Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
Monitor light blinks no picture - Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
    President:
  • 1,138 Answers
(Please be advise that if you don't have the knowledge, the proper skills and the right tools to open the back cover of your monitor and replace its part...don't risk it...
Otherwise, bring your unit to a credible technician and avail of warranty if there is any.....) If you have guts.. then do the following steps..
You said your monitor will blink but no picture display... well, there are possible reasons why this problem occur..
1. Open the back cover of your monitor..Check the power supply section for possible loose connections and blown capacitors.. Resolder any loose terminal connection on the pcb. Check for any blown capacitor, replace the capacitor with exact value, and also replace any bulging capacitor..If you have successfully replace the parts you can try to turn it on and connect the vga cable in it to the video card of your computer. Turn on also the cpu, if the monitor led turn green and the display came out..that fixed it.
2. In case you have successfully repaired the power supply section and the led of the monitor stays green.. then the problem will be in the inverter board section....Turn off your monitor... open the back cover...on the inverter board section.. check and replaced burnt or overheating high voltage transformer..if one or more of this overheats, it is enough to affect the supply current from the power supply section and that may cause to blow your capacitor...If the ballast transformer is working fine the last thing to check is the backlight inverter (the light that illuminate causing display in your monitor) Replace any busted lamp.. that should fix the black screen on your monitor. ..
If you find this information very useful..please be kind to rate this solution and vote for this on the help below...thanks..
Much appreciated if you rate this help...thanks...
Posted on Jun 02, 2010
Black screen and blinking blue light
blinking blue lights means the monitor is stand by.for the black screen
you should check your cabels from monitor to computer.they should be seated tight.if still no picture your videocard is proberly brooken.
it should be point out at LCD-monitors are fragile.
Apr 20, 2013 | Samsung SyncMaster S22B150N - LED monitor...
Slim and secure blinking green light
Same problem here... Blinking green light. Purchased new battery and is still doing the same thing. Very disappointed-these cameras are not cheap. :(
Mar 10, 2012 | Summer Infant Slim Secure Handheld Video...
(montior)on light is blinking on and off NO picture
You can look at my pictures to see what is usually wrong with your DELL monitor:
http://s807.photobucket.com/home/budm/allalbums
Most of the time are due to bad caps, bad soldering works, shorted transisotrs, etc.
Replacement board: www.lcdrepair.us
May 19, 2010 | Dell E153FP 15" LCD Monitor
Power light blinks on and off and screen is black no picture
good day, you may have a faulty monitor or a faulty videocard, have this checked. hope this helps, have a nice day
Feb 10, 2010 | Envision EN7410 17" LCD Monitor
Power light blinks red, green and off. No picture
Is there another monitor input on the back of you computer? Sometimes this happens when your graphics card is not compatible so it is best to try another one. If you have another one plug it in there first. If you don't try the monitor on a friends computer. If it still does the same thing, it may be a manufacturer defect and may need repair.
Nov 06, 2009 | Planar PL1911M-BK (Black) 19" LCD Monitor
No picture on monitor - green power light blinking
There's an internal electronic part/s of your monitor that is cold soldered / defective. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 28, 2009 | NEC MultiSync 75 17 in.CRT Conventional...
Why f257 turns on no picture light blinking?
Sounds like you have a video card issues..Also try turning off Monitor first, then shutdown PC. Then Turn monitor back on first then PC..It should sync up...
May 18, 2009 | Computers & Internet
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Mag Innovision 765S power supply light blinks and monitor power led blinks and no picture
I'd suggest looking at the mainboard. I assume the blink is rapid? A slow on, followed by a short off and back on again is normal. The fast blink thing is a mainboard issue, and the absence of blink (or light) is power "supply dead."
There is a problem transistor on the mainboard that seems to be the problem most of the time. Replacing it takes about 5 minutes if you have the tools and the talent, and the parts cost under 3 bucks at Radio Shack. Just pick up a pack of NPN switching transistors and de-solder / solder your way to a working monitor. There's usually only one on the board, so it's easy to spot.
Nov 18, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
464 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
