-   Where do you find the convergence amps Where are the located? Can you go thru the Menu and fix this-   Guest
Apr 24, 2009
-   the red, blue, and red colors are not aligned right. they show up perfect when tv first turns on then 5minutees after that, the top and bottom of screen curve and the colors separate-   denadeb08
Mar 30, 2009
-   is convergence amps the same as convergence ic
-   Guest
Jun 17, 2008
-   contacted zenith they dont offer tech support
-   Guest
Jun 09, 2008
-   I am seeing curved red green and blue lines across my projection screen?
I have a 48" Panasonic Cinemavision set. Everything on the screen has a blue shadow from the...
(More)
I have a 48" Panasonic Cinemavision set. Everything on the screen has a blue shadow from the center of the screen over to the right hand side. The left hand side is not affected.
