Question about HP DeskJet F4280 All In One Printer InkJet
My printer has a broken gear - HP DeskJet F4280 All In One Printer InkJet
  • HP Master
  • 4,737 Answers
You can get a replacement from the repairing shop/servicing center. They will replace it for you, but note that new parts isn't available in the market. If it's so then you are lucky, i've never come across any new replaceable parts for printers, except the drums, fuser and cartridges. Good luck. Thanks for using FixYa.
Posted on Jun 02, 2010
Why does it keep saying tray 1 is empty when its not?
Check the tray gears behind the try in question. With the tray removed from the printer and loaded with paper. Try to turn the rear lift drive gear. Does it lift the tray of paper?
if not check the gears closely. I suspect there broken, also look for fragments of plastic gear in the body of the printer.
if you have broken gears you might like to try shopping on the net for replacements.
Cheers,
Dave.
Feb 24, 2015 | Xerox Phaser 6600dn Color Laser Printer
I get broken gear in my hp officejet pro 8500a
Someone pulled hard on jammed paper to remove it from the printer. This has broken the small plastic paper advancing gear on the left-hand side of the printer (have seen this mistake a number of times). The printer is broken and cannot be fixed, and it is time to purchase a new one. What you and everyone needs to learn from this is to NEVER pull hard to remove paper out of your printer. Be careful, and open the access doors to get to it.
We would suggest that you upgrade to an HP 8600 series printer and if you print more than 500 pages per month you purchase an AdaptiveInk continuous ink supply system (CISS). Adaptive Ink Continuous Ink Supply System Home Page Adaptive Ink HP Pigment ERC
Mar 12, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
Hp 4L printer won't pickup paper from tray. Sequence- green led light- motor running but with grinding- no movement from pickup roller or foot- finally a misfeed led light.
That is a very common problem with the Laserjet 4L and 4P printers. The sound you hear is caused by a broken motor drive gear. This is a small plastic gear on the drive motor shaft. They can develop a small crack which prevents the motor from turning the gears for paper pickup and toner movement. When the motor tries to turn the broken gear can not turn the other gears and makes the popping or grinding sound when the gear teeth slip. You will need to replace the motor gear, it is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_49&products_id=61
I hope this helps,
BuddyMc
Jul 16, 2012 | HP Office Equipment & Supplies
Fuser open message not a broken gear
the fuser unit got a thermal fuse on need to replace. it over heat and the the power do not go throgh
Dec 02, 2011 | Brother MFC-8640D Printer
One of the heater gears ( shield ) is continuously broken several times
take out the gear which drives the broken gear then replace the broken with a new gear, check manyally driving the gear,which part or gear causing resistance in the smooth operation, replace the faulty part/gear.lubricate moving parts.
Jan 12, 2011 | Canon NP 6050 Copier
The printer says to load paper but paper is loaded already. What do I do?
hello, there are 2 good possibilites for your machine not picking up, the drive feed gear is broken, or the acuator on right side is broken. both will require machine to be serviced, now the printer engine, the mechanics, or gears only, can be swapped out from a similiar style printer engine.
Sep 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Before pulling in paper printer makes a gear slipping noise. sounds like plastic gears slipping. printer works ok otherwise
One of the gear in the roller mechanism is either displaced and not in alignment with other gear wheels OR the gear blades is broken. You have to take the assistance of technician from service center to open the printer and change the part. You can not do it your self.
Sep 15, 2010 | Office Equipment & Supplies
Lexmarkx73 Won't feed paper through while printing
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jul 13, 2008 | Lexmark X73 All-In-One InkJet Printer
ERROR E2
Here is a picture of the aforementioned broken gear, with a replacement gear visible for comparison:
From a different angle:
The printer repairman said that the plastic gear found in this and similar models can fail after as early as a few months of use. Best of luck!
May 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Printer not take paper
Look for a small piece of paper or other foreign object stuck in the paper path, or a rubber roller which has gotten slick and will no longer pick a sheet.
A broken gear in the drive mechanism, broken gear tooth, a small piece of broken plastic (from inside the printer itself), all of these can produce a problem like this.
Nov 28, 2007 | Samsung ML 1651N Laser Printer
HP DeskJet F4280 All In One Printer InkJet Logo
Seeker5211
Seeker5211
