Question about Pioneer PDP-427XD 42 in. Plasma Television
WHEN ON STANDBY WHEN TRY TO SWITCH ON BLUE LIGHT COMES ON BUT AFTER A FEW SECONDS FLASHES HAVE TO ATTEMPT MANY TIMES TO SWITCH ON ALSO SOMETIMES WHEN TRY TO TURN VOLUME UP OR CHANGE CHANNEL SWITCHES OFF TO BLUE FLASHING LIGHT. SOMETIMES GET CRACKLING SOUND AND SOUND EVENTUALLY FADES AWAY, HAVE TO TURN OFF AND ON TO RECOVER. WHAT CAN I DO TO RECTIFY PROBLEM
    President:
  • 1,099 Answers
Hello, Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Jun 02, 2010
I have a Hisense led tv model F39V77C.
Yeah, replace the set since it appears to be trashed. But if you have a few bucks lying around you might want to try replacing the unit's power supply to see if that resolves the many issues you have.
Jan 03, 2017 | Hisense Televison & Video
Finlux 32 fld850u
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 25, 2014 | Televison & Video
Flashing light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Unlike other brand TVs, reading the blinking codes to Philips is different. Check the linked site by type in 'Philips' at its search box, and press Enter.
Apr 14, 2014 | Philips 32PFL5403 LCD TV
Lights only go on standby
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 13, 2013 | Toymax Magnavox 37MF231D 37 in. LCD TV
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
My avantalk btck 10b wont connect to my blackberry curve
Had the same problem. It all looked OK and it found the Avantalk, but it would not 'pair' and kept failing. I decided the problem was probably with the Avantalk unit and wondered if I had paired it with too many other phones so decided to do a 'reset' on it. This is achieved with the Avantalk turned 'on-standby', with the two blue flashes every few seconds. Press and hold the up and down volume buttons for more than 5 seconds, at which point the red and blue lights will flash on and off 5 times very quickly. The unit should then return to its 'on-standby' state again. Switch it off (larger MFB phone button), then on again and then set it into pairing mode (immediately after the Avantalk has come on, press and hold the MFB button again until the red and blue lights are flashing), then go through the searching blue-tooth device and so on again with you phone. It should all work now.
Cheers... Rob.
Oct 15, 2010 | Cell Phones
Pioneer PDP-427XD 42 in. Plasma Television Logo
337 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
