Question about Acer X193W LCD Monitor
Colour of screen changes from white to yellow
New Acer monitor - fades from white to yellow on screen constantly
    President:
  • 1,216 Answers
May be possible that a cord from monitor to cpu is loose.
if not it is a problem in the driver ic and the cost of repair is about 20-25$
Posted on Jun 02, 2010
Fading colour
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | ViewSonic VA1703wb Monitor
Screen colour changing
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
Mar 31, 2012 | Acer P195HQB5 18 inch LCD Monitor
My monitor is not displaying colours.... its only showing bit of blue and yellow colour.... please give me solution.....
CRT monitors can fade over time. try resetting factory settings and degaussing, if you have that option. If not, you need a new monitor. Buy an lcd.
Feb 18, 2011 | HP mx705 17" CRT Monitor
PB Minos GP2W screen has coloured lines fades white then black
Most likely it's graphic card problem, but also may be monitor itself. First, check the signal by connecting to TV (if yours has a PC input), then replace card if that shows the same.
Aug 29, 2017 | Computers & Internet
Monitor color changed
there may 2 problems
1 ) Problem with the Data Cable connector the Pins might be damaged try to arrange them if disturbed / bend . if Broken change the connector.
2) Open the monitor see the soldering carefully you can locate out the dry solders easily by seeing the flux colour around it . just put the solder over there..by soldering gun to all places where u can see the dry solder.
Sep 05, 2008 | Gateway FPD2275W LCD Monitor
Computer monitor
u r monitor has colour controll /regulating problem.it has to be serviced.
Jul 29, 2008 | Gateway FPD2275W LCD Monitor
Monitor problems
it an hardware problem i would suggest u check the display i.c of the monitor
Dec 10, 2007 | HP mx705 17" CRT Monitor
Monitor problem- colour changes to white appearance to yellow appearance
COLOUR MONITER BASE COLOUR IC SOLDING AND BASE SOLDING OR CHEAK DATA CABLE
Mar 18, 2007 | SAMTRON 55V 15" CRT Monitor
Two vertical lines across screen
This is a common problem when LCDs are subjected to strong shock. Your internal circuits are damaged The panel itself may not be cracked but there is internal damage. I know of no cure or repair possible other than to replace the panel assembly.
Sep 24, 2006 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Acer X193W LCD Monitor Logo
721 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
