Question about Car Audio & Video
The battery on my car recently went flat, it's a 2000 Mazda 323 Astina. I need to recode the stereo, I didn't have the code from the previous owner so was silly enough to try and guess it not knowing that I would be locked out and now it displays 'err' and apparently only a Mazda dealer can fix it, which I know will cost a ridiculous amount. Can you help at all? I found a few solutions online but not for my model, they say you need to have a 'preset 6' key, my present keys only go up to 5. Cheers Sophie
  • Car Audio & ... Master
  • 4,944 Answers
Main Dealer or Decoding Service only for this code...Sorry !
Posted on Jun 02, 2010
Cannot find spark plugs in 2003 323 1.8 litre mazda astina
If you follow the wires to the top of the engine from the distributor, they are under the boots when you remove them. Plugs are about 4-6" down inside. f2c5d262-e131-42d7-8496-0946d38b78c6.jpg
Apr 20, 2014 | 2003 Mazda 323
Mazda v6 timing marks astina 1994
There should be little groves on the crank pully 4 or 5 marks
Nov 09, 2013 | 1989 Mazda 323
My 1994 mazda 323 astina automatic revvs high and low. what's the problem
When does is rev high and low? If it does this at idle check for a vacuum leak or maybe a blocked airflow
Jan 12, 2013 | 1994 Mazda 323
2000 model mazda 323 astina cylinder head bolt torque specs
Three stages with new bolts (a must), 1st 60 pounds, then 70 pounds then final torque is 80 FT Pounds.
Feb 16, 2012 | Mazda 323 Cars & Trucks
Can u tell me please where to locate fuel pump relay mazda astina 323 1997
It may be the circuit relay #21 in the battery junction box. See diagram below. Let me know if you have more questions.
Nov 07, 2010 | 1994 Mazda 323
Mazda demio airbag light flashing 2 x slow 6 xfast believe this is code 26 what does this signify and how can we recode please. the car is 2003 1,5 gsi uk spec
Hi
Code 26 is the clockspring under the centre of the steering wheel, you may have problems with your cruise control and horn as well. It will most prob need replacing, could be a diy job but bear in mind the previous threads caution.
Oct 30, 2009 | 1994 Mazda 323
Battery for 1997 Mazda 323 Astina 5dr hatch
It's fine to use a battery with a higher cold crank rating than original. Consider the rating in the manual to be a minimum requirement. You'll be fine as long as the physical dimensions and terminal placement are compatible with your car. The battery manufacturer's guide should tell you which battery fits your car.
Mar 03, 2009 | 1994 Mazda 323
1989 mazda astina 323 5 spd manual clutch fluid??
open your bonnet check to see @ gearbox if the-res is cable, or a cylinder, the cable is Usualy visible on the top of the gearbox if theres a cable theres no clutch flu-ed needed. Note that your gearbox uses oil. Usualy on older models like 1989 the use a clutch cable no flu-ed needed
Jan 03, 2009 | 1989 Mazda 323
Car Audio & Video Logo
104 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
