Question about Briggs & Stratton Intek Snow Horizontal Engine 7.5 Hp, 1in. X 2 27/64in. Shaft, Model# 12D412 0009 E1
Fuel in crankcase - Briggs & Stratton Intek Snow Horizontal Engine 7.5 Hp, 1in. X 2 27/64in. Shaft, Model# 12D412 0009 E1
  • 155 Answers
The fuel in the crank case is caused by bad rings or scratched/worn piston walls it the only way fuel can reach the crankcase unless you pour it in to the oil fill. The fix is to overhaul the engine. Thanks for using FixYa. Have a nice day. Jeff
Posted on Jun 02, 2010
Crank case is filling up with fuel engine wont start
On pre-electric fuel pumps .. ie. mechanical fuel pumps that were cam-driven, fuel could find its way through a faulty pump/failing gasket into the engine block and oilways ... and end up in the crankcase.
You seem to have the same problem.
You don't say what sort of vehicle you have, however, with carbs that develop a fault, fuel can find its way down past the piston rings and into the crankcase.
Whether your car has a mechanical fuel pump and carburettors, or an electric pump/injection, the fuel finding its way into the crankcase is the problem.
Sort that fuel problem out and your vehicle will start.
Dec 22, 2015 | Cars & Trucks
I have a 1993 Honda 125cc was told to mix gas but these oil in crankcase do I need to mix?
You would never mix any fuel and oil for the crankcase. If it is a 2-stroke engine, the fuel and 2-stroke oil will need to be mixed before entering the cylinder. Some engines have an automatic mixing setup - those have a separate oil reservoir for 2-stroke oil, but it will usually be a plastic tank, located nowhere near the crankcase. On a "4matic" engine, it fires like a 4 stroke, but there is no crank case, and the fuel needs to be mixed like a 2 stroke. What is the vehicle you are referencing? A dirt bike or street bike? It seems the CR125 and NR125 are both 2 stroke engines, so somehow the fuel needs to be mixed with 2-stroke oil. Can you take a picture of the crankcase oil cap?
Feb 04, 2015 | Honda Motorcycles
1999 mercury villager gas smell in oil
There are a number of possibilities here. Oil that is very old (high mileage) will become hydrocarbon contaminated over time. This can have a gasoline-like smell. There could be a problem with the piston rings allowing fuel the run down the cylinder walls into the crankcase. This can also occur in an engine that has a misfiring cylinder since the fuel is not being burned. Lastly, a leaky fuel injector can be flooding a cylinder, either when running, or after vehicle shutdown and before the fuel pressure bleeds off. This fuel will lay in the cylinder and eventually leaking into the crankcase, contaminating the oil.
Sep 05, 2014 | Cars & Trucks
CARBURETOR LEAKING OIL AND SMOKING
IT is likely that the carb is leaking fuel and filling the crankcase with fuel. Causing excessive crankcase pressure forcing oil into airbox through the crankcase vent. Check your crankcase for fuel and/ or being overfilled. If fuel is present fix the carb first, then drain and refill crankcase. After all is fixed run the unit outside for a few minutes and let it burn off excess smoke.
Sep 02, 2014 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Gas in crankcase
This sounds like it is an older vehicle with a cam driven fuel pump mounted to the block. If so the fuel pump is bad and leaking fuel into the crankcase.
Feb 17, 2014 | Vehicle Parts & Accessories
2001 chevy Z24cavalier seems to have to much crankcase pressure at the same time can't get fuel to throttle body even though fuel pump is running is this related if not fuel pump
too much crankcase pressure should be handled by the pvc valve-fuel filter may be clogged-change them and you may be running again -cheers Denny
Nov 01, 2013 | Cars & Trucks
I have CraftsmanLT1000 lawn tractor, Smokes heavily.
Many times a dirty air filter will cause this on this style of engine. When the filter is plugged, it creates a 'rich' fuel condition, and the engine smokes heavily, the excess carbon is drawn into the air filter, and plugs it even more.
check spark plugs, air filter, fuel filter, choke linkages (for full choke/no choke operation) and crankcase oil.
Crankcase oil can become fuel contaminated, thus overfilling the crankcase and filling the crankcase breather with raw oil/fuel, and this is drawn into the air filter, plugging it, and starting this senerio.
If there is fuel in the crankcase oil, drain completely, and refill with fresh oil. Then you need to look towards the carb for an inlet needle sticking, broken, worn.
Nov 15, 2009 | Craftsman Garden
Fuel coming through the crankcase of a 650 yamaha engine
carbueretor floats stuck open allowing the fuel to pass thru freely and into the intake system in which it the goes to the crankcase as it passes down thru the piston rings. Remove, clean, and rebuild the carbs.
Jul 18, 2009 | 1982 Yamaha XJ 650
2010 DIESEL, DIESEL FUEL GOES INTO CRANKCASE, A LOT! TRACTOR CAN NOT BE USED, CRANKCASE FILLS WITH FUEL AND SPRAY FROM CRANKCASE BREATHER SYSTEM. 1963, ITHINK.
do you have an injector pump mounted to the engine block? on some the seals on the pump leak letting the fuel go into the engine. only other thing would be the standpipe maybe cracked or broken. it is probally the pump though.not seeing how it's mounted i cant help much more than this.
Jul 16, 2009 | John Deere 420,1020,2010,2020,2510,2520...
How come the gas mixes with the oil then when u drive it it shuts off
it seems to be a fuel related problem. the gas should not be going into the crankcase. It is leaking into the crankcase . The fuel system is somehow leaking into the crankcase because of excessive flooding, or other fuel related problem like a gasket . don't drive the car like that.
Feb 02, 2009 | 1993 Nissan Altima
Briggs & Stratton Intek Snow Horizontal Engine 7.5 Hp, 1in. X 2 27/64in. Shaft, Model# 12D412 0009 E1 Logo
186 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
