Question about HP Pavilion dv9000z Notebook
Why won;t my laptop power up
Why won't my hp laptop power up. somtimes it turns on then off. sometimes the power stays on for a while, but the screen is black. what is wrong?
    Scholar:
  • 58 Answers
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the following steps.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check if the notebook works fine or not. However, if the notebook turns on and if the display stays blank then connect an external monitor to the notebook and check for the display on it.
Step 2: External Monitor
You can follow the steps below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook.
Incase, if the notebook does not turn on at all then the issue is due to internal hardware malfunction. In all the cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your notebook is under HP warranty, then I suggest you to contact HP support to get the notebook repaired under warranty.
Posted on Jun 02, 2010
    Scholar:
  • 88 Answers
Also you may want to consider checking your Internal fan. Just put your hand near the vent usualy on the side or back of your computer and keep it there when you turn the computer on untill you feal the hot air blowing if you feal nothing for 5 min then you need to replace your fan. This will usualy caus your computer to shut down due to heat damage control when your cpu reaches a certian temp it will shut off. There are to many things to lists with the symptoms you are having but that is the most likely one
Posted on Jun 03, 2010
Hp 2000 363nr Powers on with a blank screen and then turns off almost immediately
Try cleaning the laptop out. Use a vacuum cleaner on the exhaust vent on the bottom of the laptop.
May 27, 2013 | HP 2000-363nr 15.6" Inch 2.4gI3-370m 4gb...
Load screen won't go away
are you saying that when you first turn on your computer it stays on the very first screen.... (just for an example pretend you have an HP... does it just stay on the screen that says hp?)
Apr 16, 2013 | Computers & Internet
Screen won't turn on/Power stays on
To do a power reset, unplug your laptop, remove the battery and hold the power switch down for 30 seconds.
otherwise it may be problem with your screen back light...
Apr 10, 2013 | HP G60-535 Laptop Notebook Netbook...
I have a hp netbook laptop and it was working earlier but when I opened it it flashed my login screen and shut off and I can't get it back on and when I press the turn on button the charging button...
Remove the main battery and press power, sometimes this will solve the problem. If not, remove one stick of ram and power on, if not remove the second one and replace the first and try again. If no result it is probably a motherboard issue.
Mar 10, 2012 | HP Computers & Internet
My HP G60-235DX notebook worked fine.I tried to turn it on the next day and it won't power up.The indicator light turns on but stays red and the screen stay black and windows won't start.Sometimes If I...
Try removing the battery and the power cable for about 30-40 min and then plug it back in. If that doesn't work try contacting HP. I had a similar issue with a Toshiba replaced the HDD and after that it was fine. So I would say try those, if all else fails post on www.techsupportforum.com.
Jul 11, 2010 | HP G60-235DX Notebook
My HP Pavilion won;t str up. I turn it on. I then
If the system turn on and off and again on automatically, sometimes the problem is in GMCH. ie in the graphic chip. There are other reasons also. You have nothing to do unless you are a chip level technician. Contact me if you are. Make a reply for this because I will get satisfaction by it.
Apr 19, 2010 | HP Pavilion dv4000 Notebook
Laptop screen goes dark.
Is your computer setup to go to sleep when you close the lid?
Click on start -->control panel-->power options and then check the option that says choose what closing the lid does. You have to change this setting to 'do nothing' if you want the computer to stay on when you close the lid.
May 19, 2009 | HP Compaq Presario C700T
Acer 5634 laptop screen occasionally turns pink!
You have broken wire that connect screen to the motherboard, when moving screen it connect somtime and sometimes disconnect. It about 18pin wire but only one is broken.
Jan 12, 2009 | Acer Aspire 5630 Notebook
HP Pavilion dv9000z Notebook Logo
603 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
