Hello,\r\nMy Akai GX-635D has following problem.
Hello, My Akai GX-635D has following problem. During recording in both directions VU show normal level of recording, although when playback it is no records on right channel on forward playback and on left channel on reverse playback. I ask for your assistance.
Best regards,
Oleg
    Genius:
  • 1,040 Answers
  • pingvin39 Jun 08, 2010
    Dear Yogesh,
    Following your advise I have loaded GX-635D Service manual. What to do futher?
    Best regards,
    pingvin39
Gx 635d-recording only on one channel
This is very common due to the cheap transistors they used as well as a possible bad electrolytic cap.
Apr 06, 2014 | Audio Players & Recorders
How can I remove the pinch wheel from akai gx260d
I am no expert in Akai units but the GX-635D I was working on had a screw off cap and then there was a nut that unscrewed to get the Pinch Roller off. That is all I can say as far as help- the cap should unscrew counter clock wise.
Jan 19, 2013 | Audio Players & Recorders
I have a akai gx -635d reel to reel tape player that has stop playing where can i get it fix near me in lafayette,ala 36862
Fuses blow when there's an overload. In your case it will be a transistor perhaps in the power supply that has shorted out. It should be easy to find with an Ohm meter as it will act like you have just touched the two probes together when it's placed on the terminals of a suspect transistor.
May 08, 2012 | Audio Players & Recorders
Although I placed both ends the necessary sensing foil ,when choose auto-reverse with my Akai GX-636 RtR only the right tension arm sense the foil and blocks without reversing.When in recording mode it...
I'm pretty sure the auto-reverse is NOT supposed to work during recording. What would be the point since it only records in one direction?
And I'm pretty sure there's only one reverse sensor, usually to the left of the heads and not necessarily on a tension arm. The sensor foil is supposed to be on the non-oxide side of the tape so it will adhere better and never contact the heads.
This picture of a GX-635 shows a typical transport ...
http://www.oaktreevintage.com/web_photos/Reference_Photos/Akai_GX-365D_Front_Face_Off.jpg
There's a knob for how the auto reverse. Is it set correctly? I believe infinite forward / backward play is possible if you have the knob set properly, a sensor foil on the tape and the tape counter set to 0000 at the beginning of the recording.
May 12, 2011 | Audio Players & Recorders
NMI ISSUED PRESS ESC TO TURN OFF NMI IN IBM SERVER
dear mugkifa ,
the above error indicates , a non maskable interrupt occurred in your server , there may be a change of malfunction of a hardware ,like add on cards
one more solution in ibm server is disablig the NMI interrupt by using jumper settings (inside motherboard)
see the below mentioned details , may differ with your server series please refer with series on http://www-947.ibm.com/support/entry/portal/docdisplay?brandind=5000008&lndocid=MIGR-5069937
System-board jumpers
The following illustration shows the switches and jumpers on the system board:
migr-5069937_2.gif Note: Any jumper blocks on the system board that are not shown in the illustration are reserved. The following table describes the function of each jumper block:
Jumper Settings CMOS jumper (JP3) Pins 1 and 2: Keep CMOS data (default)
Pins 2 and 3: Clear the CMOS data, which clears the power-on password and administrator password Boot block jumper (JP4) Pins 1 and 2: Normal (default)
Pins 2 and 3: Recover boot block NMI (non-maskable interrupt) switch (SW1) Normal (default): No NMI issued
The NMI button that is on the rear of server, connected to this switch, has been pressed: NMI issued
May 07, 2010 | IBM eserver xSeries 360 8686
My AKAI GX 636 records but can't hear anything on playback (had recorded tape play on another reel to reel) plus the VU needles don't move when you try to play a recorded or pre-recorded tape
Trace the wires from the head to the amp section. Put your finger on where they join (during playback) and see if you can get a buzz. If you can't on either channel, look for something that might be common to both channels. Either a switch, or a pre-amp IC, as being the cause of the fault.
Jul 18, 2009 | Audio Players & Recorders
Unable to record with Akai GX-77
Make sure the cassett you are using has safety tab intact. Clean the heads and tape drive roller. If unit has a record level control, make sure it is set correctly
Apr 07, 2008 | Audio Players & Recorders
288 people viewed this question
 Grubhead
Grubhead
