Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Hi. Everytime we use a new toner cartridge in our UF590, it works for so long and then has a paper jam evertime it tries to print a fax.
  • 1,219 Answers
When did you replace the toner crg?
It may be that drum isnt turning, and when paper comes to the drum it jams.
New crg should resolve the problem.
But you also want to check the pick up, feed and separation rollers.
Posted on Jun 02, 2010
Our printer is not picking up the paper from the tray and is saying it is jammed. There is not jam.
Hi there !
Is your printer had jammed before and it stop printing in the middle of printing? For some reasons, paper can jammed due to printing interruptions, printer turn off, improper loading or feeding of paper, roller feeder had problem and others.
If jams before and paper have let inside the printer, please do the following first:
1. Check th paper tray, see inside if the paper is jammed inside that compartment. If there is paper jammed, remove, turn off your printer and turn on. This will solve your problem.
2. If not, open the printer cartridge door, remove the toner cartridge and look for paper jammed inside. If these is paper inside, remove it, turn off the printer and turn it on.
3. If you cannot see the paper jammed inside, the paper maybe inside the heating area. To remove paper, just turn off your printer and turn it on to roll over the paper jammed inside of it.
4. If the printer is blinking and saying there is paper jammed. You have to check the cartridge toner by opening the cartridge door, remove the cartridge and return it back but be sure it is well firmly fitted.
If following the 4 diagnostic procedure and you cannot locate the jammed paper, the problem lies on the toner cartridge itself. When toner cartridge is not rolling over, it will stop feeding the paper and it will cause printer to jammed.
To diagnose the problem, put old printer cartridge and if no toner power, just shake it well and I am sure there is still small amount of powder inside it and if it prints, the toner cartridge you purchase is defective. Reason, factory defect or improper refilling and part is not working well.
I hope it is helpful and thank you for using FixYa !
Jan 06, 2011 | HP LaserJet P3005n Printer
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
My Canon Laser Class 710 fax machine is flashing a red error and the message states ''received in memory'' .. How do I clear it?
You could be out of toner = new toner cartridge.
You could be out of paper = reload paper
You could have a printer problem, paper jam, door open, etc
get the printer part working.
does it print a report if you press the 'report' key?
Nov 13, 2009 | Canon Office Equipment & Supplies
Leaking toner all over paper and you can't read the information that is printing and alot of paper jams.
Remove the cartridge as it is faulty. Clean or vacuum the area under the cartridge (with the machine switched offf please) and fit a new cartridge.
Jul 09, 2009 | Brother MFC-7220 Plain Paper Laser Fax
ERROR CODE #021
Try a new toner cartridge. If that doesn't take care of the problem, it's the fuser.
Apr 08, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Canon Fax L100 - toner required even though not empty
hi
first do use the original toner if no use the original toner if yes check the toner cartridge may could be brocken ore the toner jammed on it if its ok you have to check the toner sensor that located in side the fax m/c under the toner cartridge may its came out of position .
thanks
May 19, 2008 | Canon FAX L-120 Plain Paper Laser
Paper not feeding
If there is no paper jammed inside the machine, then look at the "paper out" roller, this is the last roller in the paper path. I would suspect it is out of alignment.
May 11, 2008 | Brother IntelliFAX 2800 Laser Fax
Samsung SF560 error message door open & jam, no toner.
I have put a new toner in and it says "[jam 1] or no cartridge" please help this is an office fax and desperately needs to be working.
Many thanks,
Adrian.
Apr 15, 2008 | Samsung SF-560 Plain Paper Laser Fax
Paper Jams
Try changing out the toner cartridge if cleaning rollers didn't work.
Jan 07, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Samsung SF5100 has a loud buzzing noise
Hi there you might have a faulty toner cartridge is it a original or has it been refilled? I suggest to install a new toner cartridge and hopefully that will cure the fault. If this dosen't there maybe a small piece of paper stuck in the cartridge or after the toner cartridge within the heat section open the back of the machine (the jam door) and check there is no paper.
If the printed document is getting stuck just after the toner cartridge it will most likely to be the heat section will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 31, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
77 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
