Question about ASUS (WL-167G) 802.11g/b (wl167g) Wireless Adapter
Is this device combatible with windows xp professionsl x64?
  • Anonymous May 11, 2010
    Hello jRock73
    You can find driver downloads for it HERE. The Vista drivers for this device support both 32 and 64 bit.
    However, the XP drivers don't mention either. You can find the manual for it HERE. However, I looked through it and saw no mention of what platforms it supported there either.
    Have you tried it on and XP 64-bit machine yet or are you considering purchasing one?
    You can go HERE and submit a technical inquiry if you like.
    HERE is a post on a forum re: someone having tried the original XP drivers unsuccessfully on a 64-bit machine. Some other things he tried (and found did not work) are listed there, too.
    If his analysis is accurate, it would appear that there are no 64-bit XP drivers for this device.
    * If the information I provided you w/
    * resolved your problem or lead you
    * to a resolution for your problem or
    * an answer to your question, then, a
    * "FixYa" rating would be most
    * appreciated. @:)
    * (You can assign the same rating to
    * more than one expert who participated
    * in solving your problem.)
    * It is best to wait until the problem
    * has been resolved b4 rating the experts'
    * solution(s). Once you enter a rating,
    * the problem will be closed and we will
    * not be able to continue to assist you.
    * Very often it will take more than one
    * exchange of information between you
    * and an expert in order to resolve your
    * problem. If a proposed solution doesn't
    * work for you, don't rate it yet. Instead,
    * post back here letting us know and we'll
    * continue to work w/ you until we find a
    * solution that does work for you.
    * Thank you
    * BJ @:)
    Problem Solver:
  • 6 Answers
I Also have a Asus WL-167g usb wireless card. last night 5-21-08 i got tired of it not working so i removed the casing to see the chipset manufacture, i found it is a RT2571 and you can go to http://www.ralinktech.com/ and go under support, windows and download the second one down for usb. USB(RT257x/RT2671. this one works on win xp pro 64 bit. i installed it last night and works great
Posted on May 22, 2008
    Sergeant:
  • 202 Answers
You might want to check out the post by ARIES HERE. He has some links there that might be helpful. They didn't work for TNYSTRAND but s/he may have had other issues.
The link to Ralink is broken on ARIES' post but you can find what s/he was referring to HERE.
BJ @:)
Posted on Apr 09, 2008
  • Anonymous Apr 17, 2008
    Hello jRock73
    How did it go? Did the information and links I provided you w/ enable you to determine your wireless adapter's compatibility on a 64-bit XP system?
    I DO hope that is the case. :) If it isn't, please, post back here and we'll continue to work w/ you.
    If it is the case, would you kindly take just a moment to assign a FIXYA rating for my "solution"? I would be very grateful for your generosity and show of appreciation.
    Thank you once again for using FixYa! Have a beautiful day.
    BJ @:)
SOURCE:
Is the ensoniq mr61 compatible with windows 8? Is there a device or upgrade for this?
Supported Operating Systems and Hardware MQ Essen
tials
Midi
Quest
Midi
Quest
Pro
Info 32-bit Windows support: Win 8, Win 7, Vista, XP checkyes.png checkyes.png checkyes.png 64-bit Windows support: Win 8 x64, Win 7 x64, Vista x64, XP x64 checkyes.png checkyes.png checkyes.png Windows Midi Quest x64 with x64 plug-ins to support 64-bit VST hosts checkyes.png Intel Macintosh systems: OS X 10.9, 10.8, 10.7, 10.6 and 10.5
Check this link
May 29, 2014 | Computers & Internet
My Canon MX726 wont come up on my computer or my device but it says its connected to the wifi network How can I fix this
Hi, at what stage during your attempts to connect your laptop to the printer does it fail?
In the meantime here is the download for the device manual which will contain instructions on how to connect your printer:
MX720 series PDF User Manual Windows 8 8 x64 7 7 x64 Vista Vista64 XP
Mar 20, 2014 | Computers & Internet
Looking for driver MF5630 canon Win_64
I have spent hours to find a solution... there is no driver. But there are definitely 2 solutions:
1. MF5630 - using ONLY printer in Win 7 x64:
You have to use the drivers for MF5700 Series - http://driverscollection.com/?file_cid=4213082682609f383f81540957d
- http://www.techulator.com/resources/4156-How-add-Printer-manually-your-Windows.aspx
1. First, Click on the Start button in your screen, further click on Control Panel button and then double click on Devices and Printers button.
2. Then click on Add a Printer button in the menu.
3. Further select the Add a local printer button from the available menu.
4. Then choose an existing LPT port and click Next button .
5. Further select the correct driver from the driver list menu for your printer. Suppose if the requisite driver is not available then click on the Windows Update button. After the Windows 7 Update installation finishes in your computer, once again search for the appropriate driver for your printer.
2. FINAL SOLUTION - for printer and scanner - if you have proper PC configuration:)
Win7 has a possibility: http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
you can install the WIN XP environment where you can easily install driver for Canon MF 5630 (or any other by Win7 x64 not supported printer/scanner) and additional software.
BUT YOU NEED to run: Windows 7 Professional, Enterprise, or Ultimate editions. Windows XP Mode is not supported on Windows 8.
Your BIOS must support Virtual Machine.
Jan 31, 2012 | Office Equipment & Supplies
Canon pixma mp258 driver
Printer Driver for Windows XP, Mac OS X, Windows Vista (x64), Windows 7 (x64), Windows 2000, Windows 7, Windows Vista, Windows XP (x64), Linux, Windows Me, Windows 98
Get link for Driver Here
look at the bottom of the post also includes link download for resetter and manual reset for Canon MP258 printer
May 24, 2011 | Office Equipment & Supplies
Acer aspire 5520 XP x64 audio driver
Sorry to say,but I could not even find the Xp-x64 driver on the site.
Mar 31, 2009 | Computers & Internet
Cant get router to work on windows xp profeessional x64 edition with m2n4-sli motherboard
if you go to..
zyxel.com support and downloads you can find the latest firmware and drivers for your device. also user guides if yours missing.
you can also use the contact us (top right) to contact tech support for assistance.
sorry not much help
Sep 16, 2008 | Microsoft Windows XP Professional x64...
Upgrading to Windows XPx64
The answer is no because your motherboard still only supports 32 bit drivers. Read On.
Here's what you need to use Windows XP Professional x64 Edition
Important: Windows XP Professional x64 Edition cannot be successfully installed on x86 (32-bit) systems or 64-bit Intel Itanium–based systems. 32-bit device drivers are not supported on Windows XP Professional x64 Edition.
• Computer with a supported processor: AMD Athlon 64, AMD Opteron, Intel Xeon with Intel EM64T support, Intel Pentium 4 with Intel EM64T support
• 256 megabytes (MB) of RAM or higher recommended
• 1.5 gigabytes (GB) of available hard-disk space (additional space may be required if installing over a network)
• CD-ROM or DVD drive
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• Keyboard, Microsoft Mouse, Microsoft IntelliMouse, or compatible pointing device
arrow_px_up.gifTop of page Additional items or services required to use certain Windows XP features • 28.8-Kbps modem or fax modem and service provider required for Internet access (service provider may charge a fee)
• Sound requires a sound card and speakers (USB speakers require a computer with USB support) or headphones
• Remote Assistance requires that both parties be running Windows XP and be connected over a network
• Remote Desktop requires a computer running Windows 95 or later and the two computers must be connected over a network
• DVD video playback requires a DVD drive and DVD decoder card or DVD decoder software and 8 MB of video RAM
• Windows Movie Maker video capture feature requires an appropriate digital or analog video capture device and 400-MHz or faster processor for digital video camera capture
May 09, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Open Questions:
See all ASUS (WL-167G) 802.11g/b (wl167g) Wireless Adapter Questions
ASUS (WL-167G) 802.11g/b (wl167g) Wireless Adapter Logo
287 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
