if you step full down if the switch under the pedal is switching. If it does than check the battery.
Regards,
Gerard
Posted on Jun 02, 2010
Which is the master volume to boss me 25 ?
Hi, I can help you with your question. On the face of the effects, towards the right side, there are three settings that can be adjusted: DRIVE, TONE and VOLUME. The VOLUME knob is your master volume. The expression pedal can adjust volume, but it's output volume is controlled by the master VOLUME knob we just identified. I hope this has helped you, and if it has, could you please click on the "helpful" button ? Thank you!
Feb 03, 2016 | Roland Boss ME-25 Guitar Multiple Effects...
Dunlop crybaby 105q wah effect not working
Sounds like a short in the effects board of the unit causing it to bypass the volume pot.
Feb 19, 2013 | Music
Crate amp very low volume
Effects loops plug sockets get dirty and cause the sound to not get through to the actual power amp. Check those by plugging in a cable and wiggling to see. It needs to be wiggled and unplugged to see. Also, check for dirty volume control.
Feb 17, 2013 | Music
I have a marshall mg100hdfx head. it was working fine and I turned it on it started screaming like feedback at full volume. it does this with all volume at zero and without anything plugged in the inp
This could be many things and unless you are electronically adept it is unlikely you can DIY the repair... HOWEVER I want you to try one thing first: Sometimes the contacts on the switches of the Effects send and return go bad leaving the input to the power amp section floating and it can feedback. To test this, plug an INSTRUMENT cable between the send and return effects jacks on the back. This bypasses the contacts, If the amp behaves, you could run it this way getting a short cable or have the amp worked on at a shop to replace the jack. The jacks are really rather poor quality on musical amps in general.
May 13, 2012 | Marshall MG100HDFX 100-Watt Amplifier Head
Fender Acoustisonic Jr. One day I played it at its highest volume, then turned it off. Came back to play it 20 min. later and it wouldn't make a sound. You can slightly hear the guitar buzzing when...
I would try using another speaker to see if you can get the sound back, this will help you narrow down the problem, you can also use the effect send to feed anothe amp to see if you get the sound OK.
It can be blown speaker or output stages,
Jul 08, 2011 | Fender Acoustasonic Junior Dsp Combo...
The control for the Effects Loop Mix seems to function like a master volume control. I get no sound in ay channel if the Effects Loop Mix control is in the "EFF" position (right) and sound...
That is the way it is supposed to work... It is a level control to control the level sent to an EXTERNAL effects unit. What external effects unit are you using? Brand and model please. If you proportion more to the effects loop, you want to make sure the EXTERNAL effects unit is on and its gain controls are up. The foot switch input should control the EXTERNAL effects unit when you plug the footswitch into the EXTERNAL unit. The footswitch input on the amp itself has NOTHING to do with the external effect loop, it only affects the amp's own DFX unit.
Jun 25, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
What is the volume in and out on the back for
There is no "volume in and out" on the back of this unit. I am not sure what you are refering to. There IS an FX level control switch on the back which is used IF you are using EXTERNAL effects units. This switch is used to set the level to MATCH that required of the EXTERNAL device. If you are NOT using external effect unit, this switch is not used. It will not be active unless you plug into the external FX jacks.
Apr 24, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
All 3 cannels on my kb 100 working intermitently ? then not at all. can anyone help......cheers.......
Sometimes the bypass switch contacts on the effects jacks get oxidized and fail to connect the preamp to the power amp... test this by plugging another guitar cable between the two effects (send and return) and see if the amp is solid with the cable in place, These jacks in the music equipment are really not very durable. If in failed mode you can plug a cable into the effects RETURN and touch the tip and NOT get a it of hum, there is a problem in the power amp portion. Conversely if that works, then plug a set of headphones into the effects SEND and see if you can hear a signal from the inout coming through... Itwill only be on one side of the headphones (left) as it is a monaural jack. If you can't hear a weak signal here, the problem is in the preamp... LIKELY a cracked board or bad solder around one of the volume or master gain controls... a very common problem and often is intermittent... you might try wiggling the volume/gain pots sideways a tiny bit... if it pops on, remove the amp and look for bad solder on the control leads where they attach to the board.
Jan 21, 2011 | Peavey Kb2 1x10' Keyboard Amplifier
When i'm on clean sound the machine sounds ok, but when i switch to other effects on factory setting the effects sound level cut down tremandously. it just sound like being muted or being **** in. any...
A lot of pedals when on bypass actually just connect the signal straight through... WHILE when using the effect, the volume control parameter is active. You need to balance the effect volume control against the straight through level which you have no control over.
Jan 06, 2011 | Boss ME25 Guitar MultiEffects Pedal with...
Dunlop 535qc Chrome Crybaby Wah Pedal Logo
83 people viewed this question
Top Dunlop Music Experts
Michial Gueffroy
frankrome
rhodesworks
Are you a Dunlop Music Expert? Answer questions, earn points and help others
