Question about Microwave Ovens
Installing a microwave above a stove
I bought a used whirlpool microwave oven model MH1160xsq and I think I am missing a few of the mounting parts could you give me some idea of what I need and how to mount it above the stove.
  • 9098 Answers
SOURCE: Removing Microwave
First I would wonder if you really need to remove it from the wall? Many repairs can be done with it still in the wall. If so, installation instructions should be with the paperwork that came with the oven, and that will show you how to remove it. Buit if you don't have that, you would likely remove the grille from across the top. The grille is usually held in place with screws and/or clips. After that is out, there may be a couple of other screws now revealed at the top edge, or there may be a one or more "catches" just under the top edge of the the chassis. I would strongly advise you to have a helper working with you. These can be heavy, and awkward. You might call the GE Answer Center and ask if they can supply you with installation instructions. They're at 800-626-2005 (24 hrs.) Otherwise, you may be able to find instructions that are close enough at a place like Lowe's. They may have some demo models and you can usually ask to look at the manuals.
Posted on Jan 07, 2007
  • 9098 Answers
The installation guide will show you how it is installed and you can download that here:
If that link's a problem, just look it up under the Owner Center section here:
Posted on Nov 26, 2007
SOURCE: Danby Designer microwave (with exhaust
Its a bad magnetron
Posted on Jul 18, 2008
  • 13 Answers
SOURCE: I need install instruc. for a Whirlpool wallmount microwave.
sears should be able to get you the installation instructions and maint manual for this also, get on line go to and look up uour microwave part number like you did and look for the manuals
Posted on Dec 31, 2008
  • 1214 Answers
SOURCE: wall mounting needed for a top mount microwave/hood combination
Is there a wall behind where the microwave is to fit?
Most of these ship with a mounting plate and instructions for mounting to the wall. In fact, the wall bracket carries about 1/2 the weight, and the overhead cabinets carry the other half. The plates come with a good set of instructions for how to install.
Whirlpool is sending you to a distributor because they have to watch liability in this litigous world we live in..
Posted on Jan 29, 2009
Installing a microwave / convection oven above a stovetop
Needs to be properly vented to outside the house. Only install a microwave that's designed for over-stove use in this space.
Aug 25, 2014 | Microwave Ovens
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
I have bought a whirlpool microwave wmh1163xvs. where does the power cord exit the oven and where should the plug in be located?
Typically the power cord on above the stove microwaves exit from the top of the oven. That way the oven can be mounted to the wall and the power cord can be routed up to an outlet in the cabinet above the microwave.
May 02, 2010 | Whirlpool MH7140XF Microwave Oven
Microwave shut off like it lost power but the receptacle does have power to it. My model is an LVM1750.
The thermal cut out switch in the cavity is bad. I was unable to locate a wiring diagram on the internet but when I took the microwave apart, I found the wiring diagram inside the microwave on the back side of the touch panel.
This unit is mounted above the stove. We were cooking on the stove and also in the microwave. I think there was enough heat to trip the TCO switch.
Nov 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave is 21 years old. It is above the range
Um, no. You can get a new microwave that is much, much more efficient for a fraction of the repair cost.
Nov 09, 2009 | Whirlpool MH7135XE Microwave Oven
Whirlpool MH1160XSQ-1 microwave oven will not heat
all microwaves have a magenetron which produces the heat. if this is gone and it is not under warranty, it is not cost effective to repair. check you manual, most mag's have a 3 - 5 year warranty.
Nov 07, 2009 | Microwave Ovens
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Wall mounting needed for a top mount microwave/hood combination Whirlpool Model MH2175SB1. The cabinet above the stove is too flimsy to support the heavy microwave (50-60 pounds). Called Whirlpool. Sent me...
Jan 29, 2009 | Whirlpool Microwave Ovens
Removing Microwave
I just got my Whirlpool MH7100 off the wall. It was a bit of a hassle. I could not find a proper manual online at Whirlpool, but I guess since my unit was manufactured in 1993, who can blame them? Was the Internet even around in 1993?
There were 2 obvious bolts to remove above the microwave, these were found by opening the cabinet above. The next step was the hard one. Even after these were removed, the microwave would not lean forward so that it could be removed from the rear brackets. To get it to lean forward, I had to partially remove and partially break (i think) the vent for the exhaust fan. This revealed what looked like a very large screw with a regular head, one on each side. Once I unscrewed both of these, I was able to lean it forward and get it off the rear brackets.
Nov 25, 2007 | Microwave Ovens
Whirlpool Microwave Model MH7130XEZ-2
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa:
Oct 14, 2007 | Whirlpool MH7135XE Microwave Oven
Microwave Ovens Logo
196 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
