Question about Brother Fax-1360 Plain Paper Inkjet Fax
Every time a fax wants to come through there is a clicking noise and then the paper jams immediately in the rollers
  • 47 Answers
Sounds like you need a fixer, could get expensive
Posted on Jun 02, 2010
Why is my fax machine jamming all the time
Dear
If paper jam always,check the thermal ribbon correctly installed (the ink coating face upward and should above the print head)
If document jam always, check the ADF roller (white roller clean it)
Thanks.
Feb 26, 2015 | Panasonic KX FP215 - Fax / copier - B/W -...
I have just replaced all the toner cartridges in my fax and it did a self clean. The machine was making these noises which sounded like the roller was getting stuck. It would then come up with a paper...
Open control panel on your personal computer where the printer is installed. Click the printer and faxes. Then right click on the icon of your printer and click properties. Then click the maintenance Click the Bottom Plate Cleaning. If the noise is still there after you clean the bottom Plate. Clean the Roller. And look inside your printer if there is something that blocking the roller.
Jun 24, 2011 | Brother IntelliFax-1860C Plain Paper...
Paper jam
Sir/Mam
The problem mite be dirty rollers that feed the paper, try cleaning with alcohol or worn out replace. Problem is the paper roller is miss feeding not taking up the paper instead of hitting something in the machine paper jam.
Apr 18, 2010 | HP 1010 Plain Paper Inkjet Fax
Constantly getting paper jams
where the paper comes out there is a rubber roller that roller must be cleaned to get to that roller open the back cover then you will see the fuser cover that cover just drops down then you will see a white plastic remove that plastic by removing two screws at each side of the white plastic you do not have to open the rear part completely that white plastic sould come out if you wiggle it a bit you will have to take it out one side at a time then when that white plastic is removed you will see the rubber roller just clean that roller with benzine or alcohol. The machine gives you paperjams because that roller gets sticky over time.
Oct 29, 2009 | Brother IntelliFax-2820 Laser Fax
I keep getting intermittent paper jams in the back. Not every time, just occasionally. Nothing can be stuck or jammed because I keep getting good copies too.
if you have used the fax a lot or have used a cheaper quality paper the rubber feed rollers are slipping.
Open the unit up and use a bit of isopropyl alcohol on a paper towl and rub or clean the roller. Let dry and close it up again. That usually will clean enough to make it work again. If not the roller may need to be replaced.
Jul 22, 2009 | Brother IntelliFAX 2920 Plain Paper Laser...
Paper jam in fuser
Sounds like a timing jam, check paper supply, fanned, good quality, check and clean paper feed rollers.
Registration rollers clean?
If you are a tech, check and clean paper feed clutches, registration clutch. Check fuser for bearings, fuser drive, fuser roller cleaner or worn rollers.
Check exit sensor, is it out of place, is the actuator worn out, is the paper curling and coming off of the paper too early,
Try these, hope it is of some help.
Ed
Apr 23, 2009 | Office Equipment & Supplies
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Fax Machine keeps jamming
Depending on where the jam is, it could be the rollers at the exit. I have found that these rollers become sticky and cause intermitted jams. I suggest using methylated spirits to clean the black rollers where the paper would come out. You might have a few problems getting to them from the front so I would open up the back and see if you can get to them from there and clean the little grey rollers while you are there wont do any harm. :)
Careful you don't pop the black rollers out of position or you will get constant jams.
:) Good Luck
Dec 08, 2008 | Brother IntelliFax-2820 Laser Fax
Major Paper Jam
The paper is jammed around the fuser roller, you will have to remove the fuser and clean the mess.
Dec 07, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Fax Jam
hp tells me to do the following
does this help you ?
Issue While printing, copying, or receiving a fax, a paper jam occurs. If the jammed paper is removed incorrectly, other problems may occur. Clearing paper jams Remove the jammed paper by following the steps below: WARNING: Jammed paper must be removed using the rear access door to avoid mechanical damage. Do not remove jammed paper from the front of the all-in-one.
  1. Turn off the HP product and turn it so the back of the all-in-one faces you.
  2. Disconnect the power cord from the back of the all-in-one. CAUTION: The power cord must be disconnected to allow the paper feed rollers to turn freely and avoid mechanical damage.
  3. Locate and open the rear access door by pressing in on the left side tab to release the catches and then pulling the door toward you. Figure 1: Removing the rear access door c00100775.jpg
  4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  5. From the rear access door opening, remove the jammed paper.
  6. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  7. Reinstall the rear access door.
  8. Reconnect the power cord and turn on the all-in-one.
Preventing paper jams The following information will help prevent paper jams from occurring:
  • Never use paper that is wrinkled or damaged in any way.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with fresh paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door isn't locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with clean water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
richard from chicago
Dec 02, 2007 | HP Officejet 5510 All-In-One Thermal...
Brother Fax-1360 Plain Paper Inkjet Fax Logo
63 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
