Question about Panasonic KX-TG5632 Phone
Panasonic Phones are on mute and will not work
I have a phone set KX -TGA560B with three portable phones and a base station -- one of the units uses the base station as a station. All of the lines are muted and we cannot get them off mute. The phone line is still active as we can make calls using a old had set. You can dial but it will not ring through to a cell phone. I cannot locate an operating manual.
  • Anonymous Aug 08, 2008
    phones on mute. will dial no ring
  • Panasonic Master
  • 1,689 Answers
The following is generic for most cordless phones:
Did you check to make sure that the phone is not in the intercom mode? If this phone has a base station speaker phone, make sure it is not on mute. Some of these phones have a fax connection. Make sure your phone line is not accidently pluged in to the fax section. Also if the phone has a fax monitoring feature check the the setup menu that the fax is not enabled. If the phone has an answering machine mode, make sure that this feature is turned off.
In the worse case:
There may be a defect in the X-Mit section of the phone. I would suspect the fault to be in the base.
Jerry G.
Posted on Apr 13, 2008
How to open battery opening on Panasonic KX TGA560b
Look at the back of the KX-TGA560B handset. You should see a notch. Press down firmly on the notch on the battery cover side and slide the cover towards the bottom of the handset.
This is shown on page 3 in the handset manual which is available on the product page: . The direct link to the manual is .
I hope this helps.
Sep 25, 2017 | Panasonic Lands Phones
I have a KX-TG6700 base station and 4 Handsets. When I have been calling on the handsets I have recently found that there is static on the line. Later I realized that there is problem with the DTMF being...
The KX-TG6700 manual at:
For best performance
Base unit location/avoiding noise
The base unit and other compatible
Panasonic units use radio waves to
communicate with each other.
For maximum distance and noise-free
operation, we recommend the following:
LPlacing the product away from electrical
LPlacing the base unit in a HIGH and
CENTRAL location with no obstructions
such as walls.
LRaising the antennas vertically.
LIf you use the handset near a microwave
oven which is being used, noise may be
heard. Move away from the microwave
oven and closer to the base unit.
LIf you use the handset near another
cordless phone’s base unit, noise may
be heard. Move away from the other
cordless phone’s base unit and closer to
your base unit.
Have you considered all these points?
Is there a way you can move the base station to another location in your house to see if the problem get better? I don't beleive your base station is faulty, I suspect interference from something.
I don't think the 2.4GHz set is causing any issues, but you never know, try unplugged it for a while to investigate.
If you do determine that the base station is faulty there probably isn't many options to get it repair other than sending it to Panasonic. May be cheaper to buy a new base station to go with your extra handsets.
Good Luck!
Mar 14, 2008 | Lands Phones
Changing from pulse to tone panasonic phone
Touch the following keys: Menu 0 5 1 and then select 1 (tone, the factory default) or 2. Then Save (a softkey with the label in the LCD screen) and Off (opposite Talk on the keypad).
The manual for the Panasonic KX-TG5664 is available from Panasonic here: . See page 17 for setting the Dialing mode.
I hope this helps.
Apr 06, 2013 | Panasonic Lands Phones
Display not showing on 3 0f the 4 phones model PANASONIC KX-TGA560B
Display not showing on one hand set phones Model Panasonic KT-TGA560CM
Jul 27, 2011 | Panasonic KX-TGA560B 5.8 GHz Cordless...
Panasonic KX-TGA711E
this sounds like you are either out of range of the base unit or your base station isnt plugged into the mains, ensure you have the base station plugged into the power and the phone line from the wall socket is plugged in, the base station controls all the handsets, if it isnt plugged in they wont work, good luck
Aug 05, 2009 | Panasonic KX-TG1033S Cordless Phone
I purchase the Panasonic KX-TGA560B and I am having problems.
Hello amalia,
I think what happened is just software crush .. anyway, please contact Panasonic costumer-care Click Here or visit nearest Panasonic Service Center, you can know where is that by clicking here
Thank you for using FixYa.
Apr 11, 2009 | Panasonic KX-TGA560B 5.8 GHz Cordless...
Need to clear out a used kx-tga270s handset
press function, initial setting, registration, deregistration, enter 335(deL) and then press Ok (right button on screen).
Once that is done press mute on the base unit and Ok on the hanset (right button on sreen)
Mar 28, 2009 | Panasonic KX TGA270S Cordless Expansion...
No KX-TGA101S communication with KX-TG1033S
The additional handsets must be registered to the base unit. Here are the instructions from the manual:
1. [menu}
2. "handset settings" - OK
3. "Registration" - OK
4 "HS registration" - OK
Press and hold [LOCATOR] until the registration tone sounds.
-if all registered handsets start ringing, press {LOCATOR] to stop, then repeat this step.
-after the base unit beeps, the rest of the procedure must be completed within 1 minute and 30 seconds.
Press [OK], then wait until a beep sounds and Y stops flashing.
Jan 31, 2009 | Panasonic KX-TGA101S Cordless Handset
Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Oct 18, 2007 | Panasonic KX-TG2740 Cordless Phone
Panasonic KX-TG5632 Phone Logo
395 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
