Question about Seagate U6 (ST340810A) 40 GB Hard Drive
How to repair a clicking hard drive? i turned on my computer and insert the xp cd i press f9. when i choose cd rom my hard drive click in 5 times and stop clicking how to fix it? 3 years old hard drive
  • 11,800 Answers
Unfixable, the hard drive has a mechanical fault. Just junk it and get a new one.
Posted on Jun 02, 2010
HOW CAN INSTALL XP ON COMPAQ LAPTOP & DISABLE SATA DRIVE ON BIOS
Step 1. Insert the XPsoftware disc. Step 2. Restart your Computer. Step 3. Press F9 when your computer is boot up. Step 4. Change the Boot menu Hard Disc to CD/DVD ROM. Step 5. Press F10 after your change your boot menu. Step 6. Your computer will start to install your XP Software... Thanks Hope successful.....
Aug 22, 2011 | Compaq Presario Notebook
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
Apr 27, 2010 | Microsoft Windows XP Professional With...
My hard drive burnt out. The hard drive test says failed and the operating system won't boot. I placed a leftover hard drive from my Playstation 3 into the laptop and now it says no operating system found....
Try the recovery console from a windows xp recovery/install disk:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select the operating system you want to repair (you may have only one option).
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation. From here I would try "chkdsk /r" and "fixboot"
For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
For information about a specific command, type help commandname at the command prompt, and then press ENTER.
6.To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Once you've done this restart the computer and see if it boots up.
Apr 08, 2010 | HP Compaq Presario V6000T PC Notebook
I need to format my emachine hard drive. I don't have a recovery cd but i do have a xp cd
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5048
here you will find all drivers for your emachine ...
so ..assuming that you do not have expiriance ...I will try to explain in short how to do it ...
just insert the cd ...( be sure ya have the cd key if needed..) ...restart and press del to enter bios for to change the boot order to boot first from cd ...or ...
you can press F8 at start and choose to boot from cd and enter ...it will boot one time from cd ..and enter windows set-up..
after inspecting your computer will load primary drivers ..and ask you for the agreement press F8 again to agree...
inm this moment it will scan for previous installations and will show findings ...this is the moment that you press esc for to not repair or any ...than choose the C partition ...and see that you have D for delete it ...than enter to continue and L to confirm ...than C to create again and enter to format ....CHOOSE TO FORMAT INTO ntfs MODE...QUICK OR NORMAL ...
If you didnt format it a lot it doesnt matter too much ..but normal NTFS will take longer to do it , but it has a better efect ...from now on it will load the files ..and restart to continue the installation ..
the other partitions just format them from the windows ...by right click them ...and choose format ..from the list of commands..
Nov 07, 2009 | eMachines T5048 PC Desktop
Computer began to intermittentally give error message quit workin
A noisy hard drive is never a good sign. It sounds as if the drive is failing or has failed. You didn't say what operating system you have, but let's try....
You can try the following but it may not yield much. If, after these steps, the PC does start up, try to copy as much critical information as you can to either CDs, DVDs, flash drives or whatever you have.
Start the PC
During the boot, you should see a message to press the F2 key to enter setup - press the key when you see this. You key might be different, but press the one it says to press.
When you get into setup, find and change the boot sequence so that your CD-Rom looks first for an operating system
Insert your backup operating system disk - I hope you have that.
If you are not comfortable working with your PC at this level, it's usually best to take it to a repair shop. The advantage here is that even if they can't get the PC to run, many shops can still recover at least part of your data unless the drive is really destroyed.
The disadvantage is the cost - which can vary widely.
Now see the directions below:
Running Recovery Console without installing it If you cannot start your computer, you can run the Recovery Console from the Microsoft Windows XP/2000 startup disks or the Windows XP/2000 CD-ROM.
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, use the following steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
  2. Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  3. When you're prompted to press F6 for mass storage devices - press F10 instead. This will automatically start the Recovery Console.
  4. Alternatively, when the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  5. If you have a dual-boot or multiple-boot computer, choose the installation that you need to access from the Recovery Console.
  6. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  7. At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
Apr 05, 2009 | Gateway Profile 4 All In One (MPN...
Replacing with harddrive 40GB
Did you simply swap hard drives? "Couldn't find NTLDR" basically means the PC cannot find any version of Windows installed because the boot file is missing. This could be because you have a CD in the drive or the hard drive is missing or broken.
If you put in a new hard drive to replace your older smaller one you need to reinstall Windows on that new 40GB drive or it just won't work. If you have some PC Tech friends they should be able to move the data which is tricky or help you out.
Mar 18, 2009 | Compaq Presario 5000 PC Desktop
Hard drive failure
Hi, you have nothing to type there. You mean you have chosen the 1st section that opens recovery console,right? not that one. You should see the Terms of Agreement in your WinXP cd first, press F8. A section containing to install a Windows XP appears, Press Enter. Then that's the time it will search for your previous Win xp installation. In will then let you choose whether you will install a fresh copy of WinXP OR to Repair it. Choose the Repair. It will automatically repairs and format your Harddisk without deleting your files in it.  IF there's no Option to repair it, that's the time you will have to go to Recovery Console.
  • To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
    If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
If still you cannot get through to that, drop me a comment again and tell me what you have done. Feel free to ask me.
Dec 27, 2008 | Computers & Internet
Copaq presario v 2000 crash
HI
Can you log into windows normally?
If not, you may need to install windows from the beggining.
In case that windows work fine & the problem is just with system files, you can follow these steps:
1- From Start Menu choose "Run"
2- Type: SFC /SCANNOW
3- Press Enter & insert the windows XP cd when asked, then click continue or restart as the window tells you.
This should help you repair almost every problem in th systm folder.
Hope it works.
Nov 05, 2008 | HP Compaq Presario V2000 Notebook
Compaq evo d500 won't start up and won't let me access boot menu. just keeps saying keyboard fault even when another keyboard is used
press f10 during startup , when the bios open, look for the setting "halt on" . it will have a choice of keyboard, all errors or no errors , set it on "no errors" save and reboot. that may fix it.
You could also get another keyboard (neighbors or a new one) and test to see if a new keyboard solves the issue without recovering your system.
you can also use the recovery CD that came with your system:
USING THE RECOVERY CONSOLE TO REPAIR DAMAGED
FILES
If you cannot start your computer, you can run the Recovery Console from operating system CDROM
provided with the PC. To run the Recovery Console from the operating system CD-ROM:
NOTE: Make sure that the system is configured to boot first from the CD-ROM drive, then from
the hard drive. You can verify or change device boot order using the Computer Setup (F10) Utility.
For more information, refer to the Computer Setup (F10) Utility Guide provided with the
computer.
1. Insert the Windows 2000 or Windows XP CD-ROM into the CD-ROM drive.
2. Click Start > Shut Down, then select Restart from the drop-down list.
3. In the Shut Down Windows dialog, click OK.
4. Press any key to start the computer from the CD-ROM drive when you are prompted to do so.
5. On the Welcome to Setup page, press R.
6. Choose the installation that you want to access from the Recovery Console.
7. Type the administrator password. If the administrator password is blank, press the Enter key.
Oct 17, 2008 | Compaq Evo D500 PC Desktop
Windows xp service pack 2
Hi 1. Click Start, click Run, type regedit in the Open box, and then press ENTER. 2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom 3. To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1. 4. Restart your computer. NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD-ROM that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD-ROM. This may help. Good Luck
Sep 12, 2007 | Microsoft Windows XP Professional With...
Seagate U6 (ST340810A) 40 GB Hard Drive Logo
171 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
