Question about Westinghouse SK-32H240S Television
Had a thunderstorm yesterday. now set will not power on. is there an inline fuse inside case or what else can i do?
    President:
  • 1,099 Answers
Power surges or nearby lightning strikes can destroy electronic equipment. However, most of the time, damage is minimal or at least easily repaired. With a direct hit, you may not recognize what is left of it!
Ideally, electronic equipment should be unplugged (both AC line and phone line!) during electrical storms if possible. Modern TVs, VCRs, microwave ovens, and even stereo equipment is particularly susceptible to lightning and surge damage because some parts of the circuitry are always alive and therefore have a connection to the AC line. Telephones, modems, and faxes are directly connected to the phone lines. Better designs include filtering and surge suppression components built in. With a near-miss, the only thing that may happen is for the internal fuse to blow or for the microcontroller to go bonkers and just require power cycling. There is no possible protection against a direct strike. However, devices with power switches that totally break the line connection are more robust since it takes much more voltage to jump the gap in the switch than to fry electronic parts. Monitors and TVs may also have their CRTs magnetized due to the electromagnetic fields associated with a lightning strike - similar but on a smaller scale to the EMP of a nuclear detonation.
Was the TV operating or on standby at the time? If it was switched off using an actual power switch (not a logic pushbutton or the remote control), then either a component in front of the switch has blown, the surge was enough to jump the gap between the switch contacts, or it was just a coincidence (yeh, right).
If the TV was operating or on standby or has no actual power switch, then a number of parts could be fried.
TVs usually have their own internal surge protection devices like MOVs (Metal Oxide Varistors) after the fuse. So it is possible that all that is wrong is that the line fuse has blown. Remove the cover (unplug it first!) and start at the line cord. If you find a blown fuse, remove it and measure across the in-board side of fuse holder and the other (should be the neutral) side of the line. The ohmmeter reading should be fairly high - well certainly not less than 100 ohms - in at least one direction. You may need to unplug the degaussing coil to get a reasonable reading as its resistance may be 25 or 30 ohms. If the reading is really low, there are other problems. If the resistance checks out, replace the fuse and try powering the TV. There will be 3 possibilities:
It will work fine, problem solved.
It will immediately blow the fuse. This means there is at least one component shorted - possibilities include an MOV, line rectifiers, main filter cap, regulator transistor, horizontal output transistor, etc. You will need to check with your ohmmeter for shorted semiconductors. Remove any that are suspect and see of the fuse now survives (use the series light bulb to cut your losses -
It will not work properly or appear dead. This could mean there are open fusable resistors other defective parts in the power supply or elsewhere. In this case further testing will be required and at some point you may need the schematic. Hope this helps...
Posted on Jun 02, 2010
Polaroid TLA-01511C stopped working after electrical storm. Will try to change fuse, if I can get to it. How do I access the fuse? NOT equipped mentally or with tools to do more.
Contact any service technician. The fuse can be located at itw main power regulator board inside. If the power supply regulator board is found faulty, it will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
Aug 07, 2014 | Polaroid TLA-01511C 15 in. LCD Television
Yesterday my wife had the car battery replaced by the RAC and her Pioneer DEH-2050MPG unit doesn't work now and gets no power to it. I checked the car fuse for the radio and it appears to be okay
Check all of your fuses. There are probably two fuse boxes in the vehicle. There may be a fuse either inline or on the back of the radio.
Dec 25, 2012 | Car Audio & Video
Toshiba TV dead: is there a fuse inside? Toshiba 24AF46 is dead after a thunderstorm and nearby lightning. Plug sparks when I plug it into the wall. Nothing happens on the TV. No sound, nothing when I hit...
Yes,there is a fuse in inside on the tv main pcb board near the power a/c cord.But if the tv have sparks,main pcb board could have more other components fries too.If tv less 10 years repair it by a shop,more than that should buy a another tv.
Jun 09, 2011 | Toshiba 24AF46 24" TV
After a brief power outage during a thunderstorm my canon i9900 will not turn on. I left it un pluged for several hours and then repluged it and still nothing. Everything else in the office works fine.
The power supply of your printer are damage due to the brief power output during the thunderstorm. Just check the fuse inside of the power supply of the printer if they have some burned or else use the Multi Tester to identify that the fuse are damage or needed for replacement.
Jun 03, 2010 | Canon i9900 InkJet Photo Printer
Working perfectly until I put the 2nd mince pie into machine. No power so I changed fuse on plug but nothing. Has it just worn out? David
You may have an inline fuse inside microwave. You need to remove the casing of the microwave to see if there is another fuse inside (usually near the magnatron) If there is a fuse there then there's your problem, if not, then there is no use in trying to repair since the magnatron unit has possibly gone bad.
Hope this helped you
Dave
Jan 29, 2010 | Sharp R-206 800 Watts Convection /...
My cable went out during a thunderstorm. The
if it is new it should be under warranty,if not ,yes there may be a fuse inside,on the board where the plug is connected,taking it apart will void the warranty and can be dangerous .dont try this unless you have experience
Sep 21, 2009 | Televison & Video
Where is the fuse on a jet 3
There are 2 fuses on a Jet 3. The first is a 50amp fuse located right behind the foot step casing. to get to this. take the pin on the bottom of the foot step, this will expose the batteries and the 50amp fuse. The 2nd fuse is an inline fuse for the Meter on the side. that you will have to take the outer casing off around the chair. Its a 25amp inline fuse.
Jun 14, 2009 | Jet 3 Ultra Power Chair
Not getting power to ac clutch. have checked all fuses in both fuse boxes i want to know if there is an inline fuses of a relay switch from the inside switch to the power plug to ac clutch
on the suction side (low pressure) of the system there is a pressure switch that prevents the system from operating in a low freon condition. Get a set of gauges on the system to check for a low freon condition...Bypassing the pressure cutout switch could (and normally does) result in major system damage (destroys the compressor).
any questions, let me know.
clarkco
Apr 30, 2009 | Heating & Cooling
No picture
Does the set turn on i.e do you get any sound ?
There is a inline fuse inside the unit near the power pack.
Feb 01, 2008 | Televison & Video
Whirlpool GH7145XF
Check your main breaker fuse in your panel/subpanel.
Otherwise if the inline fuse is good and the main power is good, then look at the power supply for the microwave.
Mike
Nov 09, 2007 | Whirlpool GH7145XF Microwave Oven
Televison & Video Logo
649 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
