Question about Mitsubishi P-91W Printer
I am looking for a Mitsubichi thermal printhead, product number: N128-8E-SH (or N128-BE(?)). This is a print head of CTG unit. Where could I by this item? How much? Thanks in advance Attila Benkovics
I am seeking for Mitsubishi Monochrome Printer Model no. P-91W thermal head as the printing is having one white line
Posted on Dec 20, 2010
  • etgonza Jan 11, 2011
    You must pull out of all unit from Equipment that is installed, and them you must open all desk (loose four screw) clean with air, and them get ou all paper and clean with alcohol and cotton all parts of this unit where the paper run
Print head not showing blue or green in photo, new color cartridge in place same results. All photo have just a red to pink color. question would this be a print head problem?
To clean the printhead:
  1. Press Home on the printer control panel.
  2. Press the down arrow button until Maintenance is selected, then press OK.
  3. Press the down arrow until Clean Printhead is selected, then press OK.
http://support.en.kodak.com/app/answers/detail/a_id/1459/~/cleaning-printhead-on-all-in-one-printer
If you want, you could try cleaning the printhead. Follow these directions to remove the printhead: http://support.en.kodak.com/app/answers/detail/a_id/1153/~/installing%2Freplacing-printhead-in-esp-or-hero-all-in-one-printer. Then try soaking the printhead in rubbing alcohol. After it dries, put it back in and see if it helped.
If that doesn't work, consider buying a new printhead. It looks like they're only $10:
http://www.kodak.com/ek/US/en/Consumer_Products/Products/Replacement_Parts/10_Series_Printhead.htm
Aug 02, 2015 | Kodak Esp 5210 Inkjet All-in-one...
There are long axis print voids. Does the print head need to be replaced?
Before replacing your printhead, try cleaning the printer, run the cleaning card and also clean the printhead using the alcohol saturated swab, zebra part number 105909-169. In some cases that will fix your issue, if not your printhead needs to be replaced. If replacing your printhead, please make sure your card stock are clean and don't have sharp edges as that could be the cause for a scratched/burned pixel on the printhead.
-- The Pros at www.DiscountIDStore.com
Sep 22, 2011 | Zebra Eltron P310 Thermal Printer
Same one as everyone else apparently-i purchased the kodak aio 5300 three years ago and have had nothing but trouble with it. I had to order another printhead right from the start after spending hours on...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 23, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
I looking Print head for Brady Model 1344 please find to me .
The Brady 1344 printer is really a Datamax E4304 printer with 300dpi print head. A google search will produce numerous companies selling this printhead
Hope this helps
May 15, 2011 | Brady 1344 Thermal Label Printer
High, I have a Schiller AT-2 light that is printing too lightly suddenly. Hard to read the lower page tracing in particular. Had it 5 years, doing well. Anything to adjust that?
hi,
Your machines thermal printing head have some problem. Thats why it give printouts very light. Not possible to repair thermal head. You have to replace it.
ok
Feb 15, 2011 | Schiller Cardiovit At 2 Light Ecg Machine
I put new ink cartridges both black & color and it does not print. It goes through the motions but a blank page with barely anything shows.
You can look at this webpage for info on the printhead. I expect the print head(s) are blocked. This happens if the unit is unused for a long time or the unit is allowed to run out of ink. This is NOT a thermal printer.
I think you will need ALL new print heads.
Apr 04, 2010 | HP OfficeJet 7110 All-In-One Thermal...
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
What does the third light from the left indicate? I have no manual and can't print one to find out. The blinking just started and now printer will not print at all in any mode.
From the left - Light 1 is ink cartridge, (color indicates which ink) Light 2 is Print head, light 3 is configuration, 4 is cancel, 5 is resume , 6 is power.
Probably it's out of yellow ink.
Here's the HP page for your printer : http://h10025.www1.hp.com/ewfrf/wc/product?product=2511753&lc=en&cc=ca&dlc=en&submit.y=0&submit.x=0&lang=en&cc=ca
The manual is here : http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=ca&lang=en&product=2511753&
Oct 25, 2009 | HP OfficeJet Pro K5400dn Photo Printer
Printer not recognising dpi of new printhead
You have installed the wrong printhead. Check the part number of your original printhead, it was probably a 300 DPI )Dots Per Inch). The image will be stretched at a ratio of 2:3. It will print, I did it the other way around installed a 300DPI in a 200DPI printer. Image shrunk but printer appeared to work.
Apr 11, 2009 | Zebra 110XiIIIplus Direct Thermal/Thermal...
Labels enlarged
if they are diferent resolutions, ex. you change from 200 dpi to 300 dpi, you need to change something inside the printer like the gears (just reversing the platten roller gear and the the withe gera on the motor) and you are printing on 300 dpi with very small fontes.
Mar 11, 2008 | Zebra Z4Mplus Label Printer
Mitsubishi P-91W Printer Logo
269 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Martin Murray
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
