Question about SanDisk Sansa c200 MP3 Player
LOOSE DISK i loose my sandisk CD so i can not program it to my computer
  • 8,596 Answers
Sandisk website has the software
Posted on May 28, 2008
SOURCE:
I could not have access to all the programs installed by the manufacturer on my hard disk drive (D) because I had a virus and I reinstalled windows vista home basic My computer works but my dvd cannot...
When you reinstall a Operating system, sometimes you loose most of your programs unless you've backed them up. For the CD drive, you have to go into Control panel and go into your device manager. Check to see of your cd drive is listed under IDE controllers. If not, you may have to delete the driver, and let windows auto reinstall. Also, open your PC and if that's your only cd drive, you have to make sure the selector piece is capped on the master position.
Apr 02, 2014 | Acer Aspire™ T180 PC Desktop
Tip
Disk drive may be failing or my disk won't boot
Many times before a hard drive goes completely bad there are tell tale signs. If you can recognize them, there is a good chance that the data on the drive can be saved. The window of time in which action will be useful is quite small. Other than trying to fix the problem do not use the failing computer disk as you can just make the problem worse. <br /> What are the signs to look out for? While there are few surefire signs of impending disk failure there are some warning signals that give us the hint. Watch out for: disappearing files, very long wait while accessing files, files/folders whose contents appear to be strangely scrambled, reoccurring error messages while moving/copying/deleting/creating files, and strange but frequent crashes of your OS. If your computer will not boot saying that it cannot find the boot disk or other messages similar, the boot sector may be corrupt. <br /> Another telltale sign is any loud, low, irregular, clicking, or grinding sound which is emitted from the drive. This is the worst problem as your data and the disk are almost gone. <br /> What to do? Download on a friends computer and create a bootable CD from one of these manufactures:<a href="http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=seatooldreg&vgnextoid=480bd20cacdec010VgnVCM100000dd04090aRCRD"> Seatools</a> from Seagate,<span> the <span><a href="http://support.wdc.com/download/dlg/Diag504fCD.iso">Data Lifeguard tools</a></span> from Western Digital or <a href="http://www.hitachigst.com/support/downloads/">Drive Fitness Tool</a> from Hitachi.</span> <br /> <ul> <li>You must use a CD burning program (such as Nero Burning Rom or EZ-CD Creator) to burn a CD from the .ISO image.</li></ul> <br /> Using the CD, boot the problem system. Make sure the BIOS is set to boot from the CD drive first, not the hard disk. Follow the manufactures instructions to test your disk. Do not let the program write all zeros to the disk or format the disk as you will loose all your data. <br /> With luck, the program will repair any corrupt indexes. <br /> Remove the CD and attempt to do a normal boot. If you can then boot into your desktop, immediately backup any data as the fix may be short lived. <br /> If you don't have a CD drive, then you'll need to try using a bootable USB which is another topic.
on Oct 02, 2011 | Computers & Internet
My computer is stuck on the loading screen
You need a cd drive to run the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.Your only option without the cd drive is to do a System Recovery and loose all your data.
May 05, 2012 | Computers & Internet
I want to formate my system how can i do it instruct me...and will my genune copy of windows be tutelly removed
First of all, no your windows operating system key would not be removed because your hardware is already register to your computer. Yes by formatting your computer, you will loose everything and every single files, including the o.s. If you want to format and You want to restore your computer to factory setting, you will need to make a restore/recovery disk provide in the acer management program. You will see a option for making a backup disk in the acer management software in the start menua via all programs. After making this disc, save all the files that you want like pic,music,video,doc to an external harddrive. Insert disc or simply leave disc, Turn of you computer, setup your bios to boot from cd/dvd-disc in the bios boot menu. (should see this option when starting up the first few second, maybe a F key or DEl key to get you into the bios menu or A key saying boot option) Set your boot prority to cd/dvd. The Acer recovery program will come on and follow direction. If you just want to format everything and not making a recovery/restore disk (which I would not recommend unless you bought another windows operating system disc). Then just click my computer and locate your harddrive, Right click, format, you should be good to go. You will loose everything.
Jan 27, 2011 | Acer Aspire 5742Z-4200 Notebook
Computer crashed and won't boot. restarts before it loads
Firefox is a bad virus program three thing to do
1st safe mode
if not, reboot vista disk.
If can't you need to go to bios to run cd to restart fresh program. but remember if this you loose all media.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
Dec 05, 2009 | HP Pavilion DV9500Z Notebook PC
My computer is slow and the is not reading or burning CD/DVD
Slow computer problem would be different then that non reading disks. Slow computer could happen in many cases, a virus is taking up all the memory, or defragmented hard disk, programs that required more memory and cpu speed. CD, DVD could fail to read due to loose cable, BIOS setup or damaged drive.
Sep 16, 2009 | HP Pavilion a800n (PP163AA) PC Desktop
NTLDR MSSING, how can i solve this?
NTLDR is short for NT loader – a program loaded from the hard drive boot sector that displays the Microsoft Windows NT startup menu and helps Microsoft Windows NT load. So when it goes missing for some reason, your windows cannot load.
Cause:
1. Computer is booting from a non-bootable source.
2. Computer hard disk drive is not properly setup in BIOS.
3. Corrupt NTLDR and/or NTDETECT.COM file.
4. Misconfiguration with the boot.ini file.
5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
6. New hard disk drive being added.
7. Corrupt boot sector / master boot record.
8. Seriously corrupted version of Windows 2000 or Windows XP.
9. Loose or Faulty IDE/EIDE hard disk drive cable.
if there is attached drive ,remove the drive first before restarting the system if not then if you had access to another computer, copy the NTLDR and NTDETECT.COM which is available from the recovery CD which comes with computer. If you do not have the recovery CD, its available on microsoft site or is available from another computer using the same Operating System (Windows XP ). The location may be C:\i386\ntldr C:\i386\ntdetect.com use a bootable disc to restart the computer (the Win XP bootable CD or Win 98 bootable CD worked). After entering MS DOS mode, copy these 2 files to the C drive in the proper location. After restart, then pressing F10 on start up (used for system recovery ), then start the repair of Windows via system recovery This will reinstalled all Windows drivers and system files, while preserving all data on your computer.
Sep 16, 2009 | Computers & Internet
I have dvd 500 plus program from pinnacle. I loose the key number
Hi there.
When you bought the program it should have come as a disk, just find the install disk, pop it into the CD/DVD drive and execute the program and it will reinstall.
Good luck and thanks for using FixYa!!
May 26, 2009 | Computers & Internet
I lost the instalation disk for my c200 1 gb sansa mp3 player
GO to this link , so you can download the installation program ,
heres the link :
http://www.sandisk.com/Retail/DriverDown... , hope it helps and please rate , thanks AJ
Jul 01, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
