Question about Canon ES5000 Camcorder
Canon ES5000 hi8 camcorder won't load a tape.
My ES5000 hi8 camcorder's motors are operating to open and close. But when I put in a hi8tape and push the cartrdge close, the motor will only lower the tape 1/4 inch and then bring it back up and eject. Can you give me any feedback as to what is wrong? I am attempting to backup by hi8 tapes on my computer. Thank you.
  • 37 Answers
That is the mechanism alignement(mode switch)
plus a little gear who match with the other
you will need a very good tech to fix it.usely its the problem.
hope that will help
regards Alan
Posted on Jun 02, 2010
How do you reset sunroof in a 2001 Monte Carlo with 3400 model I
check fuse and relay if good than possible motor ot track problem their should be a mechanical bypass that will let you close it if stuck open the following information is courtesy of monte carlo forum
To check the condition of your original sunroof guides:
  1. Gl*** in closed position.
  2. Locate & remove 3 torx bolts on each side of sunroof glass. Lift glass out of sunroof opening & set aside in a safe place.
  3. Locate "J" shaped cover plate at front of sunroof track assembly. Remove 2 torx bolts from each cover plate.
  4. Lift up bracket to remove.
  5. Inspect the plastic guides on each side. The sunroof cables attach to guides on front outer corner. Inspect this area closely for damage.
  6. Do not operate the sunroof with the J plates removed.
Troubleshooting:
If the sunroof guides are not broken & the glass is a uniform height along the rear edge your problem may be a stripped gear inside the motor. The motor has a manual override:
  1. Get access to the motor by removing the map light/switch console or lowering the front of the headliner.
  2. Insert a large standard screwdriver into the nylon bushing at the center of the motor hub. Push up & turn the screwdriver to manually move the sunroof glass. If the unit will fully open & close manually, you most likely only need a replacement motor.
If your sunroof is stuck in the open position follow these steps to get it closed:
  1. Remove the glass.
  2. Try to close the unit without the glass. Many times one side will still be operational and close correctly.
  3. Try to slide the inoperable lift arm forward. If it moves, slide it forward until it stops.
  4. You now need to slide the original plastic guide forward to lower the arm to the closed position. Using a standard screwdriver, push it forward. The lift arm should begin to lower.
  5. If the lift arm will still not fully lower, remove the J plate as explained above, sometimes the sunroof cable will need to be lifted up to allow the guide to fully slide forward.
  6. Reinstall glass.
May 21, 2016 | Cars & Trucks
Jammed by putting tape in upside down
Take off the battery on the camcorder. Insert the battery and at the SAME time, push the power and the eject to see if this resets the camcorder so it will eject. If this does not work, I'm afraid the unit will need to be taken apart and removed manual. Good Luck
Jun 25, 2007 | Sony Handycam CCD-TRV37 Camcorder
Why am I having difficulty rewinding and playing tapes?
Is the Canon UC9 a HI8 camera?? If not it wont play HI*.
Aug 21, 2015 | Canon UC9 Camcorder
Camcorder VHS tape is tangled
Sometimes you can salvage a VHS tape by opening the cassette and manually winding or rewinding the tape to put the damaged section to one side and under tension to "iron out" the wrinkles. Your Fuji Hi8 tape may be quite thin so this repair may not work.
Dec 18, 2013 | Canon ES300V ES4000 ES410V and ES420V ES50...
When opening or closing drivers door, the window opens 5" instead of usual 1/2" and does not auto close. Also after operating window switch, onetouch or holding, the window lowers or raises and then stops...
what car
electric windows.
can fail for 3reasons
power does not reach the motor.
motor is bad
the guides are seized.
some times, the motor seems good but is weak, bad internal
commutator. (2/3s power)?
use a voltmeter see if 12v reaches motor on demand (push switch)
if that is ok, we have it down to 2 problems in 5min flat.
you could then disconnect the motor, and see if the windown
can be operated by hand, if not , its jammed
if you can , then the motor is bad or weak.
you are now IMPOWERED.
Oct 16, 2013 | Cars & Trucks
Handy cam hi8 dcr
Try removing the battery and charging it. Then put the battery back on the camera. This will reset the cassette system. The cassette should open or close depending upon what status it is in. Once you get the camera to eject fully, clean your heads with a dry head cleaner cassette for Hi8 video. If your camera is still eating tape, could be a broken pin or damaged heads.
Aug 26, 2013 | Sony Handycam DCR-TRV280 Digital Camcorder
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
My tape will not eject!!!
u must to open ur camera and eject motor u put 3 dc volt then it eill eject and clean all connect then fixit and try
Jul 02, 2009 | Sony Handycam CCD-TRV107E Camcorder
Sony hi8 ccd-trv208e pal -
Why not get a professional video company to do it for you ? Quality will be better than any domestic setup could achieve.
Aug 07, 2017 | RCA CC6254 VHS-C Analog Camcorder
Video Cameras Logo
371 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
