Question about Intel Motherboard
No display i attch ram than no display but i remove ram than beep
  • 1 more comment
  • prhalad Apr 09, 2008
    no display
  • mzimen Apr 16, 2008
    the screen resolution is too low,the color quality is endup on [4 bit].
  • sachinmitali Jul 03, 2008
    No display
    Problem Solver:
  • 24 Answers
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
39
Posted on Mar 13, 2009
    President:
  • 2,351 Answers
Prhalad, every desktop pc & notebook has their own bios beep code's. These codes (beeps) vary in description. Ex: 1 long & 2 short - repeating. If you remove you're memory you will force a beeping error. No desktop or notebook will function without the system memory. Re-place you memory. If have no video display & you recently added a video card, chances are you did not seat the video card properley & you did not change the bios setting to boot to the video card you added.
To receive a better suggestion for a possible fix adjustment please list the model number of you're motherboard. Also if this is a desktop or notebook list the manufacture's name & model number & you're operating system (WinXP home/Pro/Vista).
It is normal to hear a single beep at boot-up. This is called
Power On Sefl Test. POST. Post checks the motherboard at every boot-up. If there is a problem post will run a series of beeps, known as beep codes.
Mike
Posted on Apr 11, 2008
  • 25 Answers
If its intel board pls replace bios
Posted on Jun 29, 2008
  • kiran kiran Dec 15, 2008
    if its 845 GVSR.GLLY FLASH the bios
5 short beeps followed by endless beeping after installing Windows 7
The beeps without display would indicate a problem with RAM video card, or keyboard. Try removing the RAM and putting it back in, and same with the video card. You can also try just removing the RAM and if you still get the same beeps then RAM is likely where the problem is. Same with video. Chances are there is just a bad connection and removing the components and putting them back in will fix it.
Feb 17, 2012 | Gateway GT5654 Desktop PC
Gateway PC GT5028 cpu fan comes on and stays on, but the computer does not boot, the screen is black and there are no beeps. I have replaced the power supply and the video card, but no joy. I also...
Just try putting your memory stick 1 at time, then on the pc, check each memory likewise mentioned. If this dosn;t work, trying taking out all the hardware attched to the motherboard, including hard drive, cd-rom. Now just try with to on your motherboard with basic hardware, video card, single ram. Hope you will find the problem, isf it is mainboard...best of luck.
Sep 17, 2011 | Computers & Internet
Ram beep but no display bios jumper is clear stat bios jumper is normal then no start machine
Please see this as reference
Continuous long beeps-RAM error
2 short beeps- BIOS error
1 long and 8 short beeps- Display Card error
1 long beep after few seconds 2 short beeps-FDC error
1 long beep after few seconds 1 short beeps-FDC is Ok
1 long beep and 2 short beeps-Display Card Error
Most probable cause is Ram memory, please try removing modules and reinserting, also try using alternately just one of them to determine which one is defective.
Mar 04, 2011 | ASUS P4GE-MX Motherboard
No ram beep comes without ram and no display
> No RAM beep comes without RAM.
That is to be expected -- when the motherboard does _NOT_ detect any properly-mounted RAM, the motherboard sounds the "no-RAM" beep.
> and no display
Correct. Without RAM, the computer cannot "paint" anything onto the video screen.
Nov 06, 2010 | Intel D845GVSR Motherboard
Display probelm
I am not sure but it sounds to me like the ram is bad.
Jul 28, 2010 | Intel Motherboard
Only three beep
1) try cleaning the ram.
2) if it the long beep there is problem with the ram try changing the ram.
3) if you face the same problem there is a chance of *********** board to be faulty
Jan 07, 2009 | Intel D845GVSR Motherboard
No display
Dear hubult,
There is issue with u RAM because when u remove the RAM it starterd beep it means u r RAM slot is ok. the problem is with u RAM pls change the RAM and then check it and one more thing before u change the RAM do one thing take out the CMOS battery and then restart the system after restarting the system shut down the system and then reconect the CMOS battery and start the system.
Regards,
Bittu_8
Feb 15, 2008 | Intel Desktop Board D845BG (KD845BGPAK10)...
Intel D865GBF motherboard in not giveing beep,display
if your motherboard does not give beep and display; remove your processor and ram and try working processor and ram on your motherboard, should there be no beep and display, your motherboard is dead.
Uzowuanya
e-mail:uzowuanya@yahoo.ca
Feb 15, 2008 | Intel D865GBF Motherboard
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Nov 13, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel Motherboard Logo
232 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
