Midea WP10000 Air Conditioner Logo
Posted on Jun 02, 2010
Display shows p2 on aircon - Midea WP10000 Air Conditioner
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Jun 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
6569
Points
14
1、Check whether the resistance of the sensor is
normal (the resistance is 5Кω in the normal
temperature 25℃), when it is abnormal the sensor
should be replaced.
2、Check whether there is short circuit or open circuit
in the wire of the sensor, and whether the plug is
connected well, whether there is welding off or
rosin joint on the electric control board, if there is
any, it should be repaired.
3、When the 1 and 2 are both normal, then the
components or integrated circuit is damaged, the
electric control board should be replaced.
2helpful
2answers
How to fix CL display on TCL split-type Aircon?
HEALTH function (Optional)1. This function help carry away the accumulated dirt, bacteria, etc from the evaporator. 2. Turn off the air conditioner, press "CLEAN" button to enter this function and it will show "CL" on the display of indoor unit.
User Manual - TCL
https://www.google.com/search?q=TCL+split+type+Aircon+displays+CL
This is the best way to clean one with coil cleaner, a pressure washer and a funnel bag. Check out the videos.
How to Clean Split Air Conditioners (with Pictures)
wikiHow https://www.wikihow.com > ... > Air Conditioning
For the best clean, leave the spray on for 10-20 minutes. Finally, use a water spray to flush the unit and allow dirt to spill into the aircon bag. For help ...
tip
Display showing p2
turn unit on by display , runs for a few minutes and shout it self off , blinking p2
1helpful
What does exactly means 'INSP' in the aircon display of GW X240 4WD?
I am not sure something inspection or service,may you have to take to dealer.
1helpful
2answers
My freezer is flashing P2 - what does this mean?
Well, no, actually. P2 is an error related to the evaporator temperature probe. I would start with the electrical connections, the bond between the probe and the evaporator, and the evaporator fan.
Samsung aircon remote not working
Does your remote have batteries? If yes change them. Somewhere on the unit there should be a selector switch, put it into test and manually lower the thermostat setting
14helpful
Hobart AM15T ML-130039 with p2 message, what does this code mean
p2 would mean your rinse thermistor is open or shorted. its located on top near the the right side, after the vac. brkr. part# is 328994. remove old, istall new . dont forget to vote,hope this helps , monomoy
2answers
Water won't drain
To determine if your pump works, before attempting access from the bottom of the top drawer or from the bottom of lower drawer: You can manually pump the water out by doing the following:
1- Press the Power button to turn off the display.
2- Press the Lock button and then the start button the same tim. Hold them until the display showing up.
3- If the display is not clear with all the characters, press power button to see clear the display.
4- The first display is bL, then Er,Ld..dd, FU, P1, P2...by pressing the Start button to go by the sequence until P2 (drain). If you miss, be patient to continue press and release the start button to get back to P2.
5 When is is at P2, press Lock button to tun on the drain. When you hear the water flowing to the drain, you could pull the top drain to see how the water is draining.
6- When the water is out, press the lock button again to stop it.
7-When it is done, press the Power button to get out of manual mode.
If this is working, then your water is there because you are running the bottom and your air gap allow back flow to the top drawer and or you are running the top and your air gap allows a back flow to the bottom drawer.
Please let me know if this is not the case.
None of the words are showing
Put the files on the root of the P2's folder. Unplug the P2. Leave it off for 2 mins, and power up.
Now, if this does not work, you probably need a config.dat file which you copy with the 2 firmware files onto your P2.
Open notepad
write:
YP-P2
XX XX UMS
Replace XX XX with the 2 letters in front of your P2's firmware (Settings>System>about). Example: EU EU UMS
and save as config.dat (remember all files)
Top Midea Heating & Cooling Experts
SmartAviator
SmartAviator
john h
Are you a Midea Heating and Cooling Expert? Answer questions, earn points and help others
