Question about Acer Aspire 5720-6661 Notebook PC
Problem with one of my disks, it says it needs to be checked for consistency. when i try to do a disk check it says an unspecified error occured
  • 506 Answers
Move the content of that disk to a different location, say external drive etc. and reformat the drive. Move back the content of the drive. You should okay.
Posted on Jun 02, 2010
Cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
(External drives will not schedule to happen on restart it will happen straight away.)
Sep 09, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
Cyclic redundancy error
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
Hard disk cyclic redundancy check
Fix a Cycle Redundancy Check Error
The "Cyclic Redundancy Check" error is a Windows error message telling you there's a problem reading data you're trying to access.
The root of this problem could either be a damaged storage device or a corrupt file.
Windows has built-in tools to attempt to fix to this problem, and avoid further errors.
Click on the "Start" menu in the bottom left-hand corner and click "Run."
Type in "cmd" and press "Enter" on your keyboard.
This will open a black command prompt box.
Type in "chkdsk /f" and press "Enter."
If you receive a message saying the disk will be checked the next time the system starts, press "Y" and then "Enter."
Restart your computer by closing the command prompt box and selecting "Shut Down" from the Start menu.
Wait for the disk scan to reach 100 per cent.
This may take awhile.
When it completes, your drive errors may be fixed.
Avoid future problems with this type of error by replacing the file that caused the problem.
For example, if you got the error when using a text document, open the document and copy all the text (press "Ctrl" and "A" at the same time and then "Ctrl" and "C" at the same time).
Create a new text document and paste the text in by pressing "Ctrl" and "V" simultaneously. Save the new file, and delete the old document.
Hope this heps
Nov 02, 2012 | Ultra 0471 Seagate St3500418as 500gb Sata...
Disk read error occurred on hp mini 110-3135
Sounds like your disk drive has a problem. Now is the time when you need a CD drive to fix it or attempt to fix it by running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 11, 2012 | Computers & Internet
When turning on my computer, I am taken to a black screen where I see: A disk read error occurred. Press Ctrl alt del to restart. How do I fix this?
This error occurs when the notebook cannot boot up from the hard disk. The hard disk may be faulty.
Try re-seating the hard disk to make sure it makes proper connection to the motherboard.
Next go into the BIOS configuration and check to see if the BIOS detects the hard disk, if it is not detected the the hard disk is probably faulty.
To get your notebook operating again, replace the faulty hard disk, install Windows on the new hard disk, plus the notebook's device drivers and your programs.
Jan 29, 2011 | Dell Inspiron 6000 Notebook
HP Pavillion DV9000t ''Unrecoverable error has occured''
The recovery disk is defective so the install is bad. Install using another disk (even a generic retail one of the same type will do) and your key.
Jul 14, 2010 | HP Computers & Internet
A disk read error occured and keep on re-start
Please check that the hard disk is connected properly. If you know that the hard disk is working, check whether it is detected or not. If it's not detected, you'll need to recheck it again with the power supply. If possible, try it to another Laptop so that you can make sure that Hdd isn't the culprit. In case it's detected and the problem still persists, repair the operating system installation, this will definitely solve your problem. Good luck.
May 26, 2010 | Dell Latitude D600 Notebook
Disk read error when booting
when a "disk read error" occurs, it's most probably the disk that crashed. you can try and repair the disk by booting from a bootable cd or USB-stick with diagnostic functions, such as UBCD4win, which can be downloaded for free. UBCD has many functions to check disks for consistency. if this does not help you, then i'm afraid that you will have to replace the disk with a new one. however, it may still be possible to retrieve data from the disk, if you connect it to a pc using a usb-to-ata bridge. the program i use for data retrieval is file scavenger.
Apr 21, 2010 | Gateway MT6451 Notebook
Showing the error report
might be your operating system files is attaked by some virus or try to play it other players if the same error occures even in that then there is some problem with syatem files and u have go for a virus scan
if the error occurs only with that player then try reinstalling the software it will work then my suggestion for you to use kaspersky antivirus u can download the trial version here this trial version is more than enough to just check http://www.soft82.com/download/windows/kaspersky-anti-virus/ here it is
Feb 06, 2009 | Microsoft Windows XP Professional
Acer Aspire 5720-6661 Notebook PC Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
