Question about Hayward SAND FILTER, PRO SERIES
How do you replace the handle on the control valve pro series sa
How do you replace the handle on the control valve for the pro series sand filter
  • 8,404 Answers
Is this a push pull valve or a multi-port?
Push Pull --- there is a screw in the edge to remove that will allow you to pull the assembly from the housing.
Multi-port --- 6 screws around the ring to remove.
of course --- turn the pump off before you do anything!
I hope I have answered your question.
Posted on Jun 02, 2010
Testimonial: "thats half the answe i may have asked wrong I just want to replace the handle that changes the positions its held in with some type of pin . how does the pin come out?"
  • 1 more comment
  • A Miller Jun 03, 2010
    That is a different question or I misunderstood your original. The assembly I am talking about (on the push-pull or multi-port) is a replacable part. The handle (the part you are talking about) on the assembly ... I'm not sure about. I will have to inspect this when I get to the job. If it is, you should be able to purchase it at your pool supply.
    Thanks for the feedback ...
  • A Miller Jun 06, 2010
    I checked my filters ... my handles are integral with the operator ... no way to repair them ... yours are probably different ...
  • A Miller Jun 21, 2010
    I just looked at these comments again ... did you get your answer?
    If your valve is push-pull (goes up and down) and if you want to remove this 'lever' (wrong word ... about the right idea) from the body of the valve ... there is a pin that locks the handle in the up or the down position (filter or backwash). This pin doesn't allow you to remove the 'lever', only to lock it into position. There is a screw in the edge of the body that holds the top seal in place ... maybe two screws ... remove these screws and pull the handle ('lever') out of the body
Hayward 220T pool filter is leaking water; could it be the multi-port valve needs to be replaced?
if coming out of top where handle is yes if out backwash line yes make sure unions are tight also
Dec 30, 2013 | Hayward SAND FILTER, PRO SERIES
Drain leak
The spider gasket in the valve needs to be replaced. It is underneath the handle assembly.
Aug 26, 2013 | Hayward SAND FILTER, PRO SERIES
Do you sale the label tha goes around the valve handle ?
most of the parts for the Pro Series Hayward dial valve have been discontinued.
Aug 22, 2011 | Hayward SAND FILTER, PRO SERIES
The valve that you turn to change fil prositions the white ring under handle bnoke
Find the position where the pin that runs through the handle lines up with the slots in the valve top. Drive the pin through the handle with a punch and remove the handle then just drop a new ring in placeand replace the handle.
Aug 15, 2011 | Hayward SAND FILTER, PRO SERIES
While vacuuming my swimming pool and the valve setting is on filter, the dirty water is returning into the pool. Ive just changed a brand new spider gasket, replaced #20 silica sand. Did i miss anything...
Try changing the setting on your pool filters control valve to waste. This will bypass the filter and vacuum directly to waste. If this works, it could be a problem with the filter's "filter" setting and you may need to service or replace your control valve.
Feb 15, 2011 | Hayward SAND FILTER, PRO SERIES
Sp 704
Usually It makes no difference which way that handle goes. You didn't indicate what model valve you have. The handle turns 360 degrees. I usually lift the handle up so there is no spring tension on the valve plate, makes it much easier to get the srews in. Be sure your gasket is in proper position. Only turn valve with handle lifted, and with pump off.
Jul 12, 2010 | Hayward SAND FILTER, PRO SERIES
How do I change the sand in my Hayward S220t Top Mount Pro Series Sand Filter
un-screw the entire top valve unit. I would duct tape over the top of the riser pipe at the top.You do not want to get any sand inside that pipe. Turn upside downand rinse out completely. Add new sand remove duct tape and replace top valve unit
Jun 12, 2010 | Hayward S220t Top Mount Pro Series Sand...
Stuck multivalve head handle
that means the filter is sendind sand back to the pool if it does the filter latteral must be replace . not a easy job
Aug 18, 2009 | Hayward Pro Series 18" Above Ground Pool...
Control Valve handle wont stay in position
The valve should be about $100. We sell it for 90 something. You can rebuild them with gaskets and the spring. There should be a model number on yours, care to post it? Something like SP711, SP714, etc.
www.arrowmotor.net
May 29, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
436 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
