Question about Philips DVP-3005 DVD Player
How to clean the dvp 3005 DVD head player? - Philips DVP-3005 DVD Player
    President:
  • 1,099 Answers
Cleaning the laser lens
1) Remove any CDs from the unit and unplug all leads. Turn the unit upside down and use the small, flat screwdriver to pop out all the little plastic and rubber screw covers.
2) Take your normal sized Phillips screwdriver and unscrew all the screws.
BE CAREFUL not to damage the eject/power button ribbon cable, as these are very fragile.
Take a cotton bud and careful place some of the alcohol on it (but not so much that it is dripping everywhere). This alcohol is the same (or similar) to the small bottle of alcohol which is in audio and video cassette cleaning kits. This is probably the best way to locate a source. Locate the lens (the circular glass part) and very gently rub the cotton bud around the lens in circular motions for about 30 seconds, being very gentle. Once done, flip the cotton bud over and dry the lens with the other end for about 10 seconds.
You have now completed the cleaning process. This often cures read errors and should always be attempted first. Reverse the dismantling process and put the machine back together, making sure you DON’T TRAP the eject / power button ribbon cable, as this can cause serious problems for you if it happens.
Power on the unit and try to load both a CD. If all works fine then CONGRATULATIONS on completing the guide successfully.
Posted on Jun 02, 2010
My Philips DVD DVP 3005 won't play any sound. The picture is absolutely fine though. What can I do?
Find out the protection transistors between buffer ic 4558 and sound output rc socket and remove them and also check both + / - 12V on ic 4558
Thanks & regards
Shrinath inde
maharashtra india
Dec 28, 2010 | Philips DVP-3005 DVD Player
Hello Sir, Iam having philips 3005 dvp dvd player,last week i bought 29 inches samsung ultraslim flat TV and when i connected my dvd to the samsung tv.I got the following...
I would take it back and exchange it ,,if you purchased it new,,But if you bought it used,,and cant take it back,,I would take the top off ,,You can acces the dvd to retrieve disk and maybe see what the prob is,,thanks and goodluck
Nov 20, 2010 | Philips DVP-3005 DVD Player
As I am watching a movie, I accidental press a button on my remote of the dvd then something came out of the screen. inorder to get back to where i am watching i keep on pressing buttons on my remote. The...
It sounds as if you have inadvertantly locked your dvd player. Try using the code 136900. If this passcode is accepted, then access the general setup menu (using your remote) and choose the Disc Unlock option.
I hope this helps. I completely relate to the frustration of this very problem.
Nov 03, 2010 | Philips DVP-3005 DVD Player
My DVD 3005 is locked on a DVD do not know how it happened but obivously I have pushed the wrong button is there a common decode number I can use, I am unable to locate the manual for the player. Regards
I'm not sure whether this will work. Can you locate a small hole under the disc inserting outlet of your DVD player. If yes, push the eject button and insert a small pin well into the hole. The DVD struck in may come out in a few seconds.
Apr 07, 2010 | Philips DVP-3005 DVD Player
How can I make the DVP 3005 DVD player multi regional
I think you are looking to make your DVD Player, Region Free?? If so, here is a link that has an upgraded firmware that is NOT RELEASED BY PHILIPS, so use this at your own risk. Please read very carefully before attempting any of this. Use at your own risk.
Click Me
Heop This Helps
Oct 06, 2009 | Philips DVP-3005 DVD Player
My dvd model is philips dvp 3005 and it is in standby mode when i start my player standby led glows and when i press stand by button on the player or power on from remote control the screen shows no disc...
my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Sep 05, 2008 | Philips DVP-3005 DVD Player
Not able to read last files
This sounds like your player is on the way out.
If it,s 2 years or more older, i,d consider getting a new player, they,re cheap now £20-£30 ish Plus.
The remote will be new-Batterys. The DVD Player laser is probably on the way out. The mechanical sounds are possibly the laser head moving up and down, struggling to read The Data on The Disk.
Heres all you can do before Binning it.
1:- try a laser head disk cleaning Kit.
2:- put new batterys In The remote.
3:- ensure the underside of the CD/DVD are clean of fingerprints And scratches.
Hope this Helps Mike @ Compurepair.
Feb 22, 2008 | Philips DVP-3005 DVD Player
Software upgradation
Its called firmware, and you would need it on a disc, you would have to get it from Philips or maybe their website.
Don't download firmware from anyone else but Philips.
Feb 12, 2008 | Philips DVP-3005 DVD Player
Philips DVP-3005 DVD Player Logo
289 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
