Question about Sanyo DVP-P1 Thermal Photo Printer
Printer i need to buy the ink ribbons for this printer where do it get it from? i can't find it anywhere online.
  • 123 Answers
Http://www.rmdirect.co.uk/catalog/product_info.php?products_id=270
You will be able to buy refills here.
Hope this helps.
Good Luck.
Posted on Apr 09, 2008
I need to know why the receipt is very light when printed
If it is an ink printer, the ink ribbon or roller is probably running out of ink. Buy a new roller or ribbon and try it.
If it is a thermal printer, the paper rolls may be low grade. Try buying thicker high grade paper rolls. If that doesn't work, the print head in the printer probably needs replacing.
Check your manual to see which type you have. If you need a manual, try these guys https://the-checkout-tech.com/cashregisters.php
Jun 08, 2017 | Retail Supplies
I cannot find anywhere to buy ink for my kodak easyshare cx7525 printer
http://computers.pricegrabber.co.uk/ink-toner/kodak+easyshare+cx7525/p/370/
Dec 06, 2012 | Office Equipment & Supplies
INK IS RUNNING OFF OF THE RIBBON AND DRIPPING TO THE BOTTOM OF UNIT. RIBBON NUMBER IS DKF-9000 WE WENT THRU 3 RIBBONS IN 1 MONTH. I THINK ITS SOMETHING IN THE RIBBON TENSION.
The Problem you are having is due to re-inked or remain ribbons. You need to use OEM Printronix Ribbons, I have new in stock if needed part# 107675-001 they come in a 6 pack. 708-597-4222 Rory
Aug 04, 2011 | IBM 6400 Matrix Printer
Black Ink Only Driver Download for Epson Stylus C63?
You can't because NO-ONE has ever, nor will ever write one, the printer companies would probably literally kill anyone that did it, printer ink is more valuable than uranium, that's how they make their money... they want you to have to buy color tanks to print even when you only want need black, it is all a conspiracy..lol. Seriously if you only want black you have to get a single tank black only printer..
Feb 18, 2010 | Epson Stylus C63 InkJet Printer
How to replace a print head on a T2265 sprint pro
Tally Genicom T 2265 Printer print head. The following information regarding Print Head is taken from Website. Please go through carefully. Print heads are very sensitive from the type of ribbons you use. These textile tapes, used as consumable in dot matrix printers are made by special technologies. They are impregnated with ink and special oils, which lubricate the print head wires during printing. While print head works, the quantity of ink and lubricant in ribbon exhausts, and the quality of printed matter gradually declines. When this quantity goes down below certain limits the ribbon begins wear to threads. These fine textile fibers mix with cellulose filaments from the paper and form a dark gray dust. This is a sure sign that the ribbon is dangerously worn and must be changed with a new one. Otherwise you will soon need a print head repair service. Still not satisfied about those points, please get in touch with local authorized printer service engineer to set right the issue. Have a Nice Day The same problems you may have with "old" ribbons, because after time the lubricants and inks get dry. The usage of "worn" or "dry" ribbon leads to difficult movement of the printhead's wires, its quick wear or crush. If you wish to use your printhead for a long time without any problems, you must use a quality ribbons with an original guarantee. Never use re-inked old ribbons. This surely guides you to print head repair or to buy a new one. It is a good idea to read the User's Guide for your printer, if you have not already done so. If you don't succeed in finding it, then carefully look at your printer and try to find the lever for printhead positioning, it controls the printhead gap. You must adjust manually this gap in correspondence with the number of printed copies.
Jul 15, 2009 | Office Equipment & Supplies
Anyone knows where to buy a cartridge carrier?
Here is a link to the user guide for your printer:
Lexmark 3500/4500 Guide
The installation of ink cartridges begins on page 70.
Thanks for using Fixya.
A Fixya rating would be appreciated.
Feb 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Can't find ink replacements for 5300 kodak
Yes it will work. However, the quality of the print will go down. I have used recycled cartridges in the past and the print can smear - But it is a solution to your problem.
Jan 27, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Print quality is very poor
I used to use an LX300 and have never had this problem. I'm not sure what unclear means so I will just do some guessing. Clarity of the print depends on 3 things, software, printhead and ribbon. These are your problem areas. Epson has an option to print NLQ or near letter quality. So that should give more clarify. I basically double prints the same letter to create a darker image. The printhead, if your printer is really old, you need to either find someone to refurbish the printhead or buy a new printhead because it could be the impact pins are bent and not giving the strongest image. Lastly the ribbon, obvsiously the more used the ribbon is the weaker the image. So either re-ink the ribbon or buy a new ribbon cartridge. Hope this helps.
Aug 05, 2008 | Epson Dot Matrix LX-300+ II Printer
I purchased a BJC-85 color bubble jet printer in 2002. I have lost my disc to set up printer; I just received a new labtop for work and I dont want to buy another printer. Is there anyway you can take my...
The drivers that were on the CD probably won't work on your new laptop anyway. You can download the latest drivers here (use the box to select your Operating System -- Windows XP, etc.).
You can purchase ink online here. The BC-10 is a black ink only cartridge, and the BCI-10 is the replacement ink tank. The BC-11 is a cartridge with both black and color ink, and the replacement ink tanks are the BCI-11bk and BCI-11clr.
Jul 26, 2008 | Canon Office Equipment & Supplies
Sanyo DVP-P1 Thermal Photo Printer Logo
42 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
