Question about Sony Cameras
Intermittently unable to review photos taken with Sony A100. Also at the same time unable to access the menu
  • johnsheard Jun 03, 2010
    Thank you for this reply. That though is not the answer. The card is a vgenuine Sandisc Extreme 111 with no bent pins in the card slot. I was playing about with the problem around one answer I found, ie. takr the battery out for 5 mins and then replace. I wriggled the battery in it's slot without taking it out and all functions then worked properly. I think that it is a poor fit of battery causing the problem. The battery pins and slots need to be a slack fit to easily insert and remove the battery so sometimes it makes a poor contact thereby causing the problem.
    I don't know whether this is the cause and solution but this time it worked and will try it next time the problem occurs.
    What does anyone else think?
    John
  • johnsheard Jun 04, 2010
    This second idea seems excellent. I will do that.Thankyou for this sugestion.
    John
  • 94 Answers
Is the CF card a slow or counterfeit one? There are lots of cards on auction sites that are branded, but copies with poor quality components. try a known good High speed card. Also check if you have any bent pins in the camera CF slot.
Posted on Jun 02, 2010
  • cameradoctor Jun 03, 2010
    John, try cleaning the battery contacts in the camera and the battery itself with electrical contact cleaner ( can buy at auto parts stores ) The other thing you could try is to GENTLY pull the battery contacts to make more positive pressure on the battery - use a crochet needle. Best of luck :)
Blackberry will not send pics as mms
The BlackBerry device user is unable to send photos taken with the BlackBerry device camera in Multimedia Messaging Service (MMS) messages, because the photos taken by the BlackBerry device camera may be too large to send in MMS messages.
Reduce the size or quality of the photo and resend.
To access the size and quality options for the BlackBerry device camera, complete the following steps:
  1. Open the Camera application.
  2. Click the menu button.
  3. Select Options.
  4. Change the Picture Size and Picture Quality settings as required.
  5. Click the menu button and select Save.
And try to send the photo in an email message instead of in an MMS message.
Oct 11, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Unable to copy pictures from memory stick to the pc
This due to a malfunction in the software your usin to to download the photos.May be because your file no. is reseted.The best way is to connect the pc to your machine.When the software pops in close it down.Manually go to my computer and access the photos from the memory card or camera which appears as a memory storage device
Oct 04, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Picture suddenly pink
It is known problem of bad ccd imager in Sony DSC-T1 camera and ccd imager chip will be replaced to get normal live view in camera mode.
Sony will repair it free of cost so click Sony CCD Imager Support for details.
Thanks.
Sep 22, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
I have the sony a100 alpha... it wont take a photo. 4 red zeroes
Check the memory stick if its full and delete some photos......then try and take a shot.
the four red zeroes are counters for the number of shots u have taken.....it simply indicates you have a full memory stick.
Mine played the same trick on me too.
Jun 22, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony A100:put in empty CF cards, says card full, won't format
Might be 2GB card is more then enough for camera hardware o handle. Try 1GB card in this camera.
Mar 15, 2009 | Sony DSLR-A100 K Digital SLRCamera Digital...
I have a sony a100. It says unable to use card
What card do you use on the A100? And what capacity? Are you sure you have inserted it in the correct way? Be careful while inserting a CF card because of you insert it wrongly, it can damage the camera. Zooming is done using the zoom ring on the lens barrel. Just twist the zoom ring. Hope you are using the 18-70mm kit lens with the camera.
Feb 10, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
How do I review the pictures that I have taken?
Turn the dial on top to play. Then using the arrow buttons on the back of the unit next to the screen to change between pictures.
Click on this LINK and it will take you to the Sony website which has all the instruction manuals you need to get you on your way.
Take Care,
-WN
Dec 16, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
SonyCyberShot DSC W80
If u r unable to see live picture on LCD screen in camera mode, it means CCD Imager of camera isn't working. Contact nearest Sony service shop for proper solution because it requires CCD Imager replacement.
Jun 07, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Cameras Logo
93 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
