Question about Fujitsu Siemens Siemens Basic Line B17-1 17" LCD Monitor
Monitor in on/off loop. If hold select button down you can see the PC is diplaying but monitor keep going off then on. Also can hear the relay clicking in the monitor.
  • 23 Answers
That is a bad one. Sounds like you need a new relay. I know that is no help. Check the power cord, (believe it or not, they can have too little power going through if they get damaged or weakened by something). Check CLOSELY the video cable to computer connections. touch the ends and nearby cable ends while observing monitor to see if it flickers at the same rate of your movements. Try another monitor to see if it does the same thing. I can't help with much else on this. Good luck
Brock
Posted on Sep 16, 2010
Computer starts but no diplay shuts down immediate,
Is the power LED on the monitor ON, if not check the power cable connection at the monitor and at the mains.
Check the video cable connection at the PC.
Try a different working monitor on your PC and see if the monitor works on a different PC (the monitor maybe faulty).
Nov 17, 2012 | E-Machines T Computers & Internet
I press menu button and it shows OSD Locked instead of giving menu. How to remove this prob?
Hold down the select or menu button and press the power button keep holding down the select button until the menu appears this should unlock your osd :)
Feb 08, 2012 | Fujitsu Siemens Siemens Basic Line B17-1...
I've got a Philips 221V mnitor and it diplays:
boot your pc , keep on pressing f8 key then select safe mode option, remove the graphic driver, then shut it down, then again start install the graphic driver
Jul 28, 2011 | Philips C.927126 Monitor
Contrast button stuck? driver issue? etc?
It is a hardware problem and needs a replacement. Also try to unpress/release it by tapping lightly on the monitor. If you feel it is a driver problem then go to Start->Control Panel->System->Hardware->Device Manager->Monitor. Remove this monitor and from Action in the Menu select San for New HW. the monitor drivers will be loaded and you can then reboot.
Nov 08, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
I have a verticle black area on the left side of my computer moni
make sure no other electronic items like T.V r near by n better don place mobiles close to monitor n also don keep speakers parallel to monitor front panel
Sep 18, 2009 | Computers & Internet
My compaq sr181nx diplay monitor is now blurry
This could be a faulty monitor. Trying plugging in a different monitor to the computer.. If you continue to have the same problem with the second monitor, then it is your video card or on board video that is going out. If the video is fine after you tried the second monitor, then you need to get a different monitor for your system.
Jun 14, 2009 | HP Compaq Presario SR1810NX PC Desktop
My monitor is stuck in a constant color loop...
What you are seeing is a test they use at the factory. Here are the instructions to reset the monitor:
1. Press the MENU button
2. Use the + and - buttons to choose Advanced Menu
3. Press the SELECT button
4. Select Factory Reset
5. Select Yes
6. Press MENU again to remove the onscreen menu
Hope that helps :)
Dec 13, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Colour changing
I found this on another site:
[QUOTE=numbnutjas]I had the same problem along with lots of others who bought this great prolite monitor.
Whenever you turn the power off for more than five seconds the monitor looses an important bit of info of a hidden menu. Iilyama are not keen on publicizing the fact their monitor has a bug!
Follow these steps very carefully, it might not work the first time but it does work I promise.
Make sure that the moniter power button is off.
Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.)
plug monitor back in mains.
hold down + and - on the monitor
now hold down power button on monitor
let go of power when power button when the green led lights up
let go of + and - buttons
wait a few seconds and press menu, a hidden menu will appear in the top right
use the + and - buttons to move the hilighted option over the auto colour option in the menu
push the menu button.
It does work, but if you have any problems: email at : miamoo2038 at hotmail dot co dot uk
Feb 23, 2008 | iiyama ProLite E434S 17" LCD Monitor
Relisys 17in tft monitor
hi everyone,
i have a relisys monitor and had this exact same problem where the menu screen comes on and then cycles through the various options until it gets stuck in a loop within the colours settings.
- the solution i found is to open the monitor itself. (make sure power supply is disconnected)
- opening the monitor should be fairly easy - i have 4 screws located at each corner of the monitor.
- i have 6 screws which locate and secure the stand.
- once the screws are removed you can prise open the monitor.
- to make this easier start where the monitor comes apart
the easiest and the use your fingers to slowly prise the
rest of the casing apart.
- now examine the circuit board which you will spot quickly as it is the only circuit board visible. The rest is hidden by a steel guard.
- the circuit board is secured with three screws before
removing them make sure your body is free of static
by touching something which is metal and grounded.
- once you have removed the board locate the white connecters which are inserted in to the board.
- the one i disconnected was the one which is concerned with the menu system, which is the small connecter.
- refit circuit board
- refit casing
- refit stand
and there you have it your monitor should now work but with no menu facility, however the monitor will still have the ability to auto reset the screen should it be misaligned.
notes
this is not a complete fix, even though it worked for me it may not work for you, however you could try removing other connections and reseating them. more connections are locating underneath the steel guard inside the monitor.
Mr Jag Singh
Nov 25, 2007 | Relisys TL 766 Monitor
Fujitsu Siemens Siemens Basic Line B17-1 17" LCD Monitor Logo
436 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
