Question about Sony Ericsson W910i Cellular Phone
Emergency call only and no signal in globe
I experience emergency call only and no signal in globe .
No taillights park or dash lights
check park/tail fuse regarding dash ,park ,tail problem .brake light on passenger side is probably the brake globe needs replacing .Turn signals on passenger side could be globes or switch,check globes first ,if globes and fuse are ok ,may well be the switch especially if park switch and turn signals are on the same switch lever/stalk
Jan 15, 2014 | 1990 Buick Century
I have a 1974 Yamaha DT360. Everything works except directional signals. I have power to both rear flashers, no power to both fronts.
Check in back of or inside of the headlight globe to make sure that the lights have good connection and that there is power at that point. Inside the headlight globe is normally the central point for most wires to connect to one another. Check and look for any broken, corroded, or diconnected wires in and around the signals and globe. Make sure that the turn signal outer bodies have a good ground.
Jul 24, 2012 | 1974 Yamaha DT 360
Gprs setting for unli net in samsung corby2 using globe sim
I want to experience unlimited free internet in my corby2 using globe sim
Jul 17, 2012 | Globe7 Computers & Internet
1997 Ford Light Duty F-250 Problem: Passenger rear brake light / signal light Brake light is intermittent. Signal works most of the time. Emer. flasher is intermittent. Center & left side work fine....
It appears that you may have an intermittent earth connection between the globe sockets and the vehicle body.
First, check how well the metal base of the globe fits into the socket. If it is a bit loose remove the globe, squeeze the sides of the metal socket with some pliers so that the globe fits snugly in the socket. If it is still not working correctly, check the earth wire that runs from the globe socket and any connectors in the wiring loom near the Light Assembly as well as where the earth wire is attached to the body. Remove, clean and re-attach securely if necessary.
Sep 14, 2010 | Ford F-250 Cars & Trucks
My brake lights won't work in my AU Ford Falcon
On vehicles that use a common bulb for signal and brake lights the brake light circuit runs through the signal switch. A problem in the signal switch can cause the brake lights not to function. Also check your Emergency flasher switch. Hope this helps.
Apr 11, 2010 | Ford F Cars & Trucks
A wrong pin code was entered trice and blocked the pin code. how can i get the puk code from globe telecom. pls help, i had that sim for 5 years
If you no longer have the PUK code that came form the pack when you purchased your sim, then the only thing you can do it to go to the nearest Globe Telecom Office near you.
I was able to experience your problem with both Globe and Smart. Globe is more willing to assist, tho.
Goodluck and hope you can rate my solution. :)
Aug 01, 2009 | Nokia N95 Cellular Phone
Replacement of Light globe in Ice Dispenser
USE LESS THAN 5W GLOBE IF AVAILABLE
OR
7 W IS A STANDARD GLOBE BEING NORMALLY USED, WILL & SHOULD NOT AFFECT THE POWER CIRCUIT AS PER MY EXPERIENCE
BEST WISHES
Dec 12, 2007 | Refrigerators
No signal...
reset ur ohone than try
Nov 12, 2007 | Sony Ericsson T637
Sony Ericsson W910i Cellular Phone Logo
454 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
