Question about Juki DDL-8700
Joyee (Yuki copy) JY-A320 runs smoothly but doesn't stitch.
Hi. I'm so glad I found this site! I am searching for a user's manual for the Joyee JY-A320 industrial sewing machine. This machine is supposedly a copy of the Yuki. The thread keeps jumping out of the needle and doesn't stitch. Any hints would be both helpful and very much appreciated! Thanks. Colby
  • 323 Answers
SOURCE: Loose stitching underneath. HOW CAN I FIX!!!!
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
Posted on Jun 27, 2008
  • 3 Answers
SOURCE: needle thread breaks while quilting on machine frame
I think you might have better luck if you use 40 or 50 weight thread.
Posted on Dec 20, 2008
SewTechWayne
  • 186 Answers
SOURCE: Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Posted on Jan 31, 2009
  • 43 Answers
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
Posted on May 07, 2009
  • 4 Answers
Are you threading it correctly? I've had this problem twice, the first few times the thread was wrapped around different items (below the spool holder and then around the needle) the other times I threaded it wrong. Double check that the machine is threaded correctly with the manual. I've missed a step here or there and it does make a difference.
Posted on Jul 29, 2009
I have a Necchi Royal Series 4795 and I can only use a straight stitch. How do you set this machine to other stitches(hemming,serging)? just need to know what dials to set for which stitch & what foot
try --www.yumaeng.com-- for a pdf version user manual for the machine
that should give you all the information on what to do for the stitches you want
go google and type in ---user manual for necchi sewing machine model 4795-- as there other sites with user manuals as well
Jan 04, 2017 | Necchi Sewing Machines
I have no user manual and dont know how to thread or adjust the stitching
Search the internet for:
Make + Model + the word "Manual"
If you also search the internet, including YouTube, you will most likely find web site articles and videos that describe the functions you need help performing. Search for items like "threading sewing machine," "sewing machine stitch," etc.
Jan 26, 2016 | Sewing Machines
Bernina sewing machine
Hook don't catch thread
Possible reasons:
  • bent needle
  • needle/thread combination is not correct. When sewing, the thread should travel smoothly down the long groove on the front of the needle. (see user manual, chapter "Threads and needles")
  • stitch plate damaged
  • wrong hook timing (sewing machine needs to be taken to a BERNINA dealer for servicing)
Aug 12, 2014 | Sewing Machines
What should the tension settings be for Elna Club 4D overlocker
Hi Nikita86,
Do you perhaps still have a scanned copy of the Club 4D overlocker?
Jul 10, 2012 | Elna Sewing Machines
Im lookin for a manual for a joyee model jh811
Hi, where you able to find a manual for joyee jh811 machine? I'm desperate for one also. Would really appreciate if you could send me a copy or point to where I could get one :)
Jun 01, 2012 | Sewing Machines
I need a free manual for at 54 stitch sewing machine Kenmore 385 16554
or contact manufacturer support.
Aug 27, 2011 | Sewing Machines
My yuki serger run too slowly.i want to set up it speed faster because i am a worker in a sewing shop
Domestic sergers usually sew 1500 stitches per minute, you can't increase this. You can make the stitch longer which will move a bit more fabric through with each stitch but obviously you need the stitch to hold the fabric too.
If you find this is not fast enough for the volume of work you need to do, then shop around for an industrial machine. Usually built into a table, and designed to feed very fast. Try the Juki website, they do a big range of industrial machines such as these http://www.juki.co.jp/industrial_e/products_e/apparel_e/cat6/
Jun 13, 2011 | Juki MO-735 Mechanical Sewing Machine
I have a white brand sewing machine, Model # 2468, Serial # 70722. It contains 24 zig zag design cams.in great shape. The problem is I cannot find the manual. Any possibility of finding one? Thank you.
Hi
The Singer site usually has White manuals free to download.
I couldn't find a manual for the w2468 but I did find one for the w268.
http://www.singerco.com/accessories/manuals.html
Just type in w268 and click on search.
On the next page click on free download!
They also have a manual for the w2400, maybe it is similar to your machine?
Hope this helps!
Oct 28, 2010 | White Sewing Sewing Machines
I was given a Kenmore sewing machine 12 stitch model# 158-13521 and I am not sure how to change the dials to get size of stich, or width. I was looking for a manual but I cannot find one. I have found...
Whew, that was a tough one but I found you a deal. If, you go to www.sewconsult.com you can download your manual for $5.95 and they take paypal, which is great. Good luck and happy sewing, I am glad that my sources remembered this site, my usual ones couldn't help.
Sep 26, 2010 | Kenmore Sewing Machines
Juki DDL-8700 Logo
231 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
