Question about Panasonic KX-A143 Phone
Find number in menu
How can I through the menu find the latest number that called me on my phone?
How do i block a number on my alcatel one touch pixi 3
Block Calls & Messages:
  1. Open the apps drawer and launch "Contacts"
  2. Tap the name of the contact you want to block calls and messages from
  3. Tap "Edit" > "Menu" and enable "All calls to voicemail"
Unblock Calls & Messages:
  1. Launch "Contacts"
  2. Tap the contact you want to unblock
  4. Disable "All calls to voicemail"
Forward Calls (Unconditional):
  1. Tap "Phone" on the home screen
  2. Tap "Menu" > "Settings"
  3. Tap "Call settings" > "Call forwarding"
  4. Choose to "Always forward" and if necessary, enter the phone number to forward calls to
  5. Tap "Enable"
Forward Calls (Conditional Forwarding):
  1. Open the "Phone" app
  3. Go to "Call settings" and tap "Call forwarding"
  4. Select to forward calls "When busy", "When unanswered" or "When unreachable"
  5. Enter the phone number you want to forward calls to and tap "Update" or "Enable"
Turn Off Call Forwarding:
  1. Open "Phone" and tap "Menu"
  2. Tap "Settings" > "Call settings" > "Call forwarding"
  3. Select "Always forward", "When busy", "When unanswered" or "When unreachable"
  4. Tap "Disable"
Read more: http://cellphoneforums.net/general-cell-phone-forum/t381553-alcatel-onetouch-pixi-3-block-calls-messages%3B-forward-calls.html#ixzz4TXeusLlT
Dec 22, 2016 | Alcatel Cell Phones
How do i block incoming phone call from a uniden cordless phone
  1. Block an Incoming Call
    • 1 Wait until your phone rings and displays the caller ID information 2 Press the "Block" button on your handset.3 Press "Menu/Select" or "Block" to confirm your decision.Block in Standby Mode
    • Press the "MENU" button on your phone's handset.
    • 2 Press the down arrow button to select "Call Blocking." Choose "Create New," "Private Number" (block private calls) or "Unknown Number" (block unknown numbers) from the list.
    • 3 Enter the 10-digit phone number, if creating a new entry. Otherwise, press the "Menu/Select" button to confirm your choice
Oct 14, 2011 | Uniden Cordless Phone
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
Can I divert calls from this phone to another phone? Thanks MArk David
  • Figure out if your particular cell phone model has the option to forward incoming calls. You can do this by visiting your cell phone manufacturer's website or reading the manufacturer's manual that came along with the purchase.
  • Access the "Settings" menu on your cell phone and select "Phone Settings" menu.
  • Select the "Call Forwarding" option in the "Phone Settings menu. This option is usually found at the bottom of the "Phone Settings" menu. Selecting the "Call Forwarding" option gives you access to call-forwarding controls.
  • Switch on the "Call Forwarding" slider. The default position is off.
  • Insert the phone number you wish to forward your calls to in the "Forward To" field. This field most commonly lies below the "Call Forwarding" slider.
  • Exit the setup menu by pressing the home button. You may be asked to confirm/save the changed settings depending on your cell phone model.
  • Make a test phone call to the cell phone number on which you just enabled the call rerouting option. If the call is forwarded and received on the number you entered, it means that the "Call Forwarding" option has been activated.
  • Oct 08, 2010 | Panasonic Cell Phones
    How do you UNblock a blocked number
    Go to menu then initial setting then call block. Scroll to find the blocked number and choose erase. That erases it from the call block menu on your phone.
    Sep 17, 2009 | Panasonic KX-TG1033S Cordless Phone
    Retrieve the latest 10 dial out number
    It will mainly depend on the setup but usually the last 10. TO access the last 10 select the soft key menu button, down arrow on silver dial to outgoing call log. Let me know if that helps.
    May 19, 2009 | Panasonic KX-T7730 Corded Phone
    How do I find the latest phone # from which I just received a call?
    The 3rd or 4th soft key under the display has MENU underneath it. If you press it and use the Navigator button down, it will step to outgoing call log.
    Carl
    Apr 16, 2009 | Panasonic KX-T7633 Corded Phone
    Music menu
    You can hard reset the phone (factory settings)
    "power off - hold 3, green call and * - power on while holding"
    Please note this will format all the saved information stored in phone memory.
    Jun 17, 2008 | Nokia 7373 Cellular Phone
    Calls dropped
    you might try getting the latest firmware for your phone. Nokia's have a lot of bugs, and the new firmware releases sometimes contains a fix for them. Try to get the latest OFFICIAL release of your phone's firmware, hacked versions can be a real pain sometimes so be aware. I hope this helps.
    Mar 30, 2008 | Nokia N73 Cellular Phone
    Panasonic KX-A143 Phone Logo
    93 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
