Where do find 'Browser configuration'. I am getting Error 413 message ''Entity too large'' on a website and some adice to clear it was to go into 'browseconfig' and check frst two boxes. Need to find solution as can't get back into the website.
  • Dax Estorioso
    Dax Estorioso Jun 02, 2010
    What do you use, internet explorer, firefox, or google chrome?
  • 428 Answers
Error Message: "413 – Request Entity Too Large"
Translation: The Web server has determined that the data being sent by the browser is simply too large (that is, too many bytes). This occurs when file size limits are exceeded. For example, when uploading a very large file (using a technique such as HTTP PUT), a 413 error may be returned when the Web server sees that the file size is too large.
Solution: This error is typically due to configuration or programming errors on the Web server end. It may be possible to shrink the request entity (such as uploading a smaller file). Otherwise, the Web server will need to be reconfigured to accommodate the larger entity. You should inform Webmasters of the offending sites about the trouble.
If you are using a proxy you may have to configure it to allow large packet transfers.
Posted on Jun 02, 2010
Widows7/413 request entity too large
413 errors occur when the request body is larger than the server is configured to allow.
Apr 22, 2015 | HP Computers & Internet
Internal error 502
However, it is possible that there's something wrong on your end and we'll work through those possibilities below.
  1. Try loading the URL again by pressing F5 on your keyboard, or by clicking the refresh/reload button.
    While the 502 Bad Gateway error is usually indicating a networking error outside of your control, it could be extremely temporary. Trying the page again will often be successful.
  2. Start a new browser session by closing all open browser windows and then opening a new one. Then try opening the webpage again.
    It's possible that the 502 error you received was due to an issue on your computer that occurred sometime during this use of your browser. A simple restart of the browser program itself could solve the problem.
  3. Clear your browser's cache. Outdated or corrupted files that are being stored by your browser could be causing 502 Bad Gateway issues.
    Removing those cached files and trying the page again will solve the problem if this is the cause.
  4. Delete your browser's cookies. For similar reasons as mentioned above with cached files, clearing stored cookies could fix a 502 error.
    Note: If you'd rather not clear all of your cookies, you could first try removing only those cookies related to the site you're getting the 502 error on. It's best to remove them all but it won't hurt to try the clearly applicable one(s) first.
  5. Start your browser in Safe Mode. Running a browser in Safe Mode means to run it with default settings and without add-ons or extensions, including toolbars.
    If the 502 error no longer appears when running your browser in Safe Mode, you know that some browser extension or setting is the cause of the problem. Return your browser settings to default and/or selectively disable browser extensions to find the root cause and permanently fix the problem.
    Note: A browser's Safe Mode is similar in idea to the Safe Mode in Windows but it is not the same thing. You do not need to start Windows in Safe Mode to run any browser in its particular "Safe Mode."
  6. Try another browser. Popular browsers include Firefox, Chrome, Internet Explorer, andSafari, among others.
    If an alternative browser doesn't produce a 502 Bad Gateway error, you now know that your original browser is the source of the problem. Assuming you've followed the above troubleshooting advice, now would be the time to reinstall your browser and see if that corrects the problem.
  7. Download Software Update 1 for Microsoft Forefront Threat Management Gateway (TMG) 2010 Service Pack 1 if you have MS Forefront TMG SP1 installed and receive a Error Code: 502 Proxy Error. The network logon failed. (1790) or similar message when accessing a web page.
    Important: This is not a common solution to 502 Proxy Error messages and only applies in this particular situation. Forefront TMG 2010 is a business software package and you would know if you have it installed.
  8. Restart your computer. Some temporary issues with your computer and how it's connecting to your network could be causing 502 errors, especially if you're seeing the error on more than one website. In these cases, a restart would help.
  9. Restart your networking equipment. Issues with your modem, router, switches, or other networking devices could be causing 502 Bad Gateway or other 502 errors. A simple restart of these devices could help.
    Tip: The order you turn off these devices isn't particularly important, but be sure to turn them back on from the outside in. In other words, turn on the outermost hardware on the network first (usually your modem), followed by the device it's connected to (usually your router). Next would be any switch or other device between the router and your computer.
  10. Change your DNS servers, either on your router or on your computer or device. Some Bad Gateway errors are caused by temporary issues with DNS servers.
    Note: Unless you've previously changed them, the DNS servers you have configured right now are probably the ones automatically assigned by your ISP. Fortunately, a number of other DNS servers are available for your use that you can choose from. See my Free & Public DNS Servers list for your options.
  11. Contacting the website directly might also be a good idea. Chances are, assuming they're at fault, the website administrators are already working on correcting the cause of the 502 Bad Gateway error but feel free to let them know about it.
    See my Website Contact Information page for a list of contacts for popular websites. Most websites have social networking accounts they use to help support their services. Some even have telephone and email contacts.
    Tip: If you suspect that a website is down for everyone, especially a popular one, checking Twitter for chatter about the outage is often very helpful. The best way to do this is to search for #websitedown on Twitter, as in #cnndown or #instagramdown.
  12. Contact your Internet Service Provider. If your browser, computer, and network is working, and the website reports that the page or site is working for them, the 502 Bad Gateway issue could be caused by a network issue that your ISP is responsible for.
    Tip: See How To Talk To Tech Support for tips on talking to your ISP about this problem.
  13. Come back later. At this point in your troubleshooting, the 502 Bad Gateway error message is almost certainly an issue with either your ISP or with the web site's network - one of the two parties may have even confirmed that for you if you contacted them directly.
    Either way, you're not the only one with seeing the 502 error and you'll need to wait until the problem is solved for you.
Errors Like 502 Bad Gateway
The following error messages are related to the 502 Bad Gateway error:
500 Internal Server Error ' 503 Service Unavailable ' 504 Gateway Timeout
A number of client-side HTTP status codes also exist, like the very common 404 Not Found error, among many others: List of HTTP Status Code Errors.
Aug 06, 2014 | Yahoo Computers & Internet
List of abbreviations
Here is the list of error codes for websites
100 Continue
101 Switching Protocols
200 OK
201 Created
202 Accepted
203 Non-Authoritative Information
204 No Content
205 Reset Content
206 Partial Content
300 Multiple Choices
301 Moved Permanently
302 Moved Temporarily
303 See Other
304 Not Modified
305 Use Proxy
400 Bad Request
401 Unauthorised
402 Payment Required
403 Forbidden
404 Not Found
405 Method Not Allowed
406 Not Acceptable
407 Proxy Authentication Required
408 Request Time-Out
409 Conflict
410 Gone
411 Length Required
412 Precondition Failed
413 Request Entity Too Large
414 Request-URL Too Large
415 Unsupported Media Type
500 Server Error
501 Not Implemented
502 Bad Gateway
503 Out of Resources
504 Gateway Time-Out
505 HTTP Version not supported
Oct 23, 2013 | Computers & Internet
Please describe solution of error 413 problem:
HTTP Error 413 Request entity too large
Introduction
The Web server (running the Web site) thinks that the HTTP data stream sent by the client (e.g. your Web browser or our CheckUpDown robot) was simply too large i.e. too many bytes. What constitutes 'too many bytes' depends partly upon the operation being attempted. For example a request to upload a very large file (via the HTTP PUT method) may encounter a ceiling on upload file size set by the Web server.
413 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle:
  • Obtain an IP address from the IP name of the site (the site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from the Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receive an HTTP status code that it recognises as '413'. Frank Vipond. September 2010.
Fixing 413 errors - general
This error seldom occurs in most Web traffic, particularly when the client system is a Web browser. The problem can only be resolved by examining what your client system is trying to do then discussing with your ISP why the Web server rejects the number of bytes sent by the client system.
Fixing 413 errors - CheckUpDown
This error should simply never occur on your CheckUpDown account. If it does, it typically indicates defective programming of our systems or of the Web server which manages the site. The length of the HTTP data stream we normally send is relatively small and well within the limits of what most Web servers should accept.
Please contact us (email preferred) whenever you encounter 413 errors - there is nothing you can do to sort them out. We then have to liaise with your ISP and the vendor of the Web server software to agree the exact reason for the error.
hope this helps
Mar 01, 2011 | Computers & Internet
When i wap browsing auto exiting. showin this message not enough memory
Hi hot dushan,
It seems your phone has a WAP WML browser only, and you are accessing websites that cannot parse the HTML pages to WAP WML content, e.g facebook.Such large HTML pages cannot be rendered and cached by your web browser, hence bringing up the error message. To solve your problem, install an alternate web browser for your phone. In this case, I presume that you are using a phone whose back-end is a J2ME(Java 2 Micro Edition) platform,with CLDC(Connected Limited Device Configuration) and MIDP(Mobile Information Device Profile).That can handle a good JAVA-based web browser such as Opera Mini. To install this application,please access www.operamini.com with the phone's web browser and select Opera Mini 4.2.A signed version is preferred. Opera Mini is a fully HTML-capable web-browser that can browse and access any website.With the superior front-end compression algorithms offered by the Opera Mini servers, it renders pages very fast and limits the bandwidth and data consumed, optimizing performance on slow and inconsistent networks and at the same time, saving on your carrier charges.
Feb 03, 2011 | Cell Phones
Error Message
Try to clear your private data by clicking tools in the browser then options then privacy click clear private data. Restart your computer then reintall yahoo messenger.
Oct 17, 2008 | Yahoo Messenger
N95 internet browser
hi i m using nokia n95, i have activated my NET ON PHONE service from my airtel connection and i cant download large files from gprs internet in my mobile directly. not able to download songs and the error message what i get evertime is " Entity is too large".
is there any other browser which can allow me to download larger files...?????
Sep 03, 2008 | Nokia N95 Cellular Phone
Software
check your configuration in the phone first. You can call up your provide and they can give you all the info the phone needs to talk to the provider network.
May 20, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
